Old 05-11-2003, 08:44 PM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default TRF414mII newbie question
should i make my car 4 wheel brake or just leave it as is?
if yes how do i make it four wheel brake????
im using yokomo's 139's and the tale always seems to slide out after the turn when i floor it. sometimes before the turn
im using firm inserts is that why
what should i do??
Calvin Ng is offline   Reply With Quote
Old 05-11-2003, 10:28 PM   #2
JohnA's Avatar
Running full time four wheel drive will make the car more stable under braking. On the 4141mII you will need to buy a front diff and a locked centre pulley, the TA04 ones are fine, a lot cheaper and you can buy the delrin outdrives like the ones in the rear of your 414 later if you want too.
I would, however persevere with the one-way, unless you are racing on a small and low grip track, it's not bad once you get the hang of it.
As for the rear spinning out when you floor it, that's nothing to do with the one-way. Under power the car is four wheel drive. Make sure your rear diff is set correctly, not too slack or tight, get an experienced racer to have a look. Also try to be a bit smoother on the throttle, you wouldn't expect any car to stay straight if you floor it on the apex of a corner.
Your tyres & inserts should be fine, ask around and see what others are using at the track and go with that. I find firmer inserts better.
JohnA is offline   Reply With Quote
Old 05-11-2003, 10:43 PM   #3
Registered User
Calvin Ng's Avatar
thanx a bunch
the guyz told me to get firms but it seems to be weird
one guy helped me out and told me to use whites in the front and yellows in the back. its better but there could be improvments
Old 05-12-2003, 04:31 PM   #4
Registered User
Calvin Ng's Avatar
hey can you give me the part number i looked for it and couldnt find it
newbie question bbamboo Rookie Zone 2 07-31-2008 07:23 PM
Newbie set up question for TC TylerOwenby Rookie Zone 2 05-08-2007 09:39 PM
Gearing Question For TRF414mII Calvin Ng Rookie Zone 1 06-16-2003 02:02 PM
Part Number For locked centre pulley for trf414mii. Rear diff question Calvin Ng Electric On-Road 2 05-12-2003 10:41 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
