Old 05-11-2003, 08:11 PM   #1
Accord's Avatar
Send a message via AIM to Accord
Default Best solder to use for hard wiring batteries?
What is the best solder to use for hard wiring batteries?
Accord is offline   Reply With Quote
Old 05-11-2003, 09:49 PM   #2
Radio Shack 60/40 rosin core solder - part # 64-008 (the BIG spool- just buy it....you will use it all...someday).
0.062 diameter
You can buy the smaller diameter, if you run an iron that is not very big, but you NEED an iron that will do the job!!!! #1 problem with not getting a GREAT solder joint.
acloco is offline   Reply With Quote
Old 05-11-2003, 09:56 PM   #3
Hi Accord,
Remember to use a 60 watt soldering iron..good for the job.
Cheers...
monster_sg is offline   Reply With Quote
Old 05-12-2003, 06:57 AM   #4
CRASH's Avatar
Trader Rating: 26 (100%+)
A no-clean solder is the best type to use. The residue it leaves behind will not effect the solder joint.
I use Kester no-clean solder.
Later
CRASH is offline   Reply With Quote
Old 05-12-2003, 08:45 AM   #5
ersin or rosin core, well anything with flux in it.
a 30W iron with a decent tip will be sufficient. if your tip looks like a dogs dinner then you'll need 60w,
remember to use some fluxite as well
sanj
schumacher is offline   Reply With Quote
Old 05-12-2003, 11:26 AM   #6
pdduubb's Avatar
What temp is best used for soldering?
I just got a Radio Shack digital iron that adjusts by farinheit degrees.
Thanks in advance for any information you may provide.
pdduubb is offline   Reply With Quote
Old 05-12-2003, 01:19 PM   #7
Registered User
The best solder is Acer Racing SuperSolder 6% Silver/ 94% Tin.
About $4.99 per oz.
RadioShack 60/40 .050 dia. rosin-Core Solder is good choice. The solder is not too thick or too thin.
With 60W flat tip solder iron.
Aku-Man is offline   Reply With Quote
Old 05-12-2003, 01:24 PM   #8
R/C Tech Charter Subscriber
Trader Rating: 30 (100%+)
I'm with CRASH on this one.....Kester no-clean is all I use.
Lowrance is offline   Reply With Quote
Old 05-12-2003, 03:47 PM   #9
Accord's Avatar
Where can I buy Kester no clear? I've never heard of it before.
Old 05-12-2003, 11:47 PM   #10
Registered User
This is the Kester web site:
http://www.kester.com/index2.html
This some info on the "no clean" solder:
http://www.kester.com/245.html
This is where you can get some:
http://www.summitelectronics.com/ecg-components.html
Read this before using:
http://www.kester.com/PDF%20FILES/PD...0245%20Core%20(02Oct01).pdf
This is the Manufacturer's data sheet:
http://www.kester.com/PDF%20FILES/PD...20Cored/245%20(06Dec99)logo.pdf
thatdog is offline   Reply With Quote
Old 05-13-2003, 01:36 AM   #11
I use the 60/40 from radio shack it works great.
As for the iron a 40watt will do you but not for me, my friends refer to my iron as LAVA because its INSANELY HOT! and the solder joints take a few extra secs to take.
Chris@WeaponR is offline   Reply With Quote
Old 05-13-2003, 05:32 AM   #12
where I bought mine... http://www.wassco.com/245nocfluxco.html
Old 05-13-2003, 05:57 AM   #13
Regional Moderator
Addict sa RC's Avatar
Has anyone tried the Acer Racing 6% Silver solder? Are there any improvements against the Deans 2% Silver solder?
Addict sa RC is offline   Reply With Quote
Old 05-13-2003, 06:00 AM   #14
Accord's Avatar
I currently have a Weller soldering station and it came with a 40w soldering iron. Even when I put the heat setting all the way up, sometimes I can't even melt the solder! If I got a 60w soldering iron would this solve my problems?
Also, does anyone know what Weller's website is? I can't find it.
Old 05-13-2003, 06:20 AM   #15
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
John, Hakko soldering station is the best I have ever used, ask Steve about one, you can look at mine if you like, they rule. I have been using the kester solder for years, and really only like to use that.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Trying to solder AAA batteries shiston Australian Racing 4 05-11-2006 04:49 PM
Hard Wiring???? jhigga15 Electric On-Road 7 02-24-2005 08:10 AM
solder batteries axel Electric On-Road 15 02-23-2005 09:26 PM
Hard wiring batterys berger Electric On-Road 31 11-11-2003 09:47 AM
Hard Wiring M Ignacio Electric On-Road 43 04-29-2003 07:48 PM
