Old 05-13-2003, 06:49 AM   #16
Accord's Avatar
Send a message via AIM to Accord
I used the soldering iron that Steve and Les have set up at the corner of the work benches near the door, that thing was awesome! Was that the Hakko soldering iron?
By the way, I ordered an Xray T1 Evo2 and it should be arriving today . Hopefully when I go up there later to pick it up Steve will also have the Hakko soldering station in stock.
Accord is offline   Reply With Quote
Old 05-13-2003, 06:58 AM   #17
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Yeah John, that is a Hakko.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 05-13-2003, 09:03 AM   #18
Send a message via AIM to M Ignacio
Spooky, which Hakko soldering iron was that?
M Ignacio is offline   Reply With Quote
Old 05-13-2003, 08:43 PM   #19
TimPotter's Avatar
M Ignacio .....Hakko 936
Old 05-13-2003, 09:09 PM   #20
Racer X's Avatar
I'm sure that someone will correct me if I'm wrong (I'm reasonable sure that I am not). Silver solder (usually) uses acid flux and is not good for electrical connections of any kind.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 05-13-2003, 10:40 PM   #21
Spooky, was that the black or white Hakko 936?
Old 05-14-2003, 09:02 AM   #22
Registered User
We are moving toward lead free solders. In the future there will not be any tin/lead solder.
Common Alloys Being Used or
Evaluated to Replace Lead
& Their Melting Points
Sn96.5Ag3.5 (221 C) tin(Sn)/silver(Ag) solder
Sn95Sb5 (232-240 C)
Sn95.5Ag3.8Ci0.7 (~217 C)
Sn95.8Ag3.5Cu0.7 (~217 C) NIST Alloy
Sn99.3Cu0.7 (227 C)
Sn96.2Ag2.5Cu0.8Sb0.5 (213-218 C)
Sn97Cu2.0Sb0.8Ag0.2 (226-228 C)
Sn91.8Ag3.4Bi4.8 (202-215 C)
Sn42Bi58 (138 C)
The silver solders come with different fluxes. Depends on the application. The silver solder that is used for jewelry uses the acid flux.
thatdog is offline   Reply With Quote
Old 05-14-2003, 10:05 AM   #23
TimPotter's Avatar
M Ignacio, White.. if that makes a difference..
Old 05-14-2003, 01:40 PM   #24
akrcracer's Avatar
First off, You need a hot iron. Check it out. www.bormir.com. Look under goot irons, TQ series. I have a TQ 95. Best 25.00 I ever spent on RC. Only problem, Bormir is having a hard time keeping them in stock, because the word is out them. As for your question about solder. Acer racing solder as the highest silver content adversized. I had a hard time soldering with this solder with a 42 watt iron. And I had a good one (Weller WTCPT) even with a ungar race station (60 watt iron)I once had. I would buy some rosin core flux to use with Acer solder. Dean's is a good solder. Or last use 63/37 solder you can buy a electronic store. 63/37 can be used with irons that don't get as hot.
akrcracer is offline   Reply With Quote
Old 05-14-2003, 01:43 PM   #25
akrcracer's Avatar
racerx, Acer silver solder uses rosin flux in their solder.
Old 05-14-2003, 02:00 PM   #26
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
i use deans and it works great
Intermision is offline   Reply With Quote
Trying to solder AAA batteries shiston Australian Racing 4 05-11-2006 04:49 PM
Hard Wiring???? jhigga15 Electric On-Road 7 02-24-2005 08:10 AM
solder batteries axel Electric On-Road 15 02-23-2005 09:26 PM
Hard wiring batterys berger Electric On-Road 31 11-11-2003 09:47 AM
Hard Wiring M Ignacio Electric On-Road 43 04-29-2003 07:48 PM
