Personal Transponder + Heatsink Fans...
My receiver only has two channels....
Having put off purchasing a personal transponder for a few months now (I have a policy of only buying things that I feel will make me faster), I finally buckled and bought one this last race. I have to say, it was kind of cool to not lug that huge transponder on my body. HA... Anyway, I have a motor heatsink/fan coming in in a few days. If I use a Y splitter to split the battery terminal on my receiver, would it sufficiently power both the fans (cool can fan has dual fans) and the personal transponder? I'm kind of stressing over this b/c I don't want to have to buy another receiver/radio system... Thx. |
Solder the fan wires to the speedo + and - terminals. Also means that when you plug your battery in they start automatically and stay on until you unplug them.
I thought about that - I hardwire though, so I kinda would like to forego that option. Thanks anyway...
Oh right ok......you could get a servo extension lead. Solder the extension lead to the speedo terminals then when your ready plug the fan into the extension lead.
http://www.apexmodels.com/product-search.php , look down the righthand side for Search and type in 'lead'. The first thing that comes up should be a 'Futaba Servo Extension Lead'. Charles |
Originally Posted by Charles Godwin
(Post 3652991)
http://www.apexmodels.com/product-search.php , look down the righthand side for Search and type in 'lead'. The first thing that comes up should be a 'Futaba Servo Extension Lead'. Charles I wonder though, couldnt you solder the fan wire where the on/off wires are soldered on to? then when you switch on, the fan should come on Or just put a switch on the fan its self being soldered to the speed neg/pos |
Originally Posted by StickyFingaz
(Post 3652920)
Having put off purchasing a personal transponder for a few months now (I have a policy of only buying things that I feel will make me faster), I finally buckled and bought one this last race. I have to say, it was kind of cool to not lug that huge transponder on my body. HA... PTs will make you faster! The lighter weight, plus the ability to mount them lower (in less accessable spots) will lower your overall weight and lower your CG. The lower weight will give you a better power to weight ratio and the lower CG will allow you to turn harder without fear of rolling over. Plus, not having to remember to put it in, or take it out every heat makes it a great pit-time saver, allowing you to peak your batteries later keeping their voltage up. -Frank |
