Old 09-06-2007, 03:21 PM   #46
Default LRP 13.5 w/ Sintered vs. Novak SS13.5 Pro Sintered?
LRP sintered Rotor????
With the LRP Sintered Rotor... Does is the Vector 13.5 still equil to the Novak SS13.5 Pro with sintered rotor?
JPG333 is offline   Reply With Quote
Old 09-06-2007, 03:27 PM   #47
Default MORE Pics of 13.5 motors please!!!
Originally Posted by syndr0me View Post
Today, the Orion 13.5 brushless motor showed up, thus completing the availability of "stock" brushless from the three big sensored motor manufacturers.
Basically, three companies are making sensored brushless motors right now that are readily available to consumers. Those are Novak, LRP and Feiago. Novak and LRP only sell motors under their own brands, while Feiago is the OEM source for several companies, including Orion, GM and SpeedPassion.
We've seen posts from Charlie saying that all the companies are working together with the sanctioning bodies to create a standard for spec brushless motors to ensure they're as even as possible. Many of us assume that 13.5 motors will be the new "stock," and 10.5 motors will be the new spec mod (19T). Presumably, those will be the two motors where there's focus on design limitations, with all others being considered open mod, and possibly not subject to the same limitations. It's not clear how today's 13.5 motors will fit into those rules.
There are a lot of 13.5 threads floating around, but I figured it would be good to unify them all into one place. Many stock racers have already switched over, and I imagine as time goes on, we'll see a lot of other people make the jump as well. Hopefully we can use this thread as a single point of reference and resource for these motors.
Can you provided Torn down pictures of the LRP Vector 13.5 and the Novak SS13.5 Pro??? I think that would be a great addition to this thread. Would like to see them soon if you can provide them. I am going to print these pictures and use them for a 13.5 tech book for my club.
Excellent Pics.... Great thread???
Old 09-06-2007, 03:38 PM   #48
GreaseMonkey's Avatar
Is the fan removable on the Orion rotor?
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 09-06-2007, 04:27 PM   #49
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'll see what I can do. It's pretty time consuming getting it all ready to go.
syndr0me is offline   Reply With Quote
Old 09-06-2007, 04:28 PM   #50
syndr0me's Avatar
It doesn't seem like it's intended to be removed. I didn't look into how hard it would be to force it out.
Old 09-06-2007, 04:29 PM   #51
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Originally Posted by rc-zombies View Post
these are available from SpeedPassion
to work with the LRP or Orion open type solder holes
Do you know the size hole that these will it into? I may use them on my ESC
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-06-2007, 05:23 PM   #52
rc-zombies's Avatar
don't know size..but they should fit the SpeedPassion BL motors..and assuming it will fit the LRP's and Orion's.
I've thought about these too for my speedos..
soon as I have a large enough order.. I'll order some overseas..
Old 09-06-2007, 08:50 PM   #53
Trader Rating: 44 (100%+)
u'll probably have to consider the fact that both novak and LRP have cheap and expensive versions of 13.5.
eg.
Novak EX13.5 vs SS13.5
LRP Eraser13.5 vs Vector13.5.
IMO, without knowing the specifications, it is possible that the cheaper versions COULD be more suited to running in the same class WITH 27T brushed and the more expensive (i.e. faster) motors suited to a class of their own.
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 09-06-2007, 08:57 PM   #54
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Order me some
Me+soldering holes (like the orion motors)= bad
I cant solder those worth my life
Count me in for 3 of them when you order
Also, if you can get me some cheap bullet plugs like you have, I will take some of those too!
But to add to the 13.5 thread, I think pics of all would be cool also... I would, but my novak is messed up! If I were to take it apart, It would be done for shure.... So I dont want to risk it
BlackedOutREVO is offline   Reply With Quote
Old 09-07-2007, 10:53 AM   #55
maximebeauvais's Avatar
Trader Rating: 6 (88%+)
who know's someone from the ROAR.
or is there any ROAR guy here that read all the threat about the BL motor?????
we need there feedback about this
Maxime Beauvais
--- www.rcottawa.com ---
maximebeauvais is offline   Reply With Quote
Old 09-07-2007, 10:42 PM   #56
James35's Avatar
Does anyone know how to pronouce Feiago?
James35 is offline   Reply With Quote
Old 09-07-2007, 11:48 PM   #57
Yes, but not me.
Old 09-08-2007, 02:20 AM   #58
UK.hardcore's Avatar
it is feigao.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 09-09-2007, 01:00 PM   #59
syndr0me's Avatar
I ran the Orion 13.5 a couple of times today, but had to cut testing short due to a bad one way.
My initial impressions are not good. The speed of the motor seemed okay, but the good news ends there. It felt like a light switch, with the worst feel of any brushless motor I've ever run. It had really soft drag brakes, and no grunt out of the turns. The throttle really felt like it was on, off or nothing in between. This was a pretty massive disappointment compared to the LRP motor which is a dream to drive in every sense.
I'll no doubt need to do more testing to give a more definitive opinion. I didn't mess with timing the motor yet (it's at 0 currently) and I didn't have enough time to try all the gearing possibilities. However, none of that will matter when it comes to drag brake, and that was by far the biggest let down.
Old 09-09-2007, 01:05 PM   #60
Wow, thats not good man!
Thats so wierd because my 10.5 was AMASING! And I wont ever be buying a LRP or novak to run 10.5, orion all the way
How big is the rotor in the orion 13.5? Maybe its too small?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 07:05 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 06:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 09:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 09:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 02:33 AM
