Old 12-21-2007, 09:29 AM   #571
Originally Posted by JayBee View Post
The 13.5?
Yes, I can't find the LRP 13.5 either.
Squating Goat is offline   Reply With Quote
Old 12-21-2007, 09:46 AM   #572
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Originally Posted by wallstreet View Post
McGreevy where were you able to get your hands on an lrp. They have been out of stock everywhere.
Superior had one left, and a sintered rotor.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-21-2007, 10:01 AM   #573
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Tower had some instock early this week from what I saw.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-21-2007, 10:09 AM   #574
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by syndr0me View Post
When comparing the 13mm rotor in the Novak, I've heard guys say it's slower, and guys say it's faster. My experience is that it's about the same, it just makes the motor a little more forgiving when you're gearing it, and has a better drag brake feel, which is what I preferred. You have to gear it quite a bit higher, though, so make sure you've got the pinions & spurs to make that happen.
How much higher any starting point? i'm at 5.4 with the SS Pro and stock sintered rotor now. My LRP I was at 5.1. Are you taking like mid 4.'s??
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-21-2007, 10:26 AM   #575
syndr0me's Avatar
Gear it like your LRP/sintered to start out, then adjust it from there. It should be a similar gearing.
Brushless is pretty easy, really. Keep gearing up until your lap times aren't any faster, or until you're getting the motor so hot it goes into thermal shutdown. If you're doing things right, you shouldn't get it that hot. Every 13.5 I've ever seen will stop getting faster long before it starts getting too hot. Generally, if they shutdown, something is wrong, like a binding drivetrain. I personally try to keep the motor only geared as high as it needs to be to be at its fastest, and don't go any higher even if I've got room for more based on heat alone. It tends to just use more juice, and drop the battery's voltage faster, especially toward the end of the race.
syndr0me is offline   Reply With Quote
Old 12-21-2007, 10:54 AM   #576
syndr0me's Avatar
The trick is to keep it gangsta, y'know what I'm sayin'?
Old 12-21-2007, 11:48 AM   #577
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Yeah the 13.5
wallstreet is offline   Reply With Quote
Old 12-21-2007, 12:48 PM   #578
JayBee's Avatar
Trader Rating: 31 (100%+)
Very, very true....you guys listening?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-21-2007, 12:53 PM   #579
syndr0me's Avatar
Also, a seized bearing in the motor will cause it to thermal if you're lucky, and completely melt down if you're not.
Old 12-21-2007, 12:57 PM   #580
Verndog's Avatar
Oh ya...loud and clear. I learned that running several Mamba Max's. You keep gearing till you find the point of diminished return (heat goes up faster then speed)...then back down a tooth or 2. Less if the track / use does not require, to save battery and voltage.
A temp gun or calibrated finger is critical in BL.
So JB...you going to SIR tonight?? Maybe I cant wait for my 13mm via mail...and I see you want to sell 1.
---Team Hoarders---
Old 12-21-2007, 01:05 PM   #581
JayBee's Avatar
Yep...but Patrick picked up the rotor already.
Old 12-21-2007, 01:38 PM   #582
Skruger's Avatar
Wink Going to race local'r
But Pat picked up the rotor already.
I might be racing Fridays at SIR starting next year
ROAR # 11-118753 / MATT #11-118754
MECH # 11-118755 / RYLEE #11-118756
RIP :Loretta Plueard 2017
SUPPORTING NORTHWEST HARVEST --- WWW.NORTHWESTHARVEST.ORG THE HUNGER STOPS HERE
Skruger is offline   Reply With Quote
Old 12-21-2007, 02:31 PM   #583
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
i got a 13.5 novak and last time i ran it i was running 88sp with a 39p and after 5min the motor was coming out @ 108deg
SERPENT S811 AND S811T, FUTABA 4PKS , viper rc solutions
OS SPEED WORLDS EDITION 21 , OS 2060 PIPE
BYRON %30 FUEL , PROTEK 2300 LIPO RX PACK
SAVOX SERVOS 1268MG HV , 1267MG HV
turboxrayt1fk05 is offline   Reply With Quote
Old 12-21-2007, 02:33 PM   #584
on this lay out , this motor had tons of rip and i know i could of gone up to 41p if i want it too.
URL=http://s199.photobucket.com/albums/aa99/corallyrdx_2007/?action=view&current=1106072232a.flv][/URL]
Old 12-21-2007, 02:34 PM   #585
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 07:05 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 06:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 09:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 09:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 02:33 AM
