Old 12-20-2007, 06:01 PM   #556
syndr0me's Avatar
Trader Rating: 32 (100%+)
I've been thinking about email this guy to see if he'll share some secrets on what he's doing to his "built" brushless motors. It sounds like he opens them up, maybe rewinds them, creates better solder joints, polishes rotors, etc. I think I'd be interested in learning to "tune" these things, but I'm not sure where to start. I guess I could find one that's burned up, tear it apart, and get my head around how things work. I'm still curious to see if Novak's Sentry can be leveraged to make a crude dyno.
syndr0me is offline   Reply With Quote
Old 12-20-2007, 06:33 PM   #557
TryHard's Avatar
Originally Posted by syndr0me View Post
Oh, I can definitely relate. My peers at the track make fun of me saying I'll get something different as soon as someone else shows up with it. :-)
I need to get a picture of the 416 with the LRP ESC and Orion 13.5 in there, it looks pretty slick.
Damm.... guess that means you won't have the 416 for long then... given you'll be whooping everyone with it soon hehe
Ed
| THard.co.uk | Xray | MuchMore |
Old 12-20-2007, 09:41 PM   #558
mtbboy's Avatar
Hey guys
any news on the tekin r1 system yet or is it still in refinement like their servos?
Id like one but cant seem to find anyone with stock.
Dave,\.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 12-20-2007, 10:42 PM   #559
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
what are the goods and the bads of a 13mm rotor in a 13.5?
metalracer2 is offline   Reply With Quote
Old 12-20-2007, 11:06 PM   #560
Verndog's Avatar
Trader Rating: 16 (100%+)
I am about to find out. I bought a Novak 13.5 ss Pro and have a 13mm coming. I'll compare that to my LRP sintered 13.5 and run which works best. One thing I see initially, the LRP has more torque out of the corners and a better feel then the sintered ss pro. The ss pro has a bit more top end with less heat. About a wash with the tip going to LRP with feel. The 13mm is suppose to give similar brushed feel-- less heat-- more gear to the Novak...we'll see.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-20-2007, 11:38 PM   #561
syndr0me's Avatar
I found the LRP 13.5/sintered and the Novak 13.5/13mm-sintered to be very, very similar. The LRP was maybe just a tad smoother.
When comparing the 13mm rotor in the Novak, I've heard guys say it's slower, and guys say it's faster. My experience is that it's about the same, it just makes the motor a little more forgiving when you're gearing it, and has a better drag brake feel, which is what I preferred. You have to gear it quite a bit higher, though, so make sure you've got the pinions & spurs to make that happen.
Old 12-20-2007, 11:42 PM   #562
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
syndr0me,
How are you gearing the LRP compared with the Novak with those rotors? Same? If so, how many more teeth are you going up with the 13 mm rotor over the std. rotor?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-21-2007, 12:00 AM   #563
syndr0me's Avatar
Originally Posted by Brian McGreevy View Post
syndr0me,
I believe I geared the LRP 13.5/sintered and the Novak 13.5/13mm-sintered almost exactly the same.
With the standard rotor and NiMH, I found myself around 40-41mm rollout. With the 13mm, it was closer to 45-46mm. That's just ballpark, but it sounds like other people are in a similar range. You're probably smoother on the throttle than I am, so you might be able to pull more gear. If you're using LiPo, go up a few teeth to account for the voltage difference.
Old 12-21-2007, 12:01 AM   #564
syndr0me's Avatar
Man, I'm so bummed I can't make it to Novak to see how things go down in 13.5 and 10.5.
Old 12-21-2007, 12:04 AM   #565
JayBee's Avatar
Trader Rating: 31 (100%+)
Yeah that would be a saweet race to go to. Just imagine the feedback though; that's what I'm waiting on
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-21-2007, 12:20 AM   #566
What about the LRP 13.5 with the bonded rotor?
I was personally at a 41 mm rollout last time I ran with the Novak 13.5/sintered (not 13 mm)...and going up to a 45 or 46 mm rollout is gonna require a big gear! I'm already at 88/41 LOL.
USVTA Member #211
Old 12-21-2007, 12:26 AM   #567
syndr0me's Avatar
I never ran the LRP 13.5/bonded, but I assume it'll be quite a bit lower than the sintered. EA might know, I think he did some testing with it.
Yea, the gearing is insane. I was getting close to 50mm with LiPo. I usually keep pinions from 35 - 60 on me. It's nuts. I had to pick up an 88 for the 416, though, 'cause the big pinions were hitting the top deck. :-(
Old 12-21-2007, 12:42 AM   #568
I'm gonna have to get the 36 tooth pulleys for the Phi to make that LRP work, as I don't have any more room to move the motor forward, only about a tooth worth. With the 36 pulleys I can get that 41 mm rollout with a 35 tooth pinion instead of a 41.
USVTA Member #211
Old 12-21-2007, 07:50 AM   #569
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
McGreevy where were you able to get your hands on an lrp. They have been out of stock everywhere.
wallstreet is offline   Reply With Quote
Old 12-21-2007, 08:43 AM   #570
JayBee's Avatar
The 13.5?
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 07:05 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 06:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 09:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 09:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 02:33 AM
