Old 12-17-2007, 09:06 PM   #526
RBLove's Avatar
Trader Rating: 72 (100%+)
Originally Posted by 8up-racing View Post
The one purple motor thats pulling on all the others may have the 14mm rotor in it.It makes a big difference.There is the stock rotor,the sentered rotor,and the New,14mm it works great! Great Job NOVAK! Whats next from the "ORANGE"!
And you can put it in any of the motors,3.5 and up.
Yo 8up! What is up?
It is actually a 13mm rotor. It creates less air gap providing a little more cog and taking a MUCH larger gear. Whether it is faster or not is yet TBD. I do not think it is faster, but it gives a different feel. Standard sintered rotor will have quite a bit more rpm.
RBLove is offline   Reply With Quote
Old 12-17-2007, 09:13 PM   #527
gurumods's Avatar
Originally Posted by RBLove View Post
Yo 8up! What is up?
RBLove,is this the one you are talking about.13mm Tuning rotor
http://www.shopatron.com/product/par...95.17447.0.0.0
4x4 stampede/monster truggy
1/16 E-revo
gurumods is offline   Reply With Quote
Old 12-17-2007, 09:21 PM   #528
RBLove's Avatar
Yep
Old 12-17-2007, 09:25 PM   #529
YEP! My bad 13mm,not only once ,but twice!
Wadup ROB? Had a great time ths week end.To bad the weather kept some away. Rock on Tri-State, and a BIG Thanks To John/BSR
TC5-TC4-KSG-Tekin-Novak-3PK-Hitec-PRS-Gears-John's BSR-Racing-Tires Tri-State Raceway In Hamilton ,Ohio-Much More-Spektrum Associated-Team Magic-APS-SMC Competition Electronics-Ice.
8up-Club Dayton,Ohio
108% Certified 8up
8up-racing is offline   Reply With Quote
Old 12-17-2007, 09:33 PM   #530
RBLove's Avatar
So what are you guys gearing the Orion 13.5? Is it close in performance? Run the fan or remove it from the rotor?
Give me the low down
Old 12-17-2007, 10:02 PM   #531
gurumods's Avatar
I think i will be going with the Novak motor and the 13mm tuning rotor and the LRP esc.I have found a few different part #s for the LRP speedo.Tower has LRP80700.I found 8050 and 80750 on ebay.Correct me if i am wrong,but the latest and greatest LRP is the one with the 2007 edition sticker on the front right ??.Tower does not show the box,but i would hope that they have the 2007 one listed.
Old 12-17-2007, 10:05 PM   #532
Hey Rob,whats up?...me man,ya know I'm 8up!
I like the rotor,it did improve lap times on Jr's TC5 and it decreased motor temp.Yesterday,when he WON the 13.5 class,the motor was only 112. You coming down next weekend?
108% Certified 8up
Old 12-17-2007, 10:07 PM   #533
JayBee's Avatar
Trader Rating: 31 (100%+)
gurumods-
No.80750 is the TC SPEC which is, as far as I understand, the boss model
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-17-2007, 10:19 PM   #534
gurumods's Avatar
Originally Posted by JayBee View Post
gurumods-
Well aaaaaalrighty then.I just have to have that one
Old 12-17-2007, 10:31 PM   #535
Default mf2 gearing
hey
I have just ordered a couple of LRP sphere esc & vector 13.5 for our mf2 trucks.
anyone got any gearing suggestions.
we now usually run a 18 to 20 pinions & 86 spur.
the trucs are used on a off road track.
cheers
raedat is offline   Reply With Quote
Old 12-18-2007, 09:58 AM   #536
gurumods's Avatar
Can anyone tell me the bearing sizes for the Novak 13.5 ss.I would like to order ceramics so i have them when my motor arrives.I was told that one of them 3/16 x 1/2.Don't know if the other is the same.
Steve
Old 12-18-2007, 10:57 AM   #537
ta_man's Avatar
Trader Rating: 151 (100%+)
Steve
The other one is 1/8X3/8 - a standard motor bearing.
ta_man is offline   Reply With Quote
Old 12-18-2007, 12:24 PM   #538
runs_wscissors's Avatar
Default 13.5 Operating Temperatures
Just started foam TC racing with a Novak 13.5 with GTB ESC.
Initially I was undergeared and had only about 100deg. in the motor, which was 1.5 sec. off the A-main lap times. With a complete collection of pinions I started to inch up the gearing and monitoring the temp and lap times. Soon enough I was running 165 deg. and my best laps. I even went 1 tooth further and the ESC shut down at 190 deg. at even a better fast lap time. Went back down and raced a club night in 3 races at 165 deg. so it seems the gearing is right on.
My question is why don't I see more heat management devices on brushless setups? I am interested in trying heat sinks, fans, vents or whatever it takes to put that next larger pinion on. Specifically I'm talking about the motor itself since my ESC already has a fan/heatsink.
I did get one of those novak velocity V-shaped heat sinks and will install that for some back to back testing.
runs_wscissors is offline   Reply With Quote
Old 12-18-2007, 02:14 PM   #539
gurumods's Avatar
I jusy checked Acer Racing for bearings.They have the 1/8 x 3/8,but do not offer a 3/16 x 1/2.That seems odd that they would not offer that bearing.Maybe it is 3/16 x ???????.If soemone has that bearing out of their motor,can you please double check the size and LMK.Thanks
Steve
Old 12-18-2007, 04:24 PM   #540
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Front Bearing Size: 1/2” x 3/16” (12.7x4.8mm)
Tire Chunker is offline   Reply With Quote
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 07:05 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 06:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 09:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 09:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 02:33 AM
