Old 11-19-2007, 09:20 PM   #421
STLNLST's Avatar
Trader Rating: 21 (100%+)
lllllllll
STLNLST is offline   Reply With Quote
Old 11-19-2007, 09:40 PM   #422
RBLove's Avatar
Trader Rating: 72 (100%+)
In touring cars I have found the 13.5 to be a little faster every where on the track (straights and infield). We have some of the best stock racers in the country (Mo Denton, Eli Ezrow) racing at our track and I was a little faster with the 13.5. In brushed I am usually chasing these same guys.
I have yet to test the 10.5 against 19 turn, but plan to do so in the next couple of weeks. From the sounds of it I think the I will find the same results as the 13.5/27t.
On rubber tires I was able to pretty much match lap times between 27t and a 17.5, but when I ran the 13.5 I was a LOT faster. Once you figure out the gearing on the BL motors they are rockets.
I was running an LRP Sphere with a Novak 13.5 SS.
Just my experience.
RBLove is offline   Reply With Quote
Old 11-19-2007, 09:50 PM   #423
Suspended
Thumbs up
Novak 13.5 ss pro motor has an "ORANGE" timing ring fella's..
losidriver70 is offline   Reply With Quote
Old 11-19-2007, 09:51 PM   #424
Suspended
Thumbs up
Id second that phrase.yesterday at the track in my second qualifier we have a section where there is tabletop double double . like my third lap i over shot the first double and just punch it and the car did a back flip over the second double landed on its wheels and i kept going. thats some torque and no bullshit i must of got some good traction when i punched it! "offroad! cap city rc center!
Old 11-19-2007, 10:10 PM   #425
JayBee's Avatar
Trader Rating: 31 (100%+)
Just my experience.
My experience has been the same. Just this last Friday we were running 19t/10.5 foam and by time the main came around, the corner marshals thought I put a BL-mod in. The car was an absolute monster down the straights and a leap frog in the infield. My rollout was 36mm and motor temp was only 140-degrees!! This was with a Core 5000 lipo too
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-20-2007, 06:39 AM   #426
Originally Posted by Ffejdat View Post
Ted Flack- do you have any opinion on 12th scale 19T, which is faster there, 19t brushed or 10.5, the way you were wording your opinions above, I am presuming you were talking 10th scale for 19T.... Thanks Ted!
I haven't seen any 10.5's in 12th scale at Josh's.
Just a little more on perfromance. I believe the 13.5 is faster than a
27t.....when you get the roll out and driving style figured out. I am not sure about the performance of the lipo and brushless together compared to brushless and NiMh. I just don't know yet, but it looks like the NiMh has a slight advantage when used with the brushless motor. Do you guys suppose it might be the lower amp draw of the brushless motor?
Ted Flack is offline   Reply With Quote
Old 11-20-2007, 07:21 AM   #427
KE4PJO's Avatar
Ted;
Have you run the 13Mm rotor? thoughts?
KE4PJO is offline   Reply With Quote
Old 11-20-2007, 08:58 AM   #428
Originally Posted by KE4PJO View Post
Ted;
Not in the 13.5, but I might be able to try it later today. If I do I will post the results.
I did run it in the 10.5 but that was all I ever had I so didn't do an actual test.
Old 11-20-2007, 09:13 PM   #429
Ffejdat's Avatar
Thanks Ted!
Ffejdat is offline   Reply With Quote
Old 11-21-2007, 02:45 PM   #430
robk's Avatar
Trader Rating: 22 (100%+)
I have been racing in a series at a few local tracks with 10.5 or 19t in 1/12. The 10.5 definitely has more torque/rip out of the corner, and looks faster down the straight, but lap times are close. The last race i attended had 3 or 4 guys doing virtually identical hot laps with either motor. I can only figure that 19t is more drivable, especially since some of the tracks don't get a ton of bite.
13.5 on the other hand is reliably .2 or .3 sec. a lap faster.
Old 11-21-2007, 09:05 PM   #431
Send a message via AIM to goop
13.5 on the other hand is reliably .2 or .3 sec. a lap faster.[/QUOTE]
i totally agree rob i will be running my 13.5 novak this weekend so i will be able to see and compare my laptimes from last weekend
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 11-24-2007, 05:54 PM   #432
TryHard's Avatar
Hi guys,
I know this is a debatable question, but given all the talk over whats faster, has anyone run a 15.5 against a 27t?
My local club looks like it's going to allow brushless soon, and I'd like to be able to suggest a motor limit that we can use for B/L motors... It would seem that the general consensous is that 13.5's are faster (by how much is the debatable question)... so I'm wondering if suggesting a 15.5 to be the option.
Splitting classes isn't an option, and not everyone will switch (I know I will, then again, I'm one of the ones pushing for it ), so would like to keep it as fair as possible. Otherwise I could easily find myself in the situation whereby I'm accused of bing faster purely because of the B/L motors....
regards
Ed
| THard.co.uk | Xray | MuchMore |
Old 11-24-2007, 06:49 PM   #433
Trader Rating: 27 (100%+)
Originally Posted by TryHard View Post
Hi guys,
regards
Ed
dont know about a 15.5, but the 17.5 is very close to a tuned stock. The way you go about getting the simlar lap times (gearing, driving style) is another topic. Thats my take. The 13.5 is closer to a 19turn than a stock imo
convikt is offline   Reply With Quote
Old 11-24-2007, 09:37 PM   #434
ILDRVR's Avatar
I ended up ordering a Novak GTB and 13.5 SS . I was really interested in the XBR Sport/EX 13.5 Brushless System, but I didn't have enough info on them to give it a try. I couldn't take the chance of wasting the money and then have to upgrade anyway.
Thanks for all of your help I really appreciate it. I can't wait to get it in my TC.
Tarara Racing
Tea's Hobby Shop & Raceway Park
Cheese City Xtreme RC
ILDRVR is offline   Reply With Quote
Old 11-25-2007, 09:55 AM   #435
chris72983's Avatar
I was looking on getting a new 13.5 for this up coming season, and was wondering what motor every one likes the best. I have been running a Novak with LRP TC spec controler. I guess my question is which motor is faster than the Novak?
[COLOR="Magenta"][FONT="Arial"]Schumacher Mi3[/FONT][/COLOR]
[FONT="Arial"][COLOR="Lime"]Jammin X1CR[/COLOR][/FONT]
[COLOR="black"][COLOR="Red"]North Hills Hobbies (601-696-9767) Meridian, MS[/COLOR][/COLOR]
chris72983 is offline   Reply With Quote
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 07:05 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 06:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 09:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 09:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 02:33 AM
