Old 10-25-2007, 10:42 AM   #196
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Skruger View Post
My bad
I should not have used CELSIUS and Fahrenheit in the same responce
your original post just made it seem like you were thermaling at a lower temp. my bad
i have taken my motors up to 190*F ... so im very close to playing with fire.
i noticed during braking with my 13.5 it was as strong as it "used to be".
so my question is.... if you take the rotor to the higher limits of its temp range, will it affect its "braking" abilities?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-25-2007, 10:51 AM   #197
The Evicerator
Most of the time anything electronic runs hot it runs less efficiently than it would at a lower temperature. I would expect to get less brake out of a motor that was 190 degrees than one that was at 110 degrees.
Running your motor right at the temp shut down threshold over prolonged periods of time can cause even sintered rotors to degrade and it might be in your best interest to look into replacing the rotor more regularly or backing down on your gearing so that that those temperatures aren't reached.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 10-25-2007, 02:56 PM   #198
jallshouse's Avatar
Send a message via Yahoo to jallshouse
hey guys....need some help here, i may or may not have a problem with my LRP Vector 13.5 motor. i purchaced and installed the ceramic bearings and the sintered armature and noticed something very odd (but have no experiance with brushless up to this point) when the bonded armature was in the can and installed in the car pinion gear and all, the drivetrain spun so free that i had to hold a finger over the end of the pinion gear to set gear mesh. now with the sintered armature in the motor dosent act this way, when spinning just the shaft it feels like a brushed motor and "jogs" as i turn it and its really hard to turn compared to the bonded one. with everything installed in the car this "jogging" amplifys to the point it feels "gritty" and wont spin free at all......what did i do wrong, or is this normal and the sintered armature just has that much more pull than the bonded one
jallshouse is offline   Reply With Quote
Old 10-25-2007, 02:59 PM   #199
syndr0me's Avatar
Trader Rating: 32 (100%+)
It's normal, the sintered rotors have a lot more magnetic strength, and will "cog" more than the bonded. You'll need to gear it up quite a bit to get the speed out of it since it's got a lot more torque now.
syndr0me is offline   Reply With Quote
Old 10-25-2007, 03:22 PM   #200
jallshouse's Avatar
THANKS!!!! i was really parinoid i screwed something up......i actuailly havent gotten the bonded motor geared right in my 007, its coming off the track at about 200 degrees wether i go up or down a few teeth. guess i will start from scratch now and see where i am at
Old 10-25-2007, 03:30 PM   #201
syndr0me's Avatar
The bonded rotors fade pretty bad each time they get hot. They, as you run them, they get hotter and hotter each time. It's a pretty lame cycle, and the reason nobody likes that rotor. The sintered isn't like that, should run cool, and last a lot, lot longer. My motto is "gear it until it bleeds." I'd start around a 38mm rollout and work your way up until it gets slower, then back off a tooth. Locally, we see them around 40-43mm, but that will vary a bit from motor to motor, track layout, and driving style. Enjoy!
Old 10-25-2007, 03:47 PM   #202
Hebiki's Avatar
thanks steve! ive been running my 13.5 between 150-170. but my first run every race day is usually to figure out gearing. i guess i'll need a new rotor pretty soon.
Hebiki Design Works
Old 10-27-2007, 08:02 PM   #203
Car Breaker's Avatar
my motor after 4th meeting , can I send it for warranty?
Car Breaker is offline   Reply With Quote
Old 10-27-2007, 09:40 PM   #204
AdrianM's Avatar
I am pretty sure that would be a yes. Look like a glue failure (or lack of glue).
Adrian Martinez
Old 10-27-2007, 10:58 PM   #205
snoopyrc's Avatar
Is the Tekin 13.5 released yet? When is that supposed to happen? I would like to see how well it performs.
snoopyrc is offline   Reply With Quote
Old 10-28-2007, 10:03 PM   #206
adamge's Avatar
Experience from this weekend's large regional race: Novak 13.5SS is considerably faster than a tuned stock motor.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-28-2007, 10:11 PM   #207
The Evicerator
Of course!
Fill out a warrantee form and send it on in and we'll get you taken care of!
Steve Weiss
Old 10-28-2007, 10:12 PM   #208
The Evicerator
Well, I don't know... I don't work for Tekin... I work for Novak!
Steve Weiss
Old 10-29-2007, 12:16 AM   #209
RussB's Avatar
Send a message via MSN to RussB
well, this is a 13.5 thread, not a novak thread.
RussB is offline   Reply With Quote
Old 10-29-2007, 12:56 AM   #210
magm20001's Avatar
dont get nasty buddy, we need more company reps here like steve to take care of us.
RIP Kanye West ..... Mom
magm20001 is offline   Reply With Quote
True R/C Lipo bprc10T3 Electric Off-Road 10 03-26-2008 07:05 AM
to true or not to true tyres on club days ?? mrgsr Nitro On-Road 4 08-11-2005 06:11 AM
Is This True???????? Zac R Electric On-Road 24 03-24-2005 09:47 PM
Is this true? doublest Electric On-Road 7 05-14-2003 09:35 AM
Is this true ?????? Brett Australian Racing 9 07-14-2002 02:33 AM
