Tamiya F103 Forum
#1157
http://www.tamiyaclub.com/showroom_m...74886&sid=6590
Kawada and Square both make height adjustable uprights in Alloy,but they bend and break rather easy. I have been running cut down Tamiya uprights for 2 years and havent broke one yet.
#1165
Tires ARRRRG!
1) Anyone remember what the Ride compounds were? If I recall correctly they were the opposite of the Tamiya tires and that A hot tire and B was the cold tire?
2) Anyone try the TRG tires? I see RC Market has some showing in stock.
3) Anyone compare the F10 wheels/tires to the F103? In the pics they look like the same dimensions.
#1166
Same as Tamiya tires as far as hot cold, but the later vers.Ride brand for F103 have grooves.
I have heard they are ok, not as grippy as Ride
The New Ride tires for the 104/F10 are dimensioned for the late model F1, i.e. larger dia front, and larger dia narrow rear.
#1168
F60 body on F103?
Does the F60 body fit the F103? Not sure if the narrow body on the back side will fit of the chassis area where the battery gets installed. Any ideas?
#1169
Lately I have been switching my front tires(foam pre-mounts) from side to side after each qualifing run and main run. Tring to keep them a little closer in size as one side seems to wear down faster,although the coning problem is still there they seem to stay closer in size without having to true them. The rears really dont seem to have this problem as bad maybe just a 1/2mm difference after a few weeks pracitce and racing. Do any of you guys do this or is it just overkill?
#1170
Its best to stick with bodies that are made for the F103.
