Tamiya F103 Forum >
Tamiya F103 Forum
Like Tree9Likes
Tamiya F103 Forum
Old 03-28-2016, 08:35 AM
  #2131
The softer T-bar has an "S" on the bottom as far as I remember.
ixlr8nz is offline
Old 04-10-2016, 10:52 PM
  #2132
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Bring back the wide foam tired F103 with the 540 speed tuned motors. That was fun. Time to dig out the Sauber. Sad UF1 slowly died, yet World GT has devolved into World GT-R, sorta like when Tamiya brought the F103 GT out and not many liked it, but now WGT-R is cool.
1/8 IC Fan is offline
Old 04-25-2016, 11:31 AM
  #2133
Trader Rating: 17 (100%+)
Default TCS Class F-1 rqcing
Is the F103 legal for the TCS Class F-1 series. It looks like you have to use a F104?
Thanks,
a-man1234 is offline
Old 04-25-2016, 12:02 PM
  #2134
1/8 IC Fan's Avatar
Thanks,
Nope F104 only, and rubber
Old 05-17-2016, 10:56 AM
  #2135
Trader Rating: 19 (100%+)
Has anyone tried using the Exotek adjustable arm set (1205) on the F103 to bring the front of the car down to 180mm 0r 190mm?
astgerma52sp is offline
Old 05-17-2016, 12:19 PM
  #2136
NutDriver's Avatar
Trader Rating: 30 (100%+)
Would have to be used in conjunction with the F104 lower arms. Yes, this is common.
NutDriver is offline
Old 05-17-2016, 12:22 PM
  #2137
It's possible to use, but in order to achieve 180, you will need the lower part of the f104 front suspension, and the servo support, as well as the f104 kigpin, because that part is designed to allow more setup options to an original 104 front end
Obviusly, You can use the complete front end of a 104 (direct fit) without the exotek parts.
A better and cleaner option could be the Team Saxo F1-180 front end, direct fit, way better than the Tamiya, and easier to adjust than the front end with the exotek parts
prorace is offline
Old 05-17-2016, 02:31 PM
  #2138
Part number TS-01016-180 Is this the team Saxo front end you're referring to? Is it a complete set with kingpins included?
http://f1shop24.com/shop/product_inf...roducts_id=400
Old 05-17-2016, 02:52 PM
  #2139
Yeah! Even comes with uprigths, a copy of the tamiya 3.5mm offset ones
prorace is offline
Old 05-17-2016, 04:03 PM
  #2140
Thanks! I'll give it a try and post my findings.
Old 05-17-2016, 05:48 PM
  #2141
mtveten's Avatar
Trader Rating: 29 (100%+)
I use frequently use a modified version of the saxo front end my exotek. The stock saxo kingpins are bit soft and there is considerable flex in the upper arm / turnbuckle area. Tamiya kingpins and axles will give the an inline option with increased durability. If you want to reduce the flex to that of most modern cars you can use speed passion kingpins, knuckles, axles and pillow balls to make an easily adjustable front end with a scale appearance that is both sturdy and competitive.
mtveten is offline
Old 05-18-2016, 05:52 AM
  #2142
Thanks for the input. I have spare Tamiya king pins and uprights by (Tuning Haus (TUH1161) and the Tamiya Carbon reinforced uprights that i can switched out. I'm using the F104 turnbuckles now on the car. I'll have to make more changes as needed. The Team saxo front end comes as a complete set and would be easy to plug in. I don't see the speed passion one as a complete front and I would have to purchase individual parts to make it work. I do have an F104 front end but never really liked it. I ordered the team Saxo front yesterday and will post how it comes together and work on the track.
Old 05-18-2016, 07:36 AM
  #2143
I've running mi 103 with the Saxo front end for the las year, and works perfect, in fact in my local track I've winning Xrays and Yokomos with my old and trusty F103.
prorace is offline
Old 05-18-2016, 08:29 AM
  #2144
That's the good feedback i like to hear. I have an Xray x1 '15 but my F103 has always been my best car and I want to use it in competition. I'm excited to see how it comes out. Can you post a picture of your front end with the Team Saxo parts?
Old 05-18-2016, 06:33 PM
  #2145
mtveten's Avatar
I dont know if the speed passion front end is available as a complete set or not but even if it is that would not be the way to go.
In my testing with the saxo front end I found it flexed too much in higher grip carpet conditions resulting in inconsistent handling. I also disliked the idea of being locked into trailing alxes with no other options.
Initially i installed a some reversible tamiya axles I had to get the adjust-ability I wanted and then switched the kingpins out for f104 pins when i bent one.
After struggling on higher grip carpet with the front end flex I found that by using the speed passion knuckles I could get all reduce the flex while retaining the ability to run inline or trailing axles. The speed passion knuckes are sold without the axle insert so you would need both t complete the front axle set and they do reverse like the tamiya ones to run as either trailing or inline. Since the sp-1 uses a pillow ball upper link you will need to use them in conjunction with the 200mm upper arms included with the 180mm saxo front end. Threaded kings are also required since there is no opening at the top for the pin to go through. the added front end rigidity comes from the reduced upper link part count and the larger triangle shape of longer plastic arm. Essential what you end up with is a 180mm version of the crc front end that is all metric with both inline and trailing axle options.
mtveten is offline
