Brushless Motors >
Brushless Motors
Brushless Motors
Old 09-04-2007, 05:09 AM
Default Brushless Motors
Anyone have any basic skimmed down tutorials on these motors? Do you have to maintain them as much as the brush motors? Do they have motors equivalent to 6, 8, 10, 12 turn brush motors? Do they require special speed controllers to operate? Do these motors affect the run time of the car, possibly longer run periods than the brush motors?
Any help would be appreciated, thanks
ddzc is offline
Old 09-04-2007, 05:23 AM
Mitchell's Avatar
Trader Rating: 15 (100%+)
no where near as much maintenance needed. as all motors the faster they go the faster the battery runs out. and yes they require a brushless esc. mamba max are cheapest although they are not roar legal. hope this helps
Mitchell is offline
Old 09-04-2007, 05:41 AM
wfdfiremedic's Avatar
if u go to novak's site they have some info on what turn brushless = brushed turns. For instance 13.5bl = 27 br. the novak 4300 kv motor = 19 turn brushed.
1. not as much maintenance
2. yes, they have equivalents to the lower turned brushed
3. need a special esc that is rated down to the turn of the motor.
4. runtime will increase due to the increased eff of a brushless motor.
wfdfiremedic is offline
Old 09-04-2007, 05:56 AM
stickman310's Avatar
They also have a hell of a lot less resistance and friction than brushed motors so thats one reason why they are more efficient. For one, they don't have the brushes rubbing on the comm.
stickman310 is offline
Old 09-04-2007, 10:20 AM
great, thanks a lot everyone.
ddzc is offline
Old 09-04-2007, 10:35 AM
bxpitbull's Avatar
Also, due to the lack of touching parts, greater efficiency translates to more torque and rpms...slight gearing changes can make a torque'ey motor into a high revving beast. Subtle gear changes like that gives you a much broader rsetting ange depending on track type and conditions.
bxpitbull is offline
Old 09-04-2007, 10:55 AM
vtl1180ny's Avatar
The search button is your friend....
vtl1180ny is offline
Old 09-04-2007, 11:01 AM
bxpitbull's Avatar
doh
