Old 05-10-2003, 05:38 PM   #1
dux
Default Help me set up an RS4 Rally for onroad
Hi,
I'm converting my RS4 rally into a pavement machine, what size shocks should I get and what are some good spring/oil setups? Thanks!
dux is offline   Reply With Quote
Old 05-10-2003, 08:14 PM   #2
popsracer's Avatar
dux;
you will need the Shock towers from the Electric Sport and the 45-56mm Shocks. Other than that, it's just a matter of adjusting ride height, etc for On-road.
Visit the HPI website for some set-up advice for your specific Car.
popsracer is offline   Reply With Quote
Old 05-10-2003, 09:55 PM   #3
You don't need the shock towers, just the shorter shocks. I had good results with my RS4 pro, unprepared asphalt, with 40 wt oil, #3 pistons, and blue pro linear springs all around. Red inserts are the best all around and some 27-33r's for summertime depending on your climate.
Savage26 is offline   Reply With Quote
Old 05-10-2003, 10:28 PM   #4
dux
Thanks Savage, that'll get me started in the right direction.
Old 05-10-2003, 10:46 PM   #5
dux
Oh, and would you happen to know how to adjust rear toe out? Is it an A-arm replacement or a spacer thing or what?
Old 05-11-2003, 09:14 AM   #6
Regional Moderator
Addict sa RC's Avatar
To change the rear toe out you would need to buy different rear hubs (1/2 deg and 1 deg are available and only in aluminum) and replace the stock rear hubs.
Addict sa RC is offline   Reply With Quote
Old 05-11-2003, 02:02 PM   #7
Cole Trickle's Avatar
Besides the shorter shocks, you'll also need springs in proper length.
I'm pretty sure the standard rear toe-in is 2 degrees. That should be fine for many circumstances.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
losi rally weapon or hpi rs4 rally ? guss Rookie Zone 9 11-13-2010 08:19 PM
WTB: HPI RS4 Rally or any of these rally cars Shrike R/C Items: Wanted to Buy 0 12-01-2006 03:34 PM
tc3 rally arms/rally kit Zac R R/C Items: Wanted to Buy 3 09-18-2005 06:46 AM
TC3 Rally (and rally in general as well) NOSaholic Electric Off-Road 19 10-13-2004 10:33 AM
Tamiya TG10 Rally/ONRoad NitroLuver Nitro On-Road 1 11-29-2001 05:15 PM
