Novak Millenium charger questions >
Old 05-23-2003, 12:55 PM
  #31
Registered User
Calvin Ng's Avatar
do you k now how long they will last at 6.5 amps?
Calvin Ng is offline
Old 05-24-2003, 05:33 PM
  #32
yeap on my millenium i have to set 6mv/cell (30mv/pack) bc sometimes it will fasle peak but my pulsar can peak it at 25mv/ pack
At 6.5 compared to 5 amps charging it will probably be with 20-30 secs runtime difference.
Johnnytc3 is offline
Old 05-24-2003, 07:19 PM
  #33
Duratrax makes a power supply for only like 60 or 70 bucks. I think it has a 7 amp output or something. Would this work for the Millenium pro? Could I charge at the 6 amps that I want to? One more thing, does the Millenium pro have a motor break in feature?
racerdx6 is offline
Old 05-24-2003, 07:21 PM
  #34
nope the millenium does not have a break in feature, you should be able to charge at 6 amps with that power supply i wouldnt push it over 6 though.
Old 05-25-2003, 09:38 AM
  #35
I currently have a Novak Millenium v1.2 is it worth it to spend the extra dough to upgrade my charger to the millenium pro?
I do not need the Pit Wizard function of the charger...its just that I am wondering if it is actually a better charger as well.
Thanks!
Hammer0412 is offline
  #36
MX5
On the original question just go to ebay search for "power supply". I've seen 12 amp supplies for 30 bucks shipped.
MX5 is offline
Old 05-25-2003, 09:48 AM
  #37
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally posted by Calvin Ng
i didnt get it yet.
i just ordered one its comming
is there a risk screwing it up
what does the upgrade do
I don't even know what the heck you guys are talking about...the Millenium has been discontinued for over a year...
the Millenium PRO has the Mimh2 setting...you cant even set voltage threshhold on it......
calvin,don't worry..the upgraded versions have been out for a year......I have a version 2 and 3(bith purchased last year)..both are fine for GP 3300's....
fastharry™ is offline
Old 05-25-2003, 05:37 PM
  #38
Registered User
Calvin Ng's Avatar
were talking about the pro
Old 05-25-2003, 11:05 PM
  #39
glide 1's Avatar
Default Fastharry,
I've seen people use the "linear charge" setting on the 1.2v millenium (with threashold settings set to minimum) to charge the new GP3300 and they say it is ok (have doubts).
What i want to know is, what voltage threashold setting is recommended and if it really is ok for the packs....anyone?
glide 1 is offline
Old 05-26-2003, 12:16 AM
  #40
For Nimh packs I think you want the voltage threshold setting as low as possible. Not sure about Nicd voltage threshold setting though......
racerdx6 is offline
Old 05-26-2003, 12:22 AM
  #41
WC
WC's Avatar
Trader Rating: 28 (100%+)
Originally posted by Devin
I punch my gp3300's @6.5V with 5mV or .030/6 cell pack. I get great results and peak them 5 minutes before the race and run them hot than cool after the race is over.
Novak's manual (Mill Pro) recommends that NiMH should not be repeaked after charging.
WC is offline
Old 05-26-2003, 12:26 AM
  #42
WC
WC's Avatar
Nicad threshold depends on your cell's characteristics... usually I run 15-18mV/cell for the older less-matched (haha) packs and 12-15mV for the newer packs in better condition.
Lower threshold voltage invites more chance of false-peaking, but that's the name of the game. Less drop = less overcharging = less damage but you want all 6 cells to have peaked too, not just 3.
I get less falsepeaks with "linear" vs "reverse pulse".
WC is offline
Old 05-26-2003, 02:03 AM
  #43
Super Moderator
Grizzbob's Avatar
Just to help clear things up some, I do use an original Millenium(not a Pro) version 1.20, & I do use the Linear NiCd charge mode for my NiMh cells, including my packs of GP3300's. I've used everything from a 5mV per cell to a 9mV per cell threshold, & I've seen no problems that way(I've seen SMC actually recommend using a 9mV threshold, that's when I first tried it). The packs get just a bit warm, just like you'd want(not too hot & not cold) & they run just fine on track. What's also nice is that a 9mV threshold also works well for Sanyo 3000HV's(which I still have some packs of), so I don't have to change it over to do any of my NiMh packs....
Grizzbob is offline
Old 05-26-2003, 06:03 AM
  #44
fastharry™'s Avatar
well,if we're talking about the PRO,how are you setting threshhold on a charger that doesn't use it...the only way is to use the STANDARD Ni cad settings to charge Nimh.....but that(even with the peak detection set right) is not as accurate as the NiMH2 settings that DON"T use voltage threshold to determine when the charge is done...
Old 05-26-2003, 06:06 AM
  #45
fastharry™'s Avatar
Default Re: Fastharry,
are you talking about the PRO charger or the old one.....
