Novak Millenium charger questions
#17
i didnt get it yet.
i just ordered one its comming
is there a risk screwing it up
what does the upgrade do
#19
oh so you have to send it in
i thought you ment you phone them and they'll tell you what to do to the charger
#21
whats threshold and whats mv
#22
What is PEAK DETECTION?
When batteries reach a fully charged condition, the pack's voltage begins to drop. A charger that uses peak-detection senses this drop in voltage and changes from a high rate of charge to a trickle charge (or off in the pulse mode). Digital peak detection is more accurate than analog peak detection.
when you charge a battery pack, once it starts to peak , the voltage will start to drop (NicD more than Nimh). As the voltage drops the charger will sense that and terminate the charger according to the threshold you set it at.
#24
why would you want the voltage to drop?
#26
so if i were to charge 3300's (gp's and sanyo's)
what would you put all the settings at
#28
no problems???
i guesss thats how i'll set mine
by the way thanx a bunch
