Old 05-10-2003, 01:40 PM   #1
Suspended
subaru impreza's Avatar
Default steerin
is my steerin broke cause it only steers one way and thats it ive got the steerin aline ment right though
subaru impreza is offline   Reply With Quote
Old 05-10-2003, 03:08 PM   #2
First of all you need to make sure your servo is centered properly. When you center your steering servo you need to make sure that your steering trim is at nuetrul (spelling? ). Check your car to make sure there's no debris that's blocking it, in the tc3 debris can easily get in the sliding thingy (I forgot what it was called ). I would also check your radio to make sure your steering endpoints are set correctly, if your radio has this adjustment. What kind of radio do you use? I hope this helps!
racerdx6 is offline   Reply With Quote
Old 05-11-2003, 03:42 AM   #3
Suspended
its kinda like this in the atachment
Old 05-11-2003, 11:31 AM   #4
Suspended
treid all that and it still the same
Old 05-11-2003, 11:48 AM   #5
popsracer's Avatar
Default One-way Steering
subaru impreza;
A common problem is a Mis-matched Servo Saver. The splines on the Servo and Saver MUST match exactly or they can slip and cause the problem you describe. Make sure the servo saver is TIGHT on the Servo spines and NOT slipping.
popsracer is offline   Reply With Quote
Old 05-13-2003, 11:54 PM   #6
Suspended
thanxs pops works now
Old 05-14-2003, 03:09 PM   #7
rough512's Avatar
and now, the show begins....
rough512 is offline   Reply With Quote
steerin linkage tmaxx 2.5 deimus Monster Trucks 0 04-09-2007 04:58 PM
