which servo's are the best for tc >
Old 11-28-2007, 05:09 AM
nitro neil's Avatar
Trader Rating: 84 (100%+)
Default which servo's are the best for tc
i'm in the market for a new servo and was wondering what the high end servos guys are using and what they like about them and maybe some specs. thanks for your input
nitro neil is offline
Old 11-28-2007, 05:12 AM
sosidge's Avatar
I use Futaba and have been very happy with the S9550 and S9451.
sosidge is offline
Old 11-28-2007, 05:32 AM
nitro neil's Avatar
cool i will look up the specs hopefully i get more response
Old 11-28-2007, 05:33 AM
PitNamedGordie's Avatar
The s9950 has been the perfect servo for me. It's being updated and the new one is the S9551.
PitNamedGordie is offline
Old 11-28-2007, 05:49 AM
1fastdude's Avatar
Trader Rating: 16 (100%+)
For touring car electric I would recommend a JR 9100S servo.
specs are as follows:
Torque = 150 oz/in @ 4.8V, 180 oz/in @ 6V
Speed = .08 sec /60 degrees @ 4.8V .06 sec / 60 degrees @ 6V
Weight = 2.3 oz.
Coreless - Metal Gears - Digital
http://www.horizonhobby.com/Products...dID=JRPSZ9100S
1fastdude is offline
Old 11-28-2007, 05:53 AM
I'm using a Hitec HS-5965MG. Not high-end as far as price goes, but plenty fast enough for me. Some of the guys are using high-end KO servos, but they tell me that they turn the rate down as they they are too fast?
I've stuck with Hitec as I've never broken one. I used to use their 645 servos, and they took some serious abuse without complaint. Bit slow for carpet racing, though.
clockworks is offline
Old 11-28-2007, 06:01 AM
nitro neil's Avatar
currently i have a 9000s in my car and it was just sent back to me from repair unfortunately it needs to go back and get re repaired. it shakes back and forth. it did this prior to sending it in in another car with diffrent radio equipment.I changed the reciever and actually took servo out of the car to make sure it was the servo. i moved all wires away from each other and nothing worked. so i figured i should just get something new send the old one in and when it gets back test it and use it as a back up. A 9100s is definately on the list, but i'm still looking to see what is out there in the high end range
Old 11-28-2007, 09:06 AM
Futaba 9550, 9551. I prefer the new brushless servo from futaba, the BLS451.
adamliehr is offline
Old 11-28-2007, 09:09 AM
gansei's Avatar
PDS-2413ICS [LOW PROFILE]
torque: 8.5kg-cm
speed: 0.10s/60'
i ordered it..
gansei is offline
Old 11-28-2007, 09:11 AM
Trader Rating: 23 (100%+)
I have a Futaba S9550 and a Futaba S9451. Both are great but I like the
S9451 a little bit better. A little faster and stronger. It really turns fast and holds the line thru the turn awesome. IMO.
martman_oc is offline
Old 11-28-2007, 10:07 AM
sportpak's Avatar
Trader Rating: 26 (100%+)
Futaba BLS451....brushless baby.
sportpak is offline
Old 11-28-2007, 10:54 AM
Skiddins's Avatar
You can never go wrong with a KO.
I currently have some 2123's (7.2V) which are very fast.
I also have couple of 2413's as mentioned above (for my 5cell car)
Skiddins
Skiddins is offline
Old 11-28-2007, 11:22 AM
RC MARKET's Avatar
KO PROPO
PDS-2413 ICS Low Profile Servo
or after Futaba S9551
www.rcmarket.com.hk
RC MARKET is offline
Old 11-28-2007, 12:47 PM
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Those are great servos. I use 2 in my Losi 8 and 1 in my TC5. Not that I am a fanboy, but I like to stick with 1 servo so that I know the feel just a bit better.
rezenclowd3 is offline
Old 11-28-2007, 01:04 PM
stanislow's Avatar
9550 digital servo is the best for me
even for nitro
stanislow is offline
