motor, esc and battery temp >
Old 09-03-2007, 06:34 AM
diozxlive's Avatar
Default motor, esc and battery temp
i just bought a temp gun and wondering what are the maximum temperatures that i should watch out for in my esc, motor and battery in celcius and/or f. thanks....
diozxlive is offline
Old 09-04-2007, 01:30 AM
diozxlive's Avatar
Any info?
Old 09-04-2007, 01:40 AM
bxpitbull's Avatar
To get that info, you need to list what type of motor, esc, car, applications, gearing, where you live and what type of temperature, type of cells or pack, heatsink with or without a fan.....
bxpitbull is offline
Old 09-04-2007, 02:03 AM
grizzle's Avatar
Location: Filipino Contract Worker in Khobar, Saudi Arabia
Hi diozxlive... If you can't find the maximum temp for your esc, motor or battery from the manufacturers spec's. Try to list the equipment that you have and you might get some answers from the people that have already experience using them. Somebody might have a safe limit for the temperatures so the equipments will continue to perform to its capacity. Cheers
grizzle is offline
Old 09-04-2007, 04:17 AM
I know a lot of the novaks are made to go a max of 160 but without more info...blah blah blah see above posts.
jsl6v8 is offline
Old 09-04-2007, 05:27 AM
diozxlive's Avatar
thanks guys... i got 27turn fantom motor, futaba mc330 esc and IB 4200 side by side batteries... got the temp sensor but just don't know what max temp to watch for before i burn something...thanks...
Old 09-04-2007, 07:13 AM
bxpitbull's Avatar
It may be bla blah blah to some, but the more information you can provide, the more detailed your answer will be.
Old 09-04-2007, 08:17 AM
I didn't mean it to be disrespectful or to say the information was unimportant merely didn't want to state the exact same thing again that the 4 post before me did, didn't figure it would be helpful at that point.
jsl6v8 is offline
Old 09-04-2007, 08:27 AM
Trader Rating: 27 (100%+)
Stock motors can go up to 210F. At 230F they start to smell burnt and have a short life. There is no need to run them this hot unless the weather is Houston hot. Speed controls can go up to about 180 F. Brushless motors have about this same limit. The Novak brushless will thermal at 180F. They will stand more than this with a sintered armature.
John
John Stranahan is offline
Old 09-04-2007, 09:35 AM
bxpitbull's Avatar
OhI got a lil offended because I do get a bit long winded lol. It's cool.
Old 09-04-2007, 10:11 PM
diozxlive's Avatar
Default re
John
thanks John, Im here in Saudi Arabia so outside temp is bit more than what you have in texas... thanks...
