Old 05-10-2003, 04:02 AM   #1
davioh's Avatar
Default good rubber tires
what are some good rubber tires for a fairly hot track. i have had shimizu's which seem to last forever at home. for the track i've used hpi 35r's which are pretty nice. what do you guys recommend?
davioh is offline   Reply With Quote
Old 05-10-2003, 04:20 AM   #2
TWiZTiD's Avatar
the take off range is very good and cheap 27 or harder would be best with standend
TWiZTiD is offline   Reply With Quote
Old 05-10-2003, 04:30 AM   #3
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
shimizu's yes, very good tires.
Take Off CS(cheap sh!t) 27, very nice and it come pre-glued.
Sorex 36R, is probably the best of all.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 05-10-2003, 04:35 AM   #4
davioh's Avatar
in hk sorex and shimizu are the same price...what about they type a slicks? they any good?
Old 05-10-2003, 04:36 AM   #5
davioh's Avatar
and i hav a set of 36r's but i haven't tried them. i ultimatley havto get some tamiya tires for the asia cup. which tamiya one should i get?
Old 05-10-2003, 04:39 AM   #6
TWiZTiD's Avatar
type A's are the ones to go for
Old 05-10-2003, 04:50 AM   #7
fatdoggy's Avatar
R/C Tech Charter Subscriber
I've been running sorex 32R's, at first I though OMG they wear sooo fast, but it was my setup(it sucked). Once I found a decient setup they started wearing fine. So far my Rears are still going strong at 12+ battery packs. I bought some 36R's for the front on thursday, and will try them out today. The front 32's were so worn I could see the belts. Try out your 36's, the chances are you'll like them.
fatdoggy is offline   Reply With Quote
Old 05-10-2003, 05:14 AM   #8
davioh's Avatar
i'll probably get to the track next week, tommrow is mothers day. so i guess my best chance is next week. how do different setup's effect how fast the tires wear down?
Old 05-10-2003, 05:26 AM   #9
fatdoggy's Avatar
If you have too much camber the inside of the tyre will wear quicker, I was running 32's that are pretty soft so in a few runs(with a bad setup) I'd caused the tyres to wear a heap on the inside and nearly not at all on the outside. The result was a major groove on the inside of the front tyres. This was at stupid camber angles because my first two races I basically did zero tuning. It was not the tyre, just my inexperience with setup.
Old 05-10-2003, 07:06 AM   #10
TWiZTiD's Avatar
having to much grip wears tyres fast I run stock and at a worm up last week I used 2 and half sets of take off cs27's control tyres in 8 runs but the cars was fast so I did care
Old 05-10-2003, 08:37 AM   #11
b_budianto's Avatar
I think sorex 36's is the best for warm weather and take off 27 is best for colder weather
b_budianto is offline   Reply With Quote
Old 05-11-2003, 04:54 AM   #12
TWiZTiD's Avatar
it was only a 19 deg day but its a control tyre for the vics so i had to prac in with them
Old 05-11-2003, 05:12 AM   #13
davioh's Avatar
i got the sorex 36r's and the type a's...sorex in my opinion is so much better!
i need a good rubber setup for tc4 ft Carpetracer92 Electric On-Road 1 01-20-2008 04:02 PM
What's a tire truer? And who makes good rubber tires for asphalt? Prozak Rookie Zone 3 10-15-2006 01:53 AM
What rubber tire and inserts would be good for ozite? Superfly1967 Electric On-Road 3 03-17-2006 08:23 AM
Take-Off CS27 tires plus other rubber tires Scottrik R/C Items: For Sale/Trade 4 12-20-2005 10:23 AM
What rubber tires are working good on carpet THE GOOCH Electric On-Road 21 11-04-2005 12:28 PM
