Old 12-06-2001, 02:39 AM   #1
xray's Avatar
Cool M8, EX-1 or 3PJ-S
I am using KO Mars EX-1 now. In the past I have used Futaba 3PJ S.
During all this time I am not to worry about what radio I am using.
Both radio seems ok, until one day I try my friend's sanwa M8.
It is heavy, but I found the throtle as well as the steering wheel has more feel.
Should I buy the radio?? any opinion??
xray is offline   Reply With Quote
Old 12-06-2001, 06:32 AM   #2
RacerTex's Avatar
I have a Mars and a Mars LE. I love that radio. My brother has a Mars LE and and M8. I've used his M8 before and I understand what you are saying. The M8 is a great radio. If you can swing it, why not own both?
RacerTex is offline   Reply With Quote
Old 12-06-2001, 07:16 AM   #3
Regional Moderator
disaster999's Avatar
i heard a lot of people say that M8 is the best out of Mars and 3PJS...i have the 3PJ because its cheap (second hand) if i would choose...i think ill get the M8
disaster999 is offline   Reply With Quote
Old 12-06-2001, 07:29 AM   #4
xray's Avatar
Thanks for the info guys!!
I just wondering how you guys hold the steering wheel? are you using 3 or 4 finger?? I heard it is more consistent using 3 finger! any info?
Old 12-06-2001, 08:39 AM   #5
Had to try to figure out..it's kinda one of those things you don't think about....but-
with my KO Mars 3x-1 I only use 2 fingers, due to the fact that there isn't alot on tension on the wheel (which I believe makes the radio feel better (more responsive) to me) This would also make the radio better for long mains, I have seen people finish racing with cramps in there fingers due to tight wheels.
With my dad's and brothers Futaba 2pk radios I know I have to use a gorrilla grip 4 fingers....
My wife also likes the feel of my KO better, because she has small fingers
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-06-2001, 08:44 AM   #6
Trader Rating: 35 (100%+)
It's all about what feels good to you. One thing that you should be aware of is that the M8 (probably others) has adjustable wheel tension. Using a 2mm hex driver, you can adjust a recessed screw located behind the wheel and under the main body of the radio.
Geppetto is offline   Reply With Quote
Old 12-06-2001, 09:45 AM   #7
Corse-R's Avatar
I'm use only 3 fingers to drive. Using 4 fingers forces a position in the hand that is ok for a 4 or 5 minute heat, but if you plan to drive long time can be painful.
Use 3 or 4 fingers, depending on what you feels more comfortable.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-06-2001, 05:25 PM   #8
xray's Avatar
Geppetto, you can adjust the steering wheel tension on Futaba 3PJ S, however you cannot adjust it on KO EX-1.
My KO is the LE, which I believe it has softer tension than the regular EX-1.
I still find it too hard though!! therefore I have changed the original spring with the softer one.
Old 12-06-2001, 07:50 PM   #9
MissX's Avatar
I use M8, and have tried KO LE. I think they are about the same feel, but M8 break is better to me. M8 can be accessed faster because it has a bigger LCD.
MissX is offline   Reply With Quote
Old 12-06-2001, 09:40 PM   #10
One advantage of the 3PJS.....PCM!
I can run motors WITHOUT capacitors.......if so inclined.
acloco is offline   Reply With Quote
Old 12-06-2001, 09:57 PM   #11
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
The M8 is great, I would recomend it to anyone. It has twice as many options as you'll ever need, is comfortable, and looks cool! I use three fingers to hold the wheel, I experimented from 2 to 5, and arrived on 3. I also have the steering wheel tension set fairly tight. I feel this makes it feel smoother to drive. You can adjust the tension with a 1.5mm driver.
Speedo is offline   Reply With Quote
Old 12-07-2001, 12:10 AM   #12
MissX's Avatar
Does anyone know how to fix "FATAL ERROR" on M8?
I got into its programming menu to access the ABL and batt, and accidentally pressed DATA CLEAR. When it's turned on again, it said "FATAL ERROR".
I have fixed the M8 by sending it to the factory.
A friend said there were buttons to press to restore it's stage. It's very easy and fast, but the factory did not want to tell.
Old 12-07-2001, 02:00 AM   #13
Manticore's Avatar
wow, i didnt know that until you tell us about it ! I know the earlier generation of Sanwa pistol TX has this function but I didnt aware of it with my M8.
Manticore is offline   Reply With Quote
Old 12-07-2001, 06:11 PM   #14
what other features do m8s include
was ist los? is offline   Reply With Quote
Old 12-07-2001, 09:09 PM   #15
Moderator
Speedo's Avatar
Dual rate, EXP (Steering and throttle), 10 model memory, EPA (of course), And a whole bunch of other stuff, can't remember it all right now though.
