motor fans
Old 08-26-2007, 05:35 PM
Default motor fans
looking for a nice fan setup for my mamba max
Im looking at either 2 x 25mm wired to esc
OR
1 x 40mm wired to rx.
I plan to use the team tamale clamp on fan mount for the 25mm fans, where with the 40mm fan ill just zip-tie to the upper frame of my chassis.
Is there a specific brands out there that offers the best performing fan, or are any brand fans adequate for this type of application. Thanks in advance...
Drift Demon is offline
Old 08-26-2007, 05:58 PM
Default Fans
I got two tamale fan mounts, they work great. I've tried a few different fans and the ones that I found to push the most air are the Novak fans, they are expensive, but they are the best my LHS had, it would be nice to get a bunch of opinions here, I'm sure there are stronger fans out there.
_pilot_ is offline
Old 08-26-2007, 06:11 PM
I have not tried the novak fans but I have noticed my Muchmore fans work pretty well. Do not use 3-racing fans as they get affected by the motor (when using a brushed motor anyway) and will slow right down near the magnets.
Mike
ixlr8nz is offline
Old 08-26-2007, 07:33 PM
Here are a few sources for fans that work really well. I use ones from the first link. At 3.5 cfm at 5 volts, these move more air air than most any other fan. Hook them up straight to 7.2 volts and they really move some air.
http://www.eagepc.com/product_detail...id=283&id=9944
http://parts.digikey.com/1/parts/436...pev18-ngn.html
This one has a metal case.
http://www.laptoprepairparts.com/htm...6&category=fan
teamtamale is offline
Old 08-27-2007, 07:38 AM
KoE
KoE's Avatar
i have mine hardwired to batt pack so that the fan can continue cooling down the motor while i turn marshall. I also put on a voltage regulator after frying up a brand new MM fan before end of race day
KoE is offline
Old 08-27-2007, 05:27 PM
thats interesting.... so far I haven't had any problems with running directly off the battery with mm fans.
Mike
ixlr8nz is offline
Old 08-27-2007, 06:19 PM
for a 40mm fan i have been looking at this one, & for 2 x 25mm fans i was thinking either the much mores or the novaks...
Old 08-27-2007, 08:45 PM
more$thanbrains's Avatar
much more fans puch more air than the novak ones and they usually are about $15 cheaper
just IMO
more$thanbrains is offline
