Maximum Punch!
Old 08-26-2007, 02:18 PM
Default Maximum Punch!
Battery bars or Braid? For maximum punch!
also
Does it make a difference with brands?
Thoughts?
Jeremy Otis is offline
Old 08-26-2007, 09:16 PM
gubbs3's Avatar
I think the biggest benefit is simply doing a good job soldering. Poor solder joints will rob more power than any of the wires or bars you use.
gubbs3 is offline
Old 08-26-2007, 09:30 PM
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Yup!
That is very true!
BlackedOutREVO is offline
Old 08-26-2007, 09:40 PM
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 93 (100%+)
Use paperclips..
BSchorr is offline
Old 08-27-2007, 06:10 AM
Scrubb's Avatar
Originally Posted by BSchorr View Post
Use paperclips..
with good solder joints...
Scrubb is offline
Old 08-27-2007, 06:34 PM
Trader Rating: 72 (100%+)
The pink ones...
patrick is offline
Old 08-27-2007, 06:50 PM
killingtime's Avatar
... unbent and stretched across all the cells, connect your pos and neg to the last cell and your ready to go. It makes your car much cleaner looking.
____________ +
___________ -
killingtime is offline
Old 08-28-2007, 04:56 AM
BigPapa's Avatar
____________ +
___________ -
Send me a pic on how that looks?...... I can not imagine it
BigPapa is offline
Old 08-28-2007, 05:19 AM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
The way I used to do mine was to start gluing the weakest battery from the negative end all the way up to the positive with CA.
I would say in order cut back on connections you would need one wire from neg. to motor, and one wire from pos. to battery and then to motor. You easily store them wired like that with an antenna straw cap, but you have to be careful with positive wire where its bared for the battery.
And keep the wires as short as possible. I would keep in mind that the shorter the wire the less heat it can handle. If running mod a little longer wire is a good thing.
Proper scuffing to prep the batteries for solder is the key to good soldering joints.
Brings back some memories.
UN4RACING is offline
Old 08-28-2007, 04:53 PM
Trader Rating: 14 (100%+)
Jeremy:
Hi,
I'd go with bars. so far they have worked great.
also you have a PM
TimXLB is offline
