Comm lathes are for Sissies!!!
#16
when i was a kid and couldn't afford a lathe, i used to use Brasso on a rag to clean my comms.
#17
#18
I guarantee if you cut a motor using this "method" and dyno it, then cut it properly and dyno it again you'll see a substantial performance difference. Using a comm lathe does more than just "make the comm shiny". It might work for the basher or casual club racer, but for serious racing there is only one way to cut a motor.
#21
If you are very careful and apply just the right amount of pressure utalizing the sandpaper you can make the com perfectly round!
#22
#23
Wow is that an unsafe act.This thread should be removed before a kid or someone gets hurt!
#25
For those of us that don't have a comm lathe.....what is the best way to maintain a comm in between cuts? I have been using a metal polish and drill to take some of the black stuff off the comm and make it shiny again. Is this stupid? I also try to use motor spray after each run.
thanks
thanks
#26
That kind of advice is irresponsible !!!
Hope you wearing eye/face protection before something bad happens.
I aggree it should be deleted !!!
#28
weak weak..not getto enough. get a walmart AA drill and do it. then you
get the VALUE! lol
your dwalt drill costs more than a comm lathe.
get the VALUE! lol
#30
I don't mean to offend you and it is not an attack on you,I'm just concerned that a young fellow rc enthusiast might get hurt.
