Old 05-08-2003, 12:30 PM   #1
omalley's Avatar
Send a message via AIM to omalley
Exclamation Foam Tire Size
Looking at getting some data here on foam wheels:
When you true your tires, what millimeter are you truing too?
60mm?
50mm?
Etc.............
What surface are you primarily running those trued foams on?
Concrete?
Carpet?
Asphalt?
omalley is offline   Reply With Quote
Old 05-08-2003, 12:34 PM   #2
tufferwilde's Avatar
Carpet - plaid front/ purple rear trued to 58mm
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 05-08-2003, 01:13 PM   #3
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I found good sucess with a variety of compounds, double purple, purple, red, magenta and plaids are my most common. I true down the first time to 60 mm. I use this rule for indoor carpet and also electric and nitro asphalt.
John Fontaine is offline   Reply With Quote
Old 05-08-2003, 02:20 PM   #4
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
For Carpet - Plaid/Purple, 60-61 mm for club racing
For big races or if you want the usual best tire size 58 mm is just about right. I'd go about 60 mm though because then you get more life out of them...but they are easier to chunk that way...so don't hit too much.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-08-2003, 03:12 PM   #5
for stock i usually start with 59-60mm for stock and retrue them in between racedays. for mod i will usually start with 56-57mm area. this is for carpet only.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 05-09-2003, 07:56 AM   #6
kevin2's Avatar
Send a message via AIM to kevin2
Default foam tires
Im running plaid in the front and purple in the back with 60mm.
kevin2 is offline   Reply With Quote
Old 05-09-2003, 08:03 AM   #7
kevin2's Avatar
for carpet in the back 30 mm in the front 26mm
Old 05-09-2003, 08:13 AM   #8
omalley's Avatar
excellent information.. keep it coming
Old 05-09-2003, 08:53 AM   #9
I actually go 59.5mm..... why the 1/2 mm??? Hell I don't know I think I saw it on a T. Hodge, or M. Francis set-up sheet once and now it's etched into my brain...LOL
You where talking touring tires right??? Cause 1/12th scale and pro 10 would be way different!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-12-2003, 05:44 AM   #10
omalley's Avatar
yep, meaning 1/10 on-road touring cars only
Old 05-12-2003, 12:51 PM   #11
What kind of foam is a good starting point for ashpalt?
rcpilot is offline   Reply With Quote
Old 05-12-2003, 02:05 PM   #12
Plaid or Double Purple fronts
Purple rears
Size of hex on foam wheel? andy85 Electric On-Road 2 06-28-2008 01:29 PM
Foam Tire Size brianzippy Electric On-Road 5 09-19-2005 07:28 PM
Foam tire size? mtc3od Electric On-Road 7 10-21-2004 07:15 PM
What foam tire brand and size should I use? NITRO LUDE Nitro On-Road 4 06-29-2004 09:46 PM
*What size foam tires fit onto my car?* quBsee Nitro On-Road 3 02-18-2003 09:30 PM
