Old 09-09-2007, 11:32 PM   #31
Trader Rating: 27 (100%+)
I bought a Hakko 918. Pretty simple and does a great job.
JoeyE is offline   Reply With Quote
Old 09-09-2007, 11:33 PM   #32
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by odpurple View Post
The Hakko 936 is a good choice, but if you want to do good work on cirquit boards you wll want a small tip, like 2mm. You can get two irons for the station and switch them but the best way to go is the Hakko 928 dual soldering station. Then you can have a large handle and tip that will work for everything but batteries, and the teenie tip for cirquit board work. You can solder batteries with the 928 but its better done with a 456. 455 works great too but the 456 shows no mercy
Thats getting pretty spendy though
I use a 60 watt iron right now, I think 50 would be perfect
But I dont know, I dont do circuit work as I always screw something up, and then burn it out lol
Just soldering batt's, and Soldering the wire to my batts before each race
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-09-2007, 11:40 PM   #33
R/C Tech Founder
R/C Tech Charter Subscriber
As an (expensive) alternative to the Hakko line, there's also the Weller:
http://www.ampdraw.com/product.php?a...productid=3167
Or even a digital Weller:
http://www.ampdraw.com/product.php?a...productid=3166
I bought the regular, non-digital Weller from Superior at the 2004 Snowbirds, and man, that was probably the single best RC purchase I ever made. Small footprint, lightweight, easily replaceable tips (that are sold everywhere, including Home Depot and Fry's), heats up practically instantly. I love it.
The Hakko is also a good choice though, as many have said. I see the Hakko in more hobby shops around although I dunno what the tip availability is like. We used Hakko stations at XRC and they always got the job done (except for Derek's old beat-up Hakko that he must have left running for months at a time...)
In any case, going from an el-cheapo throwaway iron to a nice adjustable model like any of these is seriously one of the single best things you can do for yourself as an electric racer. Highly, highly recommended.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 09-09-2007, 11:45 PM   #34
odpurple's Avatar
The reason you screw cirquit board work up is because you use too big an iron. I used to do the delicate work with a big iron by using the corner of the iron tip, that takes too much skill. With the small tip I can do anything!
If all you are ever going to do is solder batteries together and into the car a Hakko 455 will do you just fine, forget about the stations.
odpurple is offline   Reply With Quote
Old 09-10-2007, 02:04 PM   #35
No, I have tried a 40 watt with a small-ish tip
Nothing as small as some I have seen at my track though, that really kills stuff? Just tip size?
WOW, those weller's are SPENDY
Hakko for me, I need one, but no money right now lol
Old 09-10-2007, 03:11 PM   #36
odpurple's Avatar
With a big tip you heat up too large an area, a small tip just puts the heat where you want the solder joint. I'm not talking about soldering big wires for the motor, etc on the speed control, but switch wires or wires inside the servo, esc, rec. For that, small is good
Old 09-10-2007, 08:09 PM   #37
OD ever solder a FET on a mini Z board?
Sydewynder is offline   Reply With Quote
Old 09-10-2007, 08:10 PM   #38
You can order Hakko tips directly from Hakko
Old 09-10-2007, 08:24 PM   #39
Makes sense
Old 09-10-2007, 08:43 PM   #40
Blisster's Avatar
I've been through a couple of crappy irons that were nothing but trouble when it came to soldering batts and leads, I just picked up a $20.00 weller 40W iron with a chisel tip and it works beautifully. It's nice and light, packs up small and gets to 900F
WCERacing.com for R/C videos, news and more!
CRC T-Fource
AE TC5
CEN Matrix C-1 FRE
Blisster is offline   Reply With Quote
Old 09-10-2007, 09:02 PM   #41
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Now thats a soldering iron...
12 years and have been threw 3. Never had one go bad, its always been my fault for it going bad.
UN4RACING is offline   Reply With Quote
Old 09-10-2007, 10:24 PM   #42
Blisster's Avatar
yeah, the Hakko 936's and the higher end station type irons are nice for sure, but I'd rather spend the extra 60-80 on a servo, tires, a-arms, whatever, and this thing does everything I need a soldering iron to do.
CRC T-Fource
AE TC5
CEN Matrix C-1 FRE
Old 09-10-2007, 11:37 PM   #43
odpurple's Avatar
No, but that never stopped me before
Old 09-11-2007, 06:51 AM   #44
timmay70's Avatar
Back in the early 90's I used to make money at the local track replacing brake fets in Novak 4s and T4s. Went right to the local electronics parts supplier and bought the fets by the dozen. I'd go to an oval race and sell out. Who needs brakes in oval? Never stopped people from wanting them replaced, though.. It was a quick way to make my race entry back.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 09-11-2007, 05:34 PM   #45
Trader Rating: 44 (100%+)
Is the weller 80W overkill for our application (soldering batt & motor leads)?
YOKObori MOkei
wyl03 is offline   Reply With Quote
Best Soldering Iron? snoopyrc Radio and Electronics 30 11-21-2010 10:52 PM
good soldering iron? aus jd 2703 Australian Racing 17 08-26-2007 04:53 PM
Busted my soldering iron... goot irons any good? JusBox Electric On-Road 71 02-23-2007 09:18 AM
good soldering iron? streetracer745 Electric On-Road 25 01-07-2007 11:42 PM
DC Soldering Iron Guo Chean Electric On-Road 2 01-03-2005 12:02 PM
