Old 04-03-2010, 01:22 PM   #1471
Send a message via ICQ to MattW
That would have decreased the timing.
MattW is offline   Reply With Quote
Old 04-03-2010, 01:35 PM   #1472
Born2Run's Avatar
Thanks MattW
Whatever
Born2Run is offline   Reply With Quote
Old 04-03-2010, 02:59 PM   #1473
I canīt read actual motor temp and actual battery voltage. It shows 0.
Iīm pressing the button on Esc after the run and then turn off the esc, after that connect it to pc.
How can I read this data??
Other question my max voltage reading is 9.91v... How ??
Thank you
rcardoso is offline   Reply With Quote
Old 04-04-2010, 04:01 AM   #1474
if the esc shows a temp of "0" the motor has no ntc build in. Only motors with ntc show their temp.
About the max voltage of 9,9v, I believe I read something about the max voltage while breaking will increase this.
Lutz is offline   Reply With Quote
Old 04-04-2010, 04:20 AM   #1475
Hi,
Is there a way to remove the on/off switch from the speedo?
Cheers
Chris
chris_blakey is offline   Reply With Quote
Old 04-04-2010, 04:20 AM   #1476
the motor has ntc.
It shows max temp. Only donīt show actual temp and iīm pressing the button before shuting down the speedo.
Old 04-04-2010, 05:03 AM   #1477
Hm then Iīm not sure how it works. Havenīt recieved my new esc yet...
Old 04-04-2010, 05:05 AM   #1478
Originally Posted by chris_blakey View Post
Hi,
Cheers
Chris
I believe you can cut the wires from the switch and solder them toghether. This way the esc should be always on and you can turn it off wirh the set button if programmed with pc
Old 04-04-2010, 06:51 AM   #1479
JonboyGB's Avatar
Hi all, I'm using a GM90 with 7.2 firmware, with a 10.5 Novak Ballastic. Track is the very big Cotswolds, UK. Does anyone have a good starting point for mode and FDR?
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 04-04-2010, 06:55 AM   #1480
Thank you
Now I don't know this for sure, but i'm happy to take a guess.
Both of those are "real time/current" readings - however, when you are hooked up to your laptop, the ESC isn't powered. So, I suspect that those are parameters/readings that are more suited to the "telemetry box" that I believe is on it's way. I don't think it's possible to read those with the laptop.
Old 04-04-2010, 12:45 PM   #1481
Graham Kenny's Avatar
Hi Guys
Just got home from my first test today with the New GM120 and i have to say its got some pace.
We played around with a few settings but i would like to know what the options under the "power curve" heading do?
Ie today i went from STD Mode 9
"Medium additional Timing 2 9.5-21.5"
to
"high additional Timing 1 9.5-21.5"
I found that it made the car feel more sluggish under medium throttle and low rev's.
Thanks in advance
Graham Kenny
Team Schumacher UK - GM Racing - TIR - Boultspeed RC Paint
Graham Kenny is offline   Reply With Quote
Old 04-04-2010, 05:58 PM   #1482
hacker's Avatar
Trader Rating: 141 (100%+)
is that all you changed, just the powercurve setting?
according to the manual
The Powercurves are only in function if Timing with Sensors is set to +30°.
hacker is offline   Reply With Quote
Old 04-05-2010, 02:22 AM   #1483
Paul Hedgeland's Avatar
Hi I have read through all the posts since the release of the 2010 120 speed controller. I have flashed the firmware however I am unsure how to do a factory reset. Below is the accelleration tab,is this what should show for mode 9 please?
i330.photobucket.com/albums/l426/hedge1970/Mode9_GII.jpg
Also yesterday running firmware 10.x Mode 8 (standard) I melted a Speedpassion 10.5 R running an FDR of 5.77 on a small outdoor track which last year I run
Motor: Novak SS 10.5
ESC: LRP Sphere TC 2007
FDR: 4.74
It seems to me the FDRs while slightly higher are not extreme so I dont know why I would have melted the motor?
Thanks for any help you can provide.
Cheers
Paul
Paul Hedgeland is offline   Reply With Quote
Old 04-05-2010, 02:43 AM   #1484
thatīs what i got with mode 9 11.1
Old 04-05-2010, 03:05 AM   #1485
FDR: 4.74
Cheers
Paul
For me it seems that std mod 9 is too much for a 10.5. You could try a lower powercurve maybe with a higher fdr. The most important thing is to check temps regulary while driving if the motor hasnīt a ntc build in. You should also set your rpm limit to 50.000 and activate timing with sensors +30 because in the manual it is said that the powercurves work only if its activated
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
