Old 04-01-2010, 09:57 AM   #1456
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Originally Posted by rcardoso View Post
anyone knows the purpose of the free wire with a plug in the end on the sensor cable of the new gm gen speed control?
Thank you
Ricardo, as Martin said some posts before here you have the purpose of the new sensor cable free wire:
Originally Posted by Martin Hofer View Post
all new gm motors / graupner motor feature a ntc sensor, soldered to the sensor pcb
so just use a regular sensor lead
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 04-01-2010, 12:15 PM   #1457
thank you all!!
rcardoso is offline   Reply With Quote
Old 04-01-2010, 12:21 PM   #1458
yea I agree
[url=http://www.howtotalkdirty101.com/]How To Talk Dirty[/url]
daveytrackels is offline   Reply With Quote
Old 04-01-2010, 01:08 PM   #1459
Photo???? soldered to the sensor pcb
http://jlsabucedo.wordpress.com
higbo is offline   Reply With Quote
Old 04-02-2010, 05:54 AM   #1460
Is this what you should read with firmware 11.1 in mode 9 ??
( I ask because i didnīt tested with the old firmware )
What gearing should I start for 9.5T ( 6554 ) outdoor
Thank you!
Old 04-02-2010, 06:26 AM   #1461
hacker's Avatar
Trader Rating: 141 (100%+)
Thank you!
thats a bit hard to read.
did you do a reset AFTER you uprgraded to 11.1?
My standard mode 9 settings are different to yours.
hacker is offline   Reply With Quote
Old 04-02-2010, 10:25 AM   #1462
yes I reseted twice..
I will insert one bigger picture.
What values you have diferent in mode 9?
Thank you!
Old 04-02-2010, 11:35 AM   #1463
reseted again and now showing this...
can someone confirm me wich one is correct ?
Old 04-02-2010, 01:44 PM   #1464
jonny123's Avatar
Yes, The bottom one after u did the factory reset is correct. The 11.1 settings wouldn't have been updated if you hadn't done the factory reset. All looks good now tho.
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 04-02-2010, 02:20 PM   #1465
thank you!
With this software the motor is reving 83333rpmīs in the air...
Screams like a bitch!! eheh
gearing advice for starting ?6.2fdr? the motor is the new 9.5
Old 04-02-2010, 03:03 PM   #1466
Send a message via ICQ to MattW
So you haven't read the instruction pdf that was with the firmware download telling you to set the rpm limit to 50,000 - this is so that the motor doesn't go bang when you free rev it!
MattW is offline   Reply With Quote
Old 04-02-2010, 03:52 PM   #1467
i had read it,but also read here to upgrade to firmware 11.1, reset, choose mode 9 and dont touch anything...
Already limited to 50.000rpmīs
Thank you
Old 04-03-2010, 08:42 AM   #1468
hacker's Avatar
Originally Posted by higbo View Post
The value established in the "fixed timing" Does it affect when using sensors?
fixed timing is for both sensored and sensorless.
The fix timing is adjustable between 0...30° for sensorless motor mode. For most motors 30° is used.
In sensored mode this value does reduce the standard motor timing of 30° to 0...30°.
the help manual is very complicated and hard to understand.
Old 04-03-2010, 09:02 AM   #1469
hacker's Avatar
Default answers
GM reps, how about we get our questions answered?
There are about 2 pages back of unanswered queries.
If the manual was at least readable and understandable, than we wouldn't need to hassle you with questions here.
Old 04-03-2010, 11:05 AM   #1470
Born2Run's Avatar
Hi Martin
I was running my GM EVO3 7T Delta with a Mamba Max (sensorless) without any problem.Now i have a Mamba Max Pro and i was trying to run this motor sensorless but i had cogging issues.I tried sensored with the endbell timing (B on B) and i had cogging issues too but when i turned the endbell clockwise with B under C , cogging has gone.Its perfect.Did i increased timing or decrease it by doing this? Im confused.
Whatever
Born2Run is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
