Old 03-30-2010, 04:48 AM   #1441
hacker's Avatar
Trader Rating: 141 (100%+)
gear up (lower fdr) will reduce your punch
hacker is offline   Reply With Quote
Old 03-30-2010, 05:25 AM   #1442
Thanks for the tip hacker - i was looking for a software setting tweak though!
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 03-30-2010, 06:46 AM   #1443
hacker's Avatar
have a play with amplimit.
Old 03-30-2010, 01:15 PM   #1444
Hello all. After some years using LRP I have went and bought the new GM120 (2010 model) and a GM10.5T (97035).
I was looking some help with what base settings to use for 10.5 pro stock. Local track is considered high grip, with around 12-13 sec lap time. I had read somewhere to just choose Mode 9 and leave it at that???? Also what FDR should I start at.
Thanks very much in advance for the advice.
Stephen_102 is offline   Reply With Quote
Old 03-30-2010, 03:11 PM   #1445
G-kenny's Avatar
Since i am also new to the GM i will be starting on mode 9 for the first few runs at said track and have a play about from there.Stephen i have a few set up files from our friends over the water that i can send you. I have been advised to start with an FDR of around 5.7 at said track. I will be heading up on easter monday for some testing with this speedo. Monday cant come quick enough :-)
G-kenny is offline   Reply With Quote
Old 03-30-2010, 03:54 PM   #1446
HI Guys, what is the effect in fitting 12.5 mm rotor instead of running the 12.3mm rotor? and do I need to adjust gearing?
RC
prodriver is offline   Reply With Quote
Old 03-30-2010, 07:23 PM   #1447
Phil C's Avatar
Hey Ricky,
Fitting a 12.5mm rotor should give more torque but a little less RPM, so you'll have to gear up a bit to maintain the same top speed.
In my opinion a bigger rotor makes the motor more efficient, meaning it should run a little cooler.
Hope this helps.
| Team XRAY UK | HUDY | RC DisCo| LRP | Sanwa | SMD | Moorespeed | MB Models | Gingapaint | McLaren Racing |
Phil C is offline   Reply With Quote
Old 03-31-2010, 04:41 AM   #1448
hana166's Avatar
For 97305 optimum FDR is 6.4 - 6.6 for indoor lap time 13 secs. IMO mode 9 is too hot to start with. Modify the setting by turning down fixed timing to 16, especially if the track has a lot of tight turns. If its flowing use 20. If you are incredibly smooth you can use more. The motor/speedo has awesome grunt and if you are aggressive with the throttle you will heat up, but not go any faster in lap time. Monitor your motor temp by reading the telemetry each run. If you're peaking at 85 deg C ish internal its on the money.
If you use 12.3mm BRCA rotor you should in theory gear shorter but it doesn't quite work out like that especially if you use dependent timing, its intelligent and gives the motor what it needs. If you gear it the same (ish) as the big rotor, 6.4 - 6.8 it seems to work out great.
Also on temps, sometimes I found the small rotor ran a tiny bit cooler (??) and was less prone to fading, I cannot say for certain why. Strange.
Generally I'd say run the big rotor when possible because the brakes are massively better with the strong rotor, but its down to your preference. Car flows more with a smaller rotor, depends on your style.
hana166 is offline   Reply With Quote
Old 03-31-2010, 05:42 AM   #1449
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Just purchased the GM 17.5 97297 motor.
Anyone got any FDR and ESC setup advice?
Never used a GM motor don't want to blow the motor / ESC.\
Also how does the temp monitor work???
Alex
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 03-31-2010, 11:18 AM   #1450
anyone knows the purpose of the free wire with a plug in the end on the sensor cable of the new gm gen speed control?
Thank you
rcardoso is offline   Reply With Quote
Old 03-31-2010, 12:53 PM   #1451
Mr. MR4's Avatar
Default GM GENIUS 120 BRUSHLESS SPEED CONTROLLER V2010
How does the GM Genius 120 V2010 compare to other speed controllers (using 10.5 fixed timing motors) like the Advanced electronics Black Diamond and LRP SXX StockSpec?
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 04-01-2010, 02:11 AM   #1452
Simple: It's quicker
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-01-2010, 03:12 AM   #1453
Thank you
no one knows ???
Old 04-01-2010, 05:31 AM   #1454
CA
no one knows ???
It's for future telementry possibilites as far as i am aware.
Chris Ashton - Schumacher Racing
www.racing-cars.com
CA is offline   Reply With Quote
Old 04-01-2010, 09:51 AM   #1455
John_S's Avatar
It is fior used with axtra motor temp sensors for motors that dont have one inbuilt like the new gm motor. To use this you must atatch your own ntc sensor to the motor
John_S is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
