Old 03-15-2010, 07:53 AM   #1336
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
both Gen1 V8 (V7.2) and Gen2 V1x.x
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 03-15-2010, 10:01 AM   #1337
Ritchie T's Avatar
Exclamation
Hi i have a few questions if you please!
When running Genius 120 gen2 with fw 11 do you still use Martins stock tutorial where you copy the modes over?
Also i need some gearing for 10.5 prostock on this size track
http://www.youtube.com/watch?v=JS-aCYLBy5E
Thank you
Ritchie T is offline   Reply With Quote
Old 03-15-2010, 10:03 AM   #1338
hana166's Avatar
Originally Posted by Jamesalex View Post
Does anyone know where I can get part of the update lead from as it has broken.
The bit that has broken is the lead that plugs into the speed controller and the usb board (has the same pin heads each end)
Do I have to buy a complete set or is there a place that I can get one from?
Cheers in advance
I had this problem and unfortunately I could not find a part number so I bought these double ended cables
http://uk.farnell.com/harwin/m40-904...204?CMP=e-b1ef
And the 8 way connectors to go with it. Had to buy enough for 8 leads to make minimum order though. But not a problem if you can split the cost with your friends.
hana166 is offline   Reply With Quote
Old 03-15-2010, 10:36 AM   #1339
John_S's Avatar
Hey richie i would recmoned with firmware 11.1 to use a standard mode 9 and change the max rpm to 50k and the frequency to 4kc as martin suggests. I would try starting my gearing around 5 for that track with a gm motor. Hope this helps and aim for temps between 70 and 80
John_S is offline   Reply With Quote
Old 03-15-2010, 12:18 PM   #1340
Ritchie T's Avatar
Exclamation
Thanks John much appreciated!
Should i do this aswell?
'To activate the new Stocksoftware for max. Top Speed
Reserved4 = 1 must be activated. Klick value 1 (Stock high speed timing).'
Or would that be for bigger tracks?
Old 03-15-2010, 12:23 PM   #1341
John_S's Avatar
Yes i think that was standard on mine? Remember and do a factory reset after you upgrade the firmware to initialise new the base settings
Old 03-15-2010, 06:03 PM   #1342
fifi's Avatar
I feel like I need a sensor cable, sometime the motor feel lost, a cog/hesitation?
On the pc for timing there is 7.5, 15, 30 but on the motor
there is -10 -5 0 +5 +10
Originally Posted by Martin Hofer View Post
just gear it up
fifi is offline   Reply With Quote
Old 03-16-2010, 01:46 AM   #1343
Hi!
Have you usb device for download data?
I need software version of your speedo.
Because if it is 4 mode, you can choose mode 3 (it is designed for modified),
and on PC set it with sensors and put limit of rpms
About timing, on pc set 30 and on engine 0. If want loose some power,
on engine set -5 or -10.
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-16-2010, 04:25 AM   #1344
the stock turtorial is not meant for V8 / V11.1
but if you read it you will find that I wrote it's for older FW versions /Gen1 speedo
the best and easiest solution is to upgrade to 11.1, do a factory reset, pick mode 9 and not touch any of the settings
just make sure you did the factory reset properly .. that's about the most important part
running sensorless, the motor timing is functionless, all you do is to move the sensors around and with no sensor lead you can change the timing as much as you want ... it will never have any effect
send me an email and I'll help you out
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-16-2010, 06:32 AM   #1345
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Running T3 with SP V3 10.5 in mode 8...
WOW, this ESC is something else I had to move to Mode 7 which backs off the speed to be able handle the car
I admit running on a new track was not the best idea for it's first run, but very very impressed.
Ran 33 rollout mode 8 it came off at 125f NOTHING... I cannot rave enough about this speedy...
We are having another 17.5 evening at my local club this week feeling sorry for anyone who has to come up against this thing
Found the power delivery needs a little getting used too very smooth and the punch when you back off the power and then back on is amazing.
Alex
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 03-16-2010, 10:11 AM   #1346
for 17.5 use mode 9 and gear at around 5.0 indoors and 4.3 - 4.0 outdoors then it'S rocking
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-16-2010, 10:20 AM   #1347
Ritchie T's Avatar
Exclamation
Ok fair enough when all thats done if i wanted to have a play around with a few of the settings which ones would you suggest?
The only reason i ask is that on club nights ill be running on a pretty small track and in a few months ill be doing nationals on much bigger ones.
Also in the v11 firmware faq which bit is this in the sortware?
'The power at the start is set with
Max. Timing: 0-30. Best value 12-20'
Old 03-16-2010, 10:27 AM   #1348
none, just leave it the way it is set
mode 9 will work for every track
if it is really getting too hot (won'T happen but just in case, use mde 8)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-16-2010, 02:27 PM   #1349
Me_MrTyson's Avatar
Thanks for the 17.5 advice...
I was running 10.5 in mode 8 125f everytime it came off mode 9 should be warmer but not by much this seems to run very efficient.
Mode 9 is where I shall be but need to work out braking point as you get to them quicker than anything I tested.
Old 03-16-2010, 05:58 PM   #1350
fifi's Avatar
Yes I have the device for pc but the older one.The one you plug on the speedo and the receiver. My friend has the new one.
On the speedo older version only 4 mode can t adjust cut off for lipo.
maybe need to send it in for update the software?
I will put mode 3 with 30 timing on pc and 0 on motor.
How do I reset mode 3 once I change on pc? Pushing set after setting mode3
doesn t seem to change the value.
Do I need a sensor wire? If yes the gm with switch or lrp direct?
Thanks, for taking time to answer.
Originally Posted by M.Abramowicz View Post
Hi!
Regards!
m.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
