Old 03-07-2010, 04:14 PM   #1306
Originally Posted by Martin Hofer View Post
when you clicked "receive data" just plug the usb wire into the speedo, no need to push the button on the wire !
Unfortunately I have to - without pushing that button transmision never starts.
That mean if I push that button it resets some data stored in esc, right?
KiiT is offline   Reply With Quote
Old 03-07-2010, 04:55 PM   #1307
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
if you click receive data and THEN! plug the wire into the speedo transmission starts automatically
if you want telemetry data, telemetry needs to be activated last tab, and you need to push the button on the speedo once shortly before switching the speedo off after the run you want telemetry data from! otherwise telemetry data won't be saved
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 03-08-2010, 01:00 AM   #1308
24 is about right, but 5,5 is totally undergeared (13.5 i guess?) as that's what I use indoors!
try 4.5, then it will be much faster
Yep running a 13.5 GM Motor and will give 4.5 a try soon.
One thing we did struggle with was the brakes. I know most people say the feel is very different with the GM, but until i turned the settings up they were all most ineffective when coasting up to the line for the start of my race. The high speed stopping seemed ok though...
Whats the major difference/improvement in the 'New Brake Software' tick box?
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 03-08-2010, 02:16 AM   #1309
the "new brake software" is speed depending:
high speed = high brake force, low speed = low brake force
this is why, when you drive to the line and the car is really slow, brakes are soft but that's not much of an issue really
when driving, the brakes feel much nicer with that software activated as you can brake more precise
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-08-2010, 02:54 AM   #1310
Send a message via MSN to Grindog001
Hi all, i have just bought a 2009 GM 120 ver 7.2 and have set it up etc. I am just curious about this advance in timing and when you would idealy have it coming in, eg half way on the straight? Also, if it is coming in too early or late, what setting would change this please?
Also, any gearing advice on a MI4 LP running a GM 10.5 on a medium twisty track with 30 metre straight
thanks in advance
john
Grindog001 is offline   Reply With Quote
Old 03-08-2010, 03:05 AM   #1311
10.5 switchpoint should be set to approx 13000 rpm, reserved should be set to 81, timing 1 should be 80 - 100
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-08-2010, 03:57 AM   #1312
Nuno Gancho's Avatar
Hi Martin, do you know when will the new speedo come ot, thanks.
Nuno Gancho is offline   Reply With Quote
Old 03-08-2010, 04:20 AM   #1313
the new speedos are available for sale for quite some time already
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-08-2010, 04:05 PM   #1314
part-time racer's Avatar
Default Up-grade question
Hello all,
without going back through all the pages I would like to ask a quick question. I bought 4 months ago a gm 120 (purple case) which I was really happy with so based on this I bought a second 120 (black case) for my indoor car.
I went racing on Sunday to a new indoor club and was suprised to learn from a local racer to this other club about the new 120's and the software installed on these new units.
My question is, how do I go about getting my 1 month old and 4 month old esc upgraded to this new specification?
The difference between my car and the car running the new software was staggering!!!
Having spent 400 in 4 months, I really hope there is a solution as the National season is due to start here in the UK in 6 weeks.
part-time racer is offline   Reply With Quote
Old 03-08-2010, 06:08 PM   #1315
steveonamission's Avatar
Originally Posted by part-time racer View Post
Hello all,
Im sorry to say, theres nothing you can do about your Gen 1 gm 120 esc's.
The new generation 2's have a completely new processer, its not just as simple as updating there firmware, the new ones have a boot loader so now, just like the tekin you can update the firmware yourself.
steveonamission is offline   Reply With Quote
Old 03-09-2010, 12:47 AM   #1316
tomracing's Avatar
Gm has offered firmware.v8 for the older gm120's
you can send your esc to gm and have it upgraded to a software like the v11.1 on the geniusII series. It will cost about 20euro+shipping
unfortunately no self updating for that you need the geniusII
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 03-09-2010, 03:32 AM   #1317
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Just purchased my first GM ESC
Was thinking of trying out one of the motors too..
What is the difference between Delta and star?
guessing star is a little older and Delta is a new version...
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 03-09-2010, 06:41 AM   #1318
Nope.
It is solder job. Star looks like Y and delta is like triangle.
Normal engine is star, and you can read for example 5.5T.
Deltas has 8D, 6D or 7D or 12D and have more rpms then star.
If I remember right, 6D has more power then 3.5T
Stock/Pro racing is for star engines and with high value of wind, liek 10.5T.
For modified you can choose what you need
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-10-2010, 06:32 AM   #1319
Lack of brakes with a gm90 using a gm 13.5 motor ( 97294 ) .
Its got the old firmware on it and I've tried the autobrake software option but it just seems to lock the wheels.
it just dosent seem to want to give me any brakes even with the new brake software
I dont know how to link my set up from the programer on here but I can email it if required.
the speedo is nice and punchy I just cant seem to get any brakes on it unless I turn on the auto brake
mobile chicane1 is offline   Reply With Quote
Old 03-10-2010, 06:56 AM   #1320
Do you know value of AutoBrake and MinBrake?
If I use new software for autobrake my good option was MinBrake = 5 and AutoBrake = 2 (with AB = 5, i feel lock the wheels when car almost stop).
m.
Michal Abramowicz
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
