Old 03-04-2010, 12:57 AM   #1291
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
correct, there is no switchpoint if you don'T tick "highspeed timing with switchpoint"
so the switchpoint rpm is functionless -> smoother feeling
switchpoint should be left at 10k though as that's where it should be if sensors would break during a race to be able to continue sensorless
you need to update the speedo yourself but that takes about 1 minute ...
how do you define "telemetry doesn't work"
the motortemp function ofcourse only works if the motor's got a tempsensor in it
all new GM / Graupner motors do have one
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 03-04-2010, 12:59 AM   #1292
Hi Martin!
There is option to get "external" wire with temp sensor from GM?
Sometimes we can't use GM engines because of event rules.
Regards!
m.
ps: whish you good luck at Warsaw/ETS
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-04-2010, 01:03 AM   #1293
you can solder a NTC tempsensor on Speedpassion sensor pcbs aswell, if you want to have the saftey option at say ETS races
not going to do Warsaw ..
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-04-2010, 04:28 AM   #1294
hana166's Avatar
Thanks for your reply Martin,
My battery reading is between 0.5 and 0.7v - perhaps I am missing something.
I use new style GM motors only, 97305, 97290, perhaps the sensor is faulty
hana166 is offline   Reply With Quote
Old 03-04-2010, 06:07 PM   #1295
hana166's Avatar
Scrub the last post, all good now..
Tried a bigger track today (100ft straight) with the new software. The dependent timing and powerbandless delivery is a true masterstoke..the car is very, very quick everywhere but controllable in the infield.
Throttle feels incredibly direct. A bit of a shock at first. Needs a bit of adjusting to..
It seemed slow at first because its so smooth..until I realised I was even faster than the SXX stock spec drivers down the straight. Oh dear. Temps were amazing, 63 deg C. No heatsink.
0.5 seconds off my fastest lap from last week..and I haven't really started to play with the gearing, rotor, etc.
I love my 7.2 (still do) but this thing is the next level. Seriously impressed.
Old 03-05-2010, 06:00 AM   #1296
Nice to hear that.
Which Fixedtiming value did you use?
BTW, I recommend to use 90 or 100A amplimiter. You won't loose too much punch in the infield but the motor just stays cooler.
And 4kc frequency. Same effect.
Gearing doesn't really matter.
Tried it indoors.
Went from 6.0 to 4.5 and there was nearly no difference. 4.5 was fast in the first 2laps, then the magnet fades and you are no faster than with 6.0, but 6.0 was much nicer to drive as it is more consistant and as you also mentioned more precise on throttle.
I guess Outdoors, 5.0 - 4.0 will be the range to use
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-05-2010, 05:42 PM   #1297
I Raced tonight at my local track (16x30metres),
I Ran Martins recommendations (pretty much Mode 9 std) and WOW
!!!!!Serious Horsepower!!!!!
I tested with and without the switching point and I have to agree with Martin thats its seriously smoother without a switch point!!
I wasn't matched on the main-straight and it looked like a full blown modified haha.
Temperatures were about 65 - 70 degrees so about right.
I really question the need for modified motors indoor now
Gearing was 6.3 with the speed passion 10.5
Stefan-Hpi Uk is offline   Reply With Quote
Old 03-06-2010, 05:48 AM   #1298
Hi Martin,
I can't read telemetry data either.
Could you please review if my reading data sequence is correct:
- motor test run (motor #97303);
- switch off esc by on/off switch
- unplug power;
- connect usb link to pc;
- run software, fix port;
- receive data;
- plug esc to usb link;
- and I must press reset on the usb link to start data receiving.
After all data are received I have wrong telemetry data. There is not max rpm, amps, also battery voltage is around 0,2V
Could you please advice?
Thanks,
Robert
KiiT is offline   Reply With Quote
Old 03-06-2010, 07:10 AM   #1299
hana166's Avatar
Originally Posted by Martin Hofer View Post
Nice to hear that.
Tried it indoors.
For 10.5 motor 12.3mm magnet 97290, indoors
I found that no timing or very little on the bottom end was best with FW7.2 and gearing at 6.44 (a good balance of punch and no fade)
so with FW11.1 I used 0 powercurve and fixed timing 25, amplimit 130. This worked well for the whole 5 minutes
Next week will try 97305 big magnet. I always preferred the feeling this motor has but have had problems with fading. It needs to be geared tall, it likes 5.3 - 5.9, 5.45 was fantastic but it was fading quickly. I had amplimit 250, now I understand this was not the correct way.
I might try 5.45 gearing and experiment with the amplimit to keep the motor fresh.
I guess the gearing is less important because of the dependent timing but if the motor is in the sweet spot the feeling is better..
Old 03-06-2010, 09:26 AM   #1300
Hi Guys i am in need of some help i have come to upgrade the firmware on my gm to the new 11.1 but i am unable to i get the screen up to upload the new version and select the bin file but when i press the program button it goes to 99% then comes up with a erroe message saying (Found not target devise)
Please can some one tell me what i am doing wrong
minivtec is offline   Reply With Quote
Old 03-06-2010, 09:45 AM   #1301
You need to press the little button on the USB adapter, after pressing the Program button in the software and while the bar is going across the screen . It then should load the firmware.
Hth
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 03-06-2010, 10:07 AM   #1302
Thanks Toblerone got it sorted now
Just one more question it says to do a system reset to get it working properly how do i do that
Old 03-07-2010, 09:35 AM   #1303
40decC is too cold, advance the fixedtiming value. I uses 24 the last weekend with 13.5.
Temp should be in the 75-80 deg range and gearing 5.0 - 6.0 indoors.
Then it's really really fast
Just ran outdoors for the first time and the car was very fast!
Advanced the fixed timing to 24, geared to around 5.5 and motor temps on can of 50 deg.
I have to do more testing with gearing, but a solid start
Thanks for all the tips Martin!
www.mkrctc.org.uk
Old 03-07-2010, 03:15 PM   #1304
Originally Posted by KiiT View Post
Hi Martin,
- unplug power;
- receive data;
Thanks,
Robert
when you clicked "receive data" just plug the usb wire into the speedo, no need to push the button on the wire !
I found 5.4 - 5.8 to be the sweet spot of the 13.5 gm motor so I'd say 6.0 would be about right for a 10.5
forget everything you know by now about timing and how it works the motor. The new firmware is 100% different
I'd use a regular 12.5mm magnet
24 is about right, but 5,5 is totally undergeared (13.5 i guess?) as that's what I use indoors!
try 4.5, then it will be much faster
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 03-07-2010, 04:14 PM   #1305
hana166's Avatar
Thanks Martin,
I'm using 6.44 with 97290 12.3mm BRCA
So I should try 6.0 with 97305 12.5mm, yes?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
