Like Tree2Likes
GM Brushless
Old 01-13-2010, 11:40 PM
  #1216
Kajman's Avatar
Hi everybody,
It seems that I will have to help my friends and lend them my esc for next racing event. Problem is, that they will drive in 13.5T + Lipo or LiFe class, has anyone idea which program or what setting should I use in 7.2 software esc's?
Motors will be Pro 13.5 and Sport 13.5.
Kajman is offline
Old 01-14-2010, 02:57 AM
  #1217
Stein Tumert's Avatar
Originally Posted by Kajman
Hi everybody,
From Martin:
For 13.5T with Genius 120/90 with 7.2 sw
[AddData]
Brushless=1
Sensor=0
Car=
Place=
BarCode=
Comment=
Motor=
Pinion=0
MainGear=0
InternalGearRatio=0
TireDiameter=0
MaxRotationSpeed=255
MaxCurrent=0
[GeniusData]
StartAmp=120
AmpLimit=250
Turbo=1
BrakeMin=5
BrakeMax=95
AutoBrake=0
FullBrake=95
ABS=0
RPMLimit=8
Polzahl=2
Frequency=3
Reserved=89
MaxReverse=100
Softgas=50
PowerCurve=0
Autogas=0
Switch=0
OnAfterUSB=1
Timing=3
TimingWith=2
[GeniusDataAdv]
Stein Tumert is offline
Old 01-14-2010, 04:40 AM
  #1218
Kajman's Avatar
Thanks man, is it with LiPo or LiFe?
Kajman is offline
Old 01-14-2010, 05:49 AM
  #1219
LiPo
Old 01-14-2010, 06:16 AM
  #1220
Originally Posted by sn00p
GM Genius 80R Race (7157)
Martin can you help?
I have a few simple questions please:-
Is it possible to get a firmware or software upgrade for this ESC?
Can i use the USB cable (GM7168.6 Genius USB Interface Cable) to setup the 80r ESC? (If i cannot use the USB lead then do i get any extra benefit from the programing box 7152 over using the TX to setup the ESC???
I also noticed on the GM website this:-
Programmierung 7154 und 7157
HOT!
gepostet von Ralf Helbing am - 17.12.2009
Richtige Programmierung mit Rückwärtsgang:
Einige Kunden habe Schwierigkeiten beim Aktivieren des Rückwärtsgangs.
Dies hat drei Ursachen. Zum einen ist leider die Funktion 1.) Auswahl des Motortyps in der Anleitung vertauscht, wodurch die Programmierung ohne Programmer irreführend ist, zum anderen muss sichergestellt sein, dass der richtige Motortyp (ohne Sensor oder mit Sensor) eingestellt ist.
Werkseitig ist ein Brushless Motor mit Sensor programmiert.
Folgende Einstellungen müssen vorgenommen werden, damit der Rückwärtsgang richtig funktioniert:
Funktion 3: Motortyp wählen:
1.) Motortyp wähen (Bürstenloser Motor ohne Sensor (1) / mit Sensor (2), Bürstenmotor (3))
7.) Startleistung auf sehr hoch (5) stellen
10.) Rückwärtsfunktion (2 oder 3) wählen
Wird ein Sensormotor sensorlos programmiert und betrieben, dann funktioniert die Rückwärtsfunktion nicht mit der Werkseinstellung, da die Werkseinstellung für Brushlessmotoren mit Sensor eingestellt ist.
Zubehör: Sensorkabel Best.-Nr. 97286.4
I take it is saying that the instructions are incorrect and to select sensored if you wish to use sensorless and vice versa???
I ended up mailing GM and got a very quick response...
Dear Daniel Matjasz,
for this speedo no USB or update is available.
The english instruction is right, just german and french is wrong.
The programmer box 7230 you can order at the next graupner shop or I think Schumacher.
Mit freundlichen Grüßen /
sn00p is offline
Old 01-15-2010, 04:36 AM
  #1221
Hi All
I've currently got Martin's 'Hot 13.5 Lipo Program' on my GM120, and it is fantastic at one series i run at as the carpet gives loads of grip, but at another series i run at the carpet gives nowhere near as much grip and i am sliding around a lot.
What settings should i look at altering to tame the power delivery for this other venue to make it less aggresive.
Thanks in advance.
Ryan
Kecky is offline
Old 01-22-2010, 04:52 AM
  #1222
Does anyone knows when will be released the new ESCīs ??
I need one ESC...
rcardoso is offline
Old 01-22-2010, 12:37 PM
  #1223
I need one ESC...
February?
Go to shop.graupner.de or search for it on www.hobbydirect.de
m.
M.Abramowicz is offline
Old 01-26-2010, 11:21 AM
  #1224
Default GM 120 v2
Another question for Martin / GM!
Is the PC software going to be new on the Gen 2 120, or the same as current?
Any changes to make it easier to use?
Toblerone is offline
Old 01-27-2010, 12:55 PM
  #1225
adri-13's Avatar
normally the PC set-up is the same. Just the speedo version evlove.
adri-13 is offline
Old 01-27-2010, 01:51 PM
  #1226
PizzaDude's Avatar
Maybe even more important; will the esc's firmware be downloadable and installlable at home?
Martin?
PizzaDude is offline
Old 01-28-2010, 03:28 AM
  #1227
Martin Hofer's Avatar
new pc software and new fileformat (.gd2)
so you cannot mess up old and new settings
the software has been restructured to make it easier to use.
there will be the possibility to update the speedo yes
Martin Hofer is offline
Old 01-28-2010, 03:52 AM
  #1228
PizzaDude's Avatar
Sounds sweet.
How is it (prototypes) currently holding against the Advanced and the new LRP in stock?
Thanks.
Old 01-28-2010, 04:14 AM
  #1229
Kajman's Avatar
Hi Martin, you seem to be knowing more
So will old esc be able to use new software? Old I mean both G50-100 and 90-120.
Will new software be better or only easier? And finally, will user be able to update esc?
Kajman is offline
Old 01-28-2010, 05:34 AM
  #1230
mike and Alex's Avatar
Default GM120
Attention Martin / GM
I have just received my GM120 with new firmware installed. I will be trying the speedo setting I read a few pages back for the 120 when using a 13.5
Is their a setting available when using a 10.5?
Last but not least does the new GM120 have new firmware?
Regards,
mike and Alex is offline
