Old 12-31-2009, 03:04 AM   #1201
radio_car_racer's Avatar
Brakes GM 120
can get the high speed to feel good but not the low speed
how do I get both to work as I want using the pc software?
mode 3
brake min 80%
brake max 80%
had to trim ATL on Futaba 4PK to 18% to get the high speed to work
motors the latest GM 6.5 in a Durango DEX410 1/10th off-road buggy
radio_car_racer is offline   Reply With Quote
Old 12-31-2009, 05:39 AM   #1202
Originally Posted by radio_car_racer View Post
Brakes GM 120
mode 3
brake min 80%
brake max 80%
I set initial brake to 40 and softbrake to the lowest value (all the way to the right) and leave brake min/max and fullbrake all on 100% I haven't changed the ATL as it seems to be enough brakes.
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-04-2010, 04:24 AM   #1203
Martin any news about the release of the new esc, and new features ?
Happy new year for all!
rcardoso is offline   Reply With Quote
Old 01-04-2010, 05:47 AM   #1204
Jamesalex's Avatar
Hey all,
Quick question, looking at leaving the fan off of my gm120 as
A my car is over weight
B I cant fit the speed controller where I want with the fan on
to help balance it out
I was just wondering if anyone has run theres with no fan and how it worked out (overheat etc)
Cheers
James
Jamesalex is offline   Reply With Quote
Old 01-04-2010, 04:08 PM   #1205
Thumbs up
Originally Posted by Jamesalex View Post
Hey all,
Need more data car, type, engine, battery.
I use gm50 on 10.5T/Lipo 2S with on-road ae tc5 for racing,
or 9.5T/Life 2S 6.6V and there is no thermal issue
So gm120 should work fine in on-road for spec/pro stock racing without fan,
just tape it to chassis on two small strip 5mm width and leave some space
for air
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-05-2010, 08:42 AM   #1206
hana166's Avatar
Brakes GM 120
mode 3
brake min 80%
brake max 80%
Somebody please correct me if I am incorrect, but, as I understand it, if you have 7.2 version, then 'Program number' on tab 2 is actually high speed brake feel. The higher the number the softer the high speed brake. So you should be able to set your brake as normal for low speed then adjust high speed to suit your preference.
hana166 is offline   Reply With Quote
Old 01-06-2010, 01:07 PM   #1207
Hi
Does any one have a program for stock 10.5 ideal but one for 17.5 would be good for a start.
Quietman is offline   Reply With Quote
Old 01-06-2010, 03:29 PM   #1208
John_S's Avatar
What firmware are you using?
John_S is offline   Reply With Quote
Old 01-06-2010, 03:35 PM   #1209
TheCoolCanFanMan's Avatar
does any one have a GM120 for sale, as im going to Snowbirds and mine has ceased to function
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 01-06-2010, 04:28 PM   #1210
PizzaDude's Avatar
Malc
I do NIB.
PM me.
PizzaDude is offline   Reply With Quote
Old 01-07-2010, 02:12 AM   #1211
Originally Posted by Quietman View Post
Hi
Using 4.9 firmware
Old 01-08-2010, 03:07 AM   #1212
Default Bent Sensor Plug
I have a bent sensor plug on my gm120, happened last night when I was fiddling with it on the pc and testing settings, it is the pin which is on the far right which is bent, and it looks very bent, tried using a small allan key driver to bend it back in place but can't do it using this, can anyone recommend a better tool to use, i was thinking of using a very fine sewing pin?
Bony85 is offline   Reply With Quote
Old 01-08-2010, 03:58 AM   #1213
Mark, i bent a pin when i started using the GM, and CAREFULLY bent it back using a small tweezers. you don't want to bend it and break it though obviously !
CPD Racing
Old 01-08-2010, 05:12 AM   #1214
Originally Posted by PizzaDude View Post
I do NIB.
PM me.
you have pm dude
Malc
Old 01-08-2010, 08:18 AM   #1215
GM Genius 80R Race (7157)
Martin can you help?
I have a few simple questions please:-
Is it possible to get a firmware or software upgrade for this ESC?
Can i use the USB cable (GM7168.6 Genius USB Interface Cable) to setup the 80r ESC? (If i cannot use the USB lead then do i get any extra benefit from the programing box 7152 over using the TX to setup the ESC???
I also noticed on the GM website this:-
Programmierung 7154 und 7157
HOT!
gepostet von Ralf Helbing am - 17.12.2009
Richtige Programmierung mit Rückwärtsgang:
Einige Kunden habe Schwierigkeiten beim Aktivieren des Rückwärtsgangs.
Dies hat drei Ursachen. Zum einen ist leider die Funktion 1.) Auswahl des Motortyps in der Anleitung vertauscht, wodurch die Programmierung ohne Programmer irreführend ist, zum anderen muss sichergestellt sein, dass der richtige Motortyp (ohne Sensor oder mit Sensor) eingestellt ist.
Werkseitig ist ein Brushless Motor mit Sensor programmiert.
Folgende Einstellungen müssen vorgenommen werden, damit der Rückwärtsgang richtig funktioniert:
Funktion 3: Motortyp wählen:
1.) Motortyp wähen (Bürstenloser Motor ohne Sensor (1) / mit Sensor (2), Bürstenmotor (3))
7.) Startleistung auf sehr hoch (5) stellen
10.) Rückwärtsfunktion (2 oder 3) wählen
Wird ein Sensormotor sensorlos programmiert und betrieben, dann funktioniert die Rückwärtsfunktion nicht mit der Werkseinstellung, da die Werkseinstellung für Brushlessmotoren mit Sensor eingestellt ist.
Zubehör: Sensorkabel Best.-Nr. 97286.4
I take it is saying that the instructions are incorrect and to select sensored if you wish to use sensorless and vice versa???
sn00p is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
