Old 10-25-2007, 03:33 AM   #106
Nuno Gancho's Avatar
Hi i just got my GM 100, i will race with 5 cells/lipo and a 4,5T GM, can you gys give me set up for the speed control, Thanks.
Nuno Gancho is offline   Reply With Quote
Old 10-25-2007, 04:22 AM   #107
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
a good starting setup is:
amplimit 200
turbo 1
startamp 130
minbrake 20
maxbrake 92
fullbrake 92
frequency 1
abs 0
throttle curve 0
reserved 22
softgas 100
these should have been the most important things.
if you need any more information, just let me know.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-25-2007, 06:47 AM   #108
Thanks for all information.
Old 10-25-2007, 04:53 PM   #109
Send a message via MSN to afonsospt
On Genius pc software rpm limit is at 8 by default.
For GM Evo3 4.5 with 5cells should I lower this value,or leave at 8?
Thanks in advance.
afonsospt is offline   Reply With Quote
Old 10-25-2007, 11:02 PM   #110
I prefer using rpm limit 0
just to make sure there is no limit.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-26-2007, 12:59 PM   #111
It doesn't matter, because a two pole motor will not make 120000rpm or more. The rpm limit was made mainly for bonded magnets, so they can't explode so easy, if you reduce the rpm limit or if you want to do stock racing with an rpm limit.
With sintered magnets you can adjust 0.
habicht is offline   Reply With Quote
Old 10-29-2007, 04:02 AM   #112
Default Running in sensorless mode
Are some motors preferred over others when running in sensorless mode? I used the word preferred instead of better because I'm not talking about power/speed here.
The reason I ask is I ran the 100 for the first time at the weekend with a Novak SS 10.5. In the second run I didn't notice the red adaptor lead pin was lose and the speedo only saw one sensor. I (wrongfully) assumed a sensor had broken and unplugged the sensor lead so it could run in sensorless mode. However, the motor became unpredictable and it didn't have a smooth progressive feel.
Would the Orion/GM type motors "feel" and respond better in sensorless mode?
THancock is offline   Reply With Quote
Old 10-29-2007, 04:10 AM   #113
yes, the brushless motor should have a sintered magnet or a GM bonded Magnet. Other bonded magnets are not strong enough for sensorless use.
Most of the bonded magnets get too weak after some runs.
Old 10-31-2007, 03:58 AM   #114
Holmenkollen's Avatar
Is it usual that the ESC (Genius 95) turns off in a hard hit. It has happen to me twice now. Works normal again after 30 s.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-31-2007, 04:02 AM   #115
try setting switch to 0
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-31-2007, 04:34 AM   #116
I have it on 0. The steering works but not the throttle. But after 30 s it works again. Iīm using two capacitors.
Old 10-31-2007, 06:20 AM   #117
could it be a temperature cut-off?
Old 10-31-2007, 06:51 AM   #118
I donīt think so. I drive indoors with five cells and a 4.0T. Optional heatsink. Speedo temp around 65 C.
Old 10-31-2007, 07:02 AM   #119
hm, sounds ok but try reserved 23 though
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-31-2007, 10:29 AM   #120
Last weekend tried 3.5T with FDR 8 on a small track and it was awesome.
Im not sure if this has been answered previously,but which FDR are you using with evo3 3.5 and 4.5 bl motors on bigger(1/8) tracks with 5cell?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
