Old 11-26-2009, 01:45 AM   #1141
Send a message via MSN to PMSorber
Originally Posted by sidecarphil1 View Post
hi martin
i have just bought a GM120 and am wondering if it is best to send it to GM for the new firmwere adding or is it ok just to use it , i will be replacing / trying against my SPX , so would like your imput , there is a few people in my club running this speedo but your input would be nice too
Phil, just jump some tables this Sunday... I will be happy to help.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 11-26-2009, 07:46 AM   #1142
i bought it second hand , it is coming on 6th December
but i will be asking for your advice Pieter
sidecarphil1 is offline   Reply With Quote
Old 11-30-2009, 11:49 PM   #1143
Thumbs up GDA file for 7.6 (should work for 7.2) LIFE 6.6V/9.5T
Hi!
There is my last gda file from gm95 with 7.6 soft (should work for 7.2
on gm90/gm120 when change Firmware=76 to Firmware=72)
At my last race event, LIFE 6.6V pack was allowed and on engine 9.5T
my TC5 was fu** rocket
FDR = 99/34*2=5.82
Engine 9.5T GM sport blau with 12.5mm rotor/fan
Tires vtec 30
ESC has max temp 59C (with smooth ride about 55-56), engine max 79C
(with smooth ride about 72-75).
Regards!
m.
ps: change txt to gda if want set it.
File Type: txt life_pabianice_dtm_tc5_9.5T.txt (874 Bytes, 167 views)
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-01-2009, 12:44 PM   #1144
jeppesen's Avatar
Hi guys.
At this weekends race, i had a good speedo/motor combo, speed was perfekt with lots of low end punch.
But, at final 2 my car didn't come right of the start, the car moved a little, then stopped, and than again full power, I thougt it was because the car was pushed back just before the start.
But then at the start of final 3, when i hit full throttle the car just stutteret for a second, and then it went off, there was no problems under the race.
I use a GM120 in stock program 6, the sensor cabel is new.
jeppesen is offline   Reply With Quote
Old 12-01-2009, 12:48 PM   #1145
Hi!
Check solder on engine, my friend at last race has this problem, because
hi doesn't done it right.
I have hope it help
Regards!
m.
Michal Abramowicz
Old 12-01-2009, 02:15 PM   #1146
jeppesen's Avatar
Originally Posted by M.Abramowicz View Post
Hi!
I have hope it help
Regards!
m.
First i forgot, i had changet to a GM90 speedo, al the motor soldering is ok, i checket them at the race, but not the one on the speedo.
Old 12-02-2009, 04:37 AM   #1147
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
it'S certainly not a solder connection.
take the motor apart, and clean the Sensor pcb! dirt on that can cause those issues.
are you sure the gen90 was set to factory settings?
@abram
your transmitter values are extremely far off! you should check those
for stock racing I also suggest startamp = 120, currentlimit= 250, softgas = 50 (always!) and hard powercurve insteas of reserved 88 as that makes the motor run hot and drop off.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 12-02-2009, 05:11 AM   #1148
Kajman's Avatar
Martin, would you send me your GDA file for stock with LiFe and Pro 9,5?
BTW- how much does weighth your BD5 with 9,5 and life as rtr?
When you programm tx, how do you move throttle trigger-slow or fast to get best result?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 12-02-2009, 05:23 AM   #1149
Originally Posted by Martin Hofer View Post
@abram
Hi Martin!
My TX is 3pk with fast module, epa +/-100% and I use it for last 4 events.
Before change I used spektrum pro module with 3001 rx and data was:
FullThrottle=23402
NeutralPoint=16257
FullBrakePoint=9117
Now with [email protected] data is:
FullThrottle=22564
NeutralPoint=13588
FullBrakePoint=9768
This esc was used by my friend with his sanwa [email protected](sanwa system)
and data was (-/+ 100% epa like manual said):
FullThrottle=23005
NeutralPoint=14681
FullBrakePoint=10111
Maybe when I will have time I will set epa for 90% and check profile
with hard curve.
Problem is simple, manual from GM does not say it directly what this option
gives with another options as yoyu know, I drive for fun and now
my esc is set almost perfect, maybe I check more options.
Regards!
m.
Michal Abramowicz
Old 12-02-2009, 08:47 AM   #1150
jeppesen's Avatar
I'm pretty sure its in factory settings, I just put it in for two weeks ago, (because my gen120 stopped working) and there i set it to program8 , and for this weekends race program 6 was faster.
So i'm pretty sure yes.
Thanks for the help.
Old 12-02-2009, 01:54 PM   #1151
Does anybody have any tips/ set up info for a GM95 running 0.9 software which has 8 profiles for 1/12th scale running 4 cell 10.5??
Bryan D is offline   Reply With Quote
Old 12-02-2009, 03:46 PM   #1152
where exactly do i download the:
CP2102 USB to UART Bridge Controller
I have downloaded the GM_Tool, but i cannot send or receive data with my GM120.
Kecky is offline   Reply With Quote
Old 12-02-2009, 04:38 PM   #1153
Send a message via ICQ to MattW
https://www.silabs.com/products/mcu/...CPDrivers.aspx
and then download the version that corresponds to your O/S.
MattW is offline   Reply With Quote
Old 12-03-2009, 02:34 AM   #1154
Originally Posted by MattW View Post
https://ww.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx
Cheers Matt.
I've downloaded and installed the 'VCP Driver Kit' for my operating system and re-booted my computer, but when i try and install the 'USB Driver Installation Utility Software AN335SW' an error message comes up saying 'Error reading "setup.ini"', anyone know how i get over this, as i thought that file was part of the VCP Driver Kit installation.
Cheers
Old 12-03-2009, 09:13 AM   #1155
0.9 or 1.9?
@ConSult Trading
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
