Old 10-20-2009, 12:21 PM   #1081
steveonamission's Avatar
Hi Martin
Any date on the GM Evolution 2 esc ?
What new features does it have? Is it running firmware 7.2? same as 120 atm?
Regards
Steven
steveonamission is offline   Reply With Quote
Old 10-21-2009, 09:39 AM   #1082
bs6ef's Avatar
Hi Martin
i have a gm90 and i can't get the esc to work with a 1s lipo, i have plugged it in and the esc starts up ok, i hear the bleeps but then i have no throttle at all, i have tried all my brand new lipos and also i have tried three different motors and it still does not work. I have plugged in my 4cell nimh and all works ok.
i am running mode 2 with voltage cutoff at 2.3v if that helps.
regards
Steve
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 10-21-2009, 02:07 PM   #1083
Originally Posted by bs6ef View Post
Hi Martin
regards
Steve
Go to page 72 and read what you should do for 1S lipo racing.
Regards,
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-22-2009, 03:03 AM   #1084
I have recently purchased a GM 120 speedo v7.2 and am running mode 8 with a novak ss 13.5 motor, Off load (Ie no pinion attached) it does not seem all that fast when comparing it to my Nosram spec speedo with the same motor, I have read on some websites that there should be a speed jump at full throttle however mine does not seem to do this, I have a Futaba 4pk transmitter with 100% set on throttle and brakes is there something I am missing?
Smartypants is offline   Reply With Quote
Old 10-22-2009, 03:29 AM   #1085
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Doesn't sound fast but is fast geared hard enough
if you want to have it sound fast look a few pages back. There'll u find s program by me
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-22-2009, 06:56 AM   #1086
Martins program definitely gets it close to revving as hard as a stock spec
LRP or Nosram speed controller..!
the difference being, you can boost the bottom end on a GM, where as you cannot with the others.
my motor seemed to get a bit hot when using Martins program,
so i just lowered the start amp a bit and couple of other bits.. still revs hard
and is almost as quick out of the corners, but isnt running as hot now. excellent!
( i expect it was more my driving style that got it hot! ?? )
pee vee is offline   Reply With Quote
Old 10-22-2009, 03:49 PM   #1087
jonny123's Avatar
Hi, I have been running sensirless on this esc for a while now in mod and the esc had worked perfect. Tonight tho I put my gm 10.5 in and put martins setup on the esc. When on anything above mode6 the motor sounded dreadfully ratteley in middle revs Which seemed very strange. Something to do with the advanced timing. This same motor ran fine in my pearl without the I'll noise. It sounds like it could be the rotor but it doesn't do the noise when running sensirless or below mode 6. This noise is with and without pinion. I have tried an esc re set and tht didn't solve it! I'm stuck.
Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 10-23-2009, 12:27 AM   #1088
The Sound is normal As the Motor gets overtimed if there's no load applied I.e. Car is not on the track
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-23-2009, 09:48 AM   #1089
John_S's Avatar
hey martin i sent you an email the other day but im not sure if you got it so i will just post my question here. I was wondering if you had a copy of marc fischers speedo settings from the 1/12th euros in holland? If not can you advise a good starting setup for 10.5 with firmware 4.8. I have seen you advice to use the stock how to settings but would you advise a mode 6 or mode 8 copy and are there any other tweaks you would advise. Thanks
John_S is offline   Reply With Quote
Old 10-23-2009, 12:54 PM   #1090
Hi Martin,
Thanks for the help at ETS race.
Frans
Frans H is offline   Reply With Quote
Old 10-24-2009, 09:29 AM   #1091
Is there a way of getting my GM 120 firmware updated to verson 7.2, mine currently has 4.9.
Thanks Cam MacDonald
Little Mac is offline   Reply With Quote
Old 10-24-2009, 10:42 AM   #1092
John_S's Avatar
You need to send it back to gm in germany m8
Old 10-24-2009, 02:59 PM   #1093
JonboyGB's Avatar
Hi Cam, yep you need to send it off to GM in Germany. 3 mates and I have just done this, took about 2-3 weeks and cost 44 euro's (for 4 esc's).
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-26-2009, 03:04 AM   #1094
hana166's Avatar
Hi I was wondering is the 7T delta safe to use with lipo and GM120?
For the 6T they don't quote power for 7.2v so I'm assuming its way too much.
I drive TC rubber carpet 10.5 lipo but will try outdoors next year also.
Never used anything faster than 10.5 but would like to frighten myself. I would like to improve my technique.
I have found 13.5 has helped my skill when I go back to 10.5.
When I see the mod drivers I understand they have a lot of skill to drive cars this aggressive and maintain high corner speed.
hana166 is offline   Reply With Quote
Old 10-26-2009, 03:14 AM   #1095
7T is about the max you should use ... I really doubt anything faster will improve laptimes
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
