Old 10-13-2009, 11:23 PM   #1066
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
can you provide a link to the specs etc of these esc's and where to buy them? Thanks
Caster Racing USA Dirt Oval
Hyperdrive
Tekin
THD Custom R/C Products/Team Holy Rollers/Team Terribles
loopedout is offline   Reply With Quote
Old 10-13-2009, 11:32 PM   #1067
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Specs
http://shop.graupner.de/webuerp/serv...11&language=en
you can get it from Hobbylobby
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-14-2009, 03:41 PM   #1068
it there anyone that can give clear details on what exactly the effects of the special settings do.
because if you click the [?] button, a lot of it is in German, and i cant understand it LOL
minimum timing timing 1 timing 2 etc. thanks!
pee vee is offline   Reply With Quote
Old 10-15-2009, 04:57 AM   #1069
I really cant make up my mind between the GM 120 7.4 or the Tekin rs pro. I like the look of both, I see tekin now has a turbo delay that will allow the turbo to kick in later so more top end speed. Does the Gm 120 have any thing like a turbo function ? I run 13.5 maybe 10.5 what function other than adjustable timing does the 120 have that will benefit a 13.5 motor.
FLAT OUT is offline   Reply With Quote
Old 10-15-2009, 05:29 AM   #1070
*SBH*'s Avatar
Hi FLATOUT
Actually it was Ralf Helbing from GM that invented the turbo function many years ago, so Yes thats included. GM speedos where the first where You could control amp limit without loosing top speed
*SBH* is offline   Reply With Quote
Old 10-15-2009, 06:11 AM   #1071
bs6ef's Avatar
Hi Martin
i'm going to be running the gm90 with a 4.5t and a 1s lipo for the first time at the weekend, now i've just got a Novak voltage booster to run and i noticed in the instructions it stated that the speedo has to be left turned off. So what do i do with the speedo that has no on/off switch????????
1. Do i just plug it all in and run it as normal?
2. Do i remove the red + wire from the Rx speedo plug
3.???????
Any help would be much appreciated
Cheers
Steve
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 10-16-2009, 08:53 AM   #1072
Originally Posted by bs6ef View Post
Hi Martin
3.???????
Cheers
Steve
Hi Steve!
If you do not turn ON ESC it will be not working
I know some info from Ralf that we should not cut off red wire, because
ESC need some power delivered from RX (some small nimh batt connected
to BEC at RX).
With novak I don't have experience (I wait for this item). I think it should workinig like manual said, connect wires to 1S lipo, plug it to RX to BEC and try. I have hope nothing burned off :-)
Regards!
m.
ps: I do tests with spektrum pro receiver 3001 with small batt 2S lipo 250mAh connected to BEC and my GM ESC work with 1S lipo
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-16-2009, 09:50 AM   #1073
adri-13's Avatar
i drive with the GM 120 2de generation and the 13.5 team ptit'yo. It's the must! i have programed my speed controller with Julien Galineau ( official ). It's more easy...
GM... we make the fast stuff!
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 10-19-2009, 03:22 PM   #1074
Angry Where I lost 'bip' ?
Hi Martin!
Now I'm after some test with upgraded 95 to new software. There is too much options to play
However, I set by tx mode 3, put yous setup posted some pages ago, unclick temp cut off and send it to esc. I lost 'bip' option... Is this normal? In resserved1, when new box open, 'bip' and 'sound' options are aktivated... WTF is going on?
Have you got this? Now I don't know where am I with speedo... Everything working nice on table but esc doesn't inform by 'bip', doesn't made any sound..., if I do factory reset everything is ok
Older software was a little smarter
Btw can you post setup for [email protected]? Maybe you have file for new software? We still in Poland drive on this.
Regards and good luck!
M.
edit: made mistake, reserved1 not 2!
Michal Abramowicz
Old 10-19-2009, 03:30 PM   #1075
reserved2 has nothing to do with beeps
I always disable beeps
it's unnecessary as I know I don't make any mistakes
if you want them to be on, set reserved 1 to 128
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-19-2009, 04:28 PM   #1076
Hi Martin, you got right!
But next question is, if I go to Special Settings, and change anyone level
on left side, Reserved1 always change to 254 and "bip" get lost ;-)
Hm, when 128 is set -> only one box 128 is checked, if I change something (for example) Timing2, change to 254, almost all boxes checked and some special --- 16, 32, 64 what is this?
Maybe I should always set it to 128 and know by "bip" where I am now ?
Some bug in 1.3.6 software or feature?
I think better and faster solution is prepare some gda files and only put them
to esc without "magics" done by "levels"
Eh. Maybe is too late for play with speedo
Regards,
m.
ps: what is minimale Timingzeit, Fixed timing, Max. Timing?
I can't find info ...
ps2: modified file from your setup to 5 cell, maybe is ok, can you look at this?
File Type: txt From_Martin_fw72_13.5_lipo_to_5cell_9.5.txt (891 Bytes, 102 views)
Michal Abramowicz
Old 10-19-2009, 04:59 PM   #1077
I tell you now what I tell everybody else ....
just leave the special settings alone and don't change what you have no clue off ...
it's far too complicated so just leave it as it is
for 9.5/5cell the setup you have now doesn't work as the 9.5 will definately blow up
just use FACTORY set mode 7
that's it with 7.2
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-20-2009, 03:04 AM   #1078
Heh, for me it does not explain WHY I should not touch this settings in 1.3.6.
I know that it is some feature for new engines which will be developed
in the future, and when they came real thing, maybe this settings help a lot to performance. I know this from Kajman and Ralf H. Some shit should not be changed and left as oryginal.
that's it with 7.2
hehhe mode 7 from new soft for me is not ok no risk no fun
I look to my saved datas from esc with 4.9 firmware, with mode 6 to 3,
difference is simple:
Reserved (old software has another value, new one need 88 for special features)
Reserved1 (bip problem, need set for 128 before push to esc)
SwitchStartMode=150 (about 16k rpm)
DelayTimeComp=15 (old one, don't get point what is do)
DelayTimeComp=16 (new one)
AktiveDiodeMaxDiff=300 (some shit, left as is)
AktiveDiodeMaxTime=110 (timing 1)
AktiveDiodeMinTime=90 (timing 2)
Just look to this settins from new modes With this bottom for me work.
Timing=3
TimingWith=2
Now with my txt file my car sounds like OLD ESC, I hear when
special timing and all shit start working.
I think, you set only one time esc and drive on it but I want play with
ESC for best from the best performance. Set some modes at home and
only at track switch and choose which is better for me.
Martin, you help a lot to this forum and users, please, no ofence
Regards!
m.
ps: some data get from not update gm: http://abram.eu.org/files/gm_zestawienie_modow_4.9.xls
ps1: if GM go wrong with software and options, I can go witj tekin or lrp
Michal Abramowicz
Old 10-20-2009, 04:08 AM   #1079
you asked for a 9.5 setup and mode 7 is for 9.5
it's the setting all the teamdrivers use 99% of time
there's enough risk if you just gear it hard enough ...
anyway next topic
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-20-2009, 04:12 AM   #1080
anyway next topic
Now Your answer is OK for me.
Problem with 9.5T/5 cell for me is now closed.
Thanks!
m.
ps: I'm always on 1% side ... I must learn how new software works
Michal Abramowicz
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
