Old 10-10-2009, 05:22 PM   #1051
Originally Posted by Martin Hofer View Post
Brake issues are 99% of times Tx setup issues. Please make sure your transmitter values (advanced settings) are as close to 1,9/1,4/1,1 (fullthrottle/neutral/full brake) as possible!
If they are not you are doing the tx setup/mode picking process the wrong way
I get full throttle and brake it just seems that the brakrs do not seem very linear
Quietman is offline   Reply With Quote
Old 10-11-2009, 02:41 AM   #1052
Hi, could you tell me the right way please
as i think thats where im going wrong
thanks!
pee vee is offline   Reply With Quote
Old 10-11-2009, 03:45 AM   #1053
Kajman's Avatar
Yeah, that would be nice, I never know if I should do it quick, slow or what Later surprises like much power at beggining or no brakes appear
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 10-11-2009, 09:31 AM   #1054
jonny123's Avatar
hi guys,
I got my faulty GM 120 replaced with a brand new unit with the new firmware. Thankyou GM .
So im ready to feel some speed again.
Martin just wondering if you could post/send me ur mod setup for Gm 6t delta and 5cells. I know it'll be pretty basic as you just run them sensorless but could you post a .gda file for me to look at.
But im confident im not going to be slow on whatever setup lol, its just soo quick and efficient.
Cheers again,
-Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 10-11-2009, 12:52 PM   #1055
Smile
Used my gm in my pan car today all i can say is that i am very happy with it loads of speed and runtime did not have to touch the gm from the start
Old 10-11-2009, 09:39 PM   #1056
R1wurks's Avatar
is this available in US? where?
R1wurks is offline   Reply With Quote
Old 10-11-2009, 11:49 PM   #1057
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
@jonny
can you please send me a .gda file with your transmitter values in it and the desired mode you want the setup to be on?
[email protected]
@ tx setup
I'm at uni right now and just about to leave so I cannot write it right now but I will post a quick how-to later
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-11-2009, 11:52 PM   #1058
Send a message via MSN to PMSorber
Yups. Beside that we use the new break software and current limit for brakes off. But ... take care that your transmitter is set to 100% end-point on brake!
Our test showed (we also had no brake) that the end-point was set to 60%...
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 10-12-2009, 08:26 AM   #1059
tx setup guide:
preperation:
endpoints on the transmitter have to be set to 100% and NOT more!
get a full battery pack, unplug the sensorwire if plugged in (works with sensorwire aswell but if it's unpluged you see the leds to check if you are doing it right)
turn on the speedo
let it boot and then press the button until you hear a long beep (programming mode enabled)
now you pick the desired mode
full throttle = mode one
full throttle - full brake = mode 2
full throttle - full brake - full throttle = mode 3 and so on
after every throttle trigger movement you hear beeps, depending on which mode you just passed
i.e. full throttle - 1 beep - full brake - 2 beeps - full throttle - 3 beeps and so on
always hold the position you just went to wait till the beeps are over then move again and hold the position
if you reached the desired mode just hold the last position (either full throttle or full brake) until you hear a long beep (programming mode over) and then you should hear a number of short beeps depending on which mode you picked and if the beeps haven't been disabled
if you now read out your speedo you should have transmitter values around 1,9ms/1,4ms/1,1ms for full throttle/neutral/full brake
that's it
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2009, 11:12 AM   #1060
So when you are setting the MODE it detects how far the sticks move and uses them as the values??
thanks
Old 10-12-2009, 11:19 AM   #1061
jonny123's Avatar
hi martin, ive sent you the email. Hope you recieved it ok.
Oh yh by the way, when i do my transmitter setup when im on the mode im on ie mode 3, ive always let go of the trigger/stick and then waited for the long beep. But you say i should hold it on the throttle or brake. I'll try that then although i have never had any problems using my method.
Jonny
Old 10-12-2009, 01:27 PM   #1062
it's just more secure that way
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-13-2009, 12:56 PM   #1063
Default USB Interface cable GM-Genius controller
Hi Martin you could tell me the reference cable to connect 120 to pc gm
manchu is offline   Reply With Quote
Old 10-13-2009, 04:45 PM   #1064
hana166's Avatar
I have raced the 7.2 firmware a few times now, spent (quite) a few hours on the software and I have to say...its just incredible.
No cogging, really smooth. Feels fantastic all round. My laptimes have fallen quite a bit.
The new reserved functions and power curves are excellent. Gives you complete control over the power delivery. Min timingzeit is a clever function, allows you to bring temps down and smooth the timing without really changing your setup too much.
You can set this controller to track conditions, layout and driving style, if you are prepared to learn the thing. Not for the technophobe though..
This is a big improvement over 4.9 particularly for stock motors
Big THANK YOU to GM !
hana166 is offline   Reply With Quote
Old 10-13-2009, 11:16 PM   #1065
@hana
glad you like it
i have posted a 13.5 setup few pages ago btw
as for the pc interface,
it's supplied with the 120 speedos
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
