Old 10-09-2009, 01:05 PM   #1036
Originally Posted by Jordan-Howe View Post
Hi
I am having a issue with setting up my GM120, I can send the data to the speedo but when i receive the data it hasn't saved it and just shows up the factory settings. Matt W has tried to fix it but has had no luck with it (Very appreciated for trying to fix it tho Matt ) Does any else have any other ideas that could solve the problem?
Regards
Jordan
Seems like battery NOT CONNECTED to the ESC.
Try connect batt first and download data
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-09-2009, 01:22 PM   #1037
Send a message via MSN to PMSorber
m.
M... you do not need to connect the bat for receiving and sending. ESC is powered bij USB.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 10-09-2009, 01:36 PM   #1038
Send a message via ICQ to MattW
In fact I have seen when battery is connected, it won't transfer data at all. Jordan, that was a proper odd issue, neither me, CK or CG had any ideas - one for Martin me thinks.
MattW is offline   Reply With Quote
Old 10-09-2009, 01:41 PM   #1039
Check your PC settings, your USB must have "Powering support" ON
If its off, it will not power the ESC.
@ConSult Trading
Old 10-09-2009, 01:58 PM   #1040
Thumbs up
Maybe yes mabye not, got this issue at last race, because forgot connect batt. Pc software got some data and stop. Maybe good usb provide power but I don't believe to this
Regards!
M.
Michal Abramowicz
Old 10-09-2009, 02:05 PM   #1041
Thumbs up
Ups.
Michal Abramowicz
Old 10-09-2009, 02:06 PM   #1042
Regards!
M.
Could be that if the USB can not provide enough energy, you need to connect the bat. We never had this problem and read and write without bat.
@ConSult Trading
Old 10-09-2009, 03:40 PM   #1043
My point was that everything works when you don't connect a pack/cells, but, if you have pack/cells connected then I have seen it fail - although mine seems fine with this!!
That isn't connected to the issue that Jordan asked about though.
Old 10-09-2009, 05:33 PM   #1044
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
have you updated your pc software/ usb driver recently?
it's absolutely necessary to keep it up to date
check your sensorport on the speedo if there is a pin bent! (you need to have a really close look :-) )
the battery should not be connected to the speedo at all when setting up the speedo!
the ubs powers the speedo and nothing else...
for lipo modified just use regular mode 2/3 sensorless with factory settings
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-10-2009, 04:34 AM   #1045
Nuno Gancho's Avatar
And donīt forget to switch off the speedo if the switch is on it will not work
Nuno Gancho is offline   Reply With Quote
Old 10-10-2009, 05:10 AM   #1046
Hi
I have got a 120 with 4.9 firmware for my 12th i set it up like i want but the brakes seem to be ethier grabbing or none at all any one got a set up for the brakes.
Also on the other esc i have had all i had to do was turn down the atl on my handset but on this one it makes the car roll forward instead it this a fault someware ?
Quietman is offline   Reply With Quote
Old 10-10-2009, 06:33 AM   #1047
Originally Posted by Quietman View Post
Hi
I have read some other issues with brakes on other forums... In general I can only say, dont use brakes (12th scale)
We will do some tests this evening and will let you all know what to do.
@ConSult Trading
Old 10-10-2009, 06:52 AM   #1048
Old 10-10-2009, 10:06 AM   #1049
Hi
i cant get the brakes to work on mine either!
well not very well anyway.
pee vee is offline   Reply With Quote
Old 10-10-2009, 03:44 PM   #1050
Brake issues are 99% of times Tx setup issues. Please make sure your transmitter values (advanced settings) are as close to 1,9/1,4/1,1 (fullthrottle/neutral/full brake) as possible!
If they are not you are doing the tx setup/mode picking process the wrong way
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
