Old 10-19-2007, 03:43 AM   #91
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
u notice a broken sensor right away. as it is no longer working, when using a sensor cable. this happens to all motors of that kind of brand (gm, orion, speedpassion, checkpoint ...)
u could try to resolder all solderpoints. sometimes this helps. it not -> return to factory
the timing of the motor has to be in mid c otherwise you will have a HUGE lack of runtime. Even with b to mid c it's still not perfect and you won't have as much runtime as with a matching esc but it will work
the motor comes apart quite easy. 3 screws in front 3 in the rear and it's open.
genius 100 -> 415
one of our teamdrivers races a 415 with gm brushless and uses a genius 100 atm. so it works.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-19-2007, 04:34 AM   #92
Send a message via MSN to mark34 Send a message via Yahoo to mark34
Thanks for the quick reply Martin
many thanks
Yokomo BD
CEFX C12
Powered By Demon Batteries and GM Brushless and 2 thumbs
Mark Ashby
mark34 is offline   Reply With Quote
Old 10-19-2007, 05:42 AM   #93
Default Sensors
Sensors and the solder points can break through heat and vibration. You can order the Sensor part complete for the GM EVO3 motors #97243.2 to replace the damaged one yourselve.
Look at www.graupner.de under the order number of the motor at "Ersatzteile" (=spare parts) you will see all tuning parts and spare parts.
With 2894.12 you can check the sensors.
Because a broken sensor can occur at any time most of the GM-Racing drivers are running without sensor wire, sensorless.
habicht is offline   Reply With Quote
Old 10-19-2007, 10:16 AM   #94
Thanks for the very prompt and informative replies. Sorry to show my ignorance, but do I take it that LRP motors differ in some way in relation to their sensor arrangement, or are they the same as all the others that you mentioned.
Again, many thanks
xraydad is offline   Reply With Quote
Old 10-19-2007, 10:21 AM   #95
The sensor arrangement is same as all the others, like Orion, Checkpoint, Trinity and Novak. LRP does have nearly the same, but less Timing.
You can adjust the Timing on our motors and turn it a little backwards (to solder point C) for more efficiency. Some drivers do also drive it original.
Old 10-20-2007, 03:55 AM   #96
Thanks very much for the very informative answers - feels like the first day at school for me at the moment.
Old 10-24-2007, 12:33 AM   #97
Send a message via ICQ to piorc
Hey guys, please, somebody knows where i could find gm genius 100 brushless systems and evo3 motors in usa ou some on line hobby shop?
i cant buy via graupner, there just sell for germany!
tks a lot
marcelo
piorc is offline   Reply With Quote
Old 10-24-2007, 12:44 AM   #98
Hobby Lobby does order most of the GM-Racing and Graupner products, if you order there.
Old 10-24-2007, 08:37 AM   #99
I've just got a Genius 100 and the RS232 cable. When I connect the battery to it (5 cell) with the setup cable connected it doesn't power up (or at least no LED lights up and no data is received).
It does power up if I remove the setup cable.
Is that normal behaviour?
THancock is offline   Reply With Quote
Old 10-24-2007, 08:57 AM   #100
to transmit or receive datas from/to the genius you have to push the setup button, then connect the esc with the batterie
you hear 6 beeps, wait until only the green led is flashing, no the esc is ready to receive datas.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-24-2007, 01:55 PM   #101
check your 8 pins of the connector. Maybe you bended one and they do a short circuit.
Old 10-25-2007, 02:37 AM   #102
Okay, almost there I think.
If I use the new "2894.6 PC-Testversion Genius" version of the software, I get an Error "TimeOut" whilst the receive button says "Read Data" (greyed out).
If I use the old "2894.6 Software Genius/PC" software it loads up the data it has received into the application without any errors.
Are there any known problems with the new "test" version?
Old 10-25-2007, 02:41 AM   #103
"If I use the old "2894.6 Software Genius/PC" software it loads up the data it has received into the application without any errors."
I use also this version. The other one should work, too, but I know the above one much better.
Old 10-25-2007, 02:55 AM   #104
The "TestVersion" has settings for sensored or sensorless motors. Does that make any difference to the controllers operation? or is it just for reference purposes?
Old 10-25-2007, 02:58 AM   #105
It's just for reference.
f.e. Timing is only adjustable for sensorless mode
For sensored motors the timing is adjusted on the sensors.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
