Old 10-02-2009, 06:55 AM   #1021
Send a message via ICQ to MattW
Make sure you don't have a battery connected to the ESC when you try to do PC comms.
MattW is offline   Reply With Quote
Old 10-04-2009, 11:07 AM   #1022
Hi guys who has run the 150 speedo? And can anyone tell me what the difference is power etc?
rc
prodriver is offline   Reply With Quote
Old 10-04-2009, 11:27 AM   #1023
150 is for 1/8th scale - can deal with big voltages. Not sure there is much point for 10th!
Old 10-04-2009, 02:04 PM   #1024
Originally Posted by Martin Hofer View Post
Here's a Speed Setup for 13,5 / 17,5T with Lipo and
FIRMWARE 7.2!!
please only use this setting for FW72
before putting that program on,
read out your speedo,
then save the transmitterdata to your pc,
load that setting,
load your just saved transmitter data,
send to the speedo
have fun
that makes it really quite quick!
pee vee is offline   Reply With Quote
Old 10-04-2009, 02:26 PM   #1025
mike and Alex's Avatar
My son has been running the GM120 for some time already and he keeps complaining about the lacks of brakes on the speedo.
Can somebody suggest a good ESC setting for both 10.5 and 6.5 with Lipo
The ESC has the 4.7 firmware
Regards
Alexander Robertson
Schumacher UK Team Driver, Lesro Models and Low Drag Racing
2008 Scottish Junior Pro Stock Champion
2009 and 2010 Scottish Junior Carpet Champion, Pro Stock
2009 Stonehaven Pro Stock Junior Champion
mike and Alex is offline   Reply With Quote
Old 10-04-2009, 04:22 PM   #1026
Personally I would suggest more initial breaks on the PC settings. Breaks was something that felt a little strange to me when i first switched. Myself and Chris G (and a few others i think) run initial breaks up at 40. It is a very personal thing, some like it, some don't.
I don't think break settings are any different between current and FW4.7 - i'm sure Martin will correct me if i'm wrong! 4.9 was the first FW that I ran. There is an option under "reserved" for new break software. I run this all the time, but i'm not 100% sure which FW this became available.
Old 10-05-2009, 02:02 AM   #1027
alan1467's Avatar
where can I get either a 90 or 120 speedo for my 1/12th scale from?
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 10-05-2009, 03:52 AM   #1028
Send a message via MSN to PMSorber
Originally Posted by M.Abramowicz View Post
Hi!
Mode 3 with or without sensor (without working very nice).
There is some Novak suggest about rollout:
http://www.teamnovak.com/tech_info/b...r_gearing.html
With 5.5T start with about 30-32mm and test for speed and temp of engine
Def of rollout is simple: diameter(mm) tire x pinion x 3.14 / spur = rollout mm, for example, 44x24x3.14/94=35,27mm
Regards!
m.
OK, here some feedback from our tests at the European Pancar Series.
We ended up with driving a GM-8 Delta in combination with MODE-2 sensorless. Within 1:12 scal its not all about rollout as you also want to minimize rotating mass and driving-hight. Normally our gar go's quite well with 43 - 44 mm rear tires. Based upon this we did see the best result with a ratio of +/-5 and a rollout of 28. Dont forget is also depending upon the track.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 10-05-2009, 04:09 AM   #1029
Nuno Gancho's Avatar
Hi Martin, is there any new software for the duo charger, and should i store the lipos afther race, is there any program? Thanks.
Nuno Gancho is offline   Reply With Quote
Old 10-05-2009, 05:56 AM   #1030
bs6ef's Avatar
Alan
www.actionmodelcentre.co.uk and speak to Wim
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 10-06-2009, 02:38 AM   #1031
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Firmware 7.2 now is standard on all new genisu 120 and it's much easier to setup really
as for the new brake software, it has been made availabel with Firmware 0.6 :-) so long time ago
genius 150 is 8th scale dedicated speedo
it can handle higher voltages
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-07-2009, 11:59 AM   #1032
I'm having trouble getting the brakes to work very well on my 120..
(no trouble getting it to go forwards very well though!! )
even if i turn them up to 100 they still dont seem very good.
how do i set the speed controller to my transmitter again?
the instructions dont seem too clear on this.
thanks
Old 10-07-2009, 02:08 PM   #1033
Default gm 120 spedd passion v3 5.5t
Martin Hi could you tell me some settings for a 120 gm motor esc passion spedd v3 5.5ty lipos greetings
manchu is offline   Reply With Quote
Old 10-09-2009, 12:58 PM   #1034
Jordan-Howe's Avatar
Hi
I am having a issue with setting up my GM120, I can send the data to the speedo but when i receive the data it hasn't saved it and just shows up the factory settings. Matt W has tried to fix it but has had no luck with it (Very appreciated for trying to fix it tho Matt ) Does any else have any other ideas that could solve the problem?
Regards
Jordan
T.O.P UK Racing Team - MuchMore UK - Tekin - Kifopaint
Jordan-Howe is offline   Reply With Quote
Old 10-09-2009, 12:59 PM   #1035
Hi I have a gm 120 and i have a few questions
When you run a nosram 5.5 motor without a sensor wire what do you set the timing at in a 12th?
On my nosram evo esc i used to use the atl on my handset to alter the throw of the brakes now it makes the car go forward is there any way to stop this?
Or do i have to do this on the pc?
Quietman is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
