Old 09-29-2009, 03:46 PM   #991
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
depends on how long you can wait
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-29-2009, 04:00 PM   #992
ok, are we saying there something new coming n I should wait, if it concerns running 1s I'm interested!
jas1 is offline   Reply With Quote
Old 09-29-2009, 04:03 PM   #993
Here's a Speed Setup for 13,5 / 17,5T with Lipo and
FIRMWARE 7.2!!
please only use this setting for FW72
before putting that program on,
read out your speedo,
then save the transmitterdata to your pc,
load that setting,
load your just saved transmitter data,
send to the speedo
have fun
File Type: txt fw72_13,5_lipo.txt (859 Bytes, 368 views)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-29-2009, 04:10 PM   #994
change the .txt ending to .gda to make the gm software recognize the file
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-29-2009, 04:19 PM   #995
Last edited by Frans H; 09-29-2009 at 04:21 PM. Reason: wrong post in wrong section
Frans H is offline   Reply With Quote
Old 09-29-2009, 04:39 PM   #996
Would that work for 10.5 aswell as 13.5/17.5?
Old 09-30-2009, 03:48 AM   #997
FIRMWARE 7.2!!
Thank you Martin!
To others, in txt file is:
Sensor=0
Should be 1
btw, ControllerMode=2 is mode 3 set by radio???
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-30-2009, 04:34 AM   #998
it might work if you can find a really good cooling fan :-)
it will be ballisitic in any case
for 10.5/5cell change the undervoltage cutoff to 3,6V and use the soft powercurve
Originally Posted by M.Abramowicz View Post
Thank you Martin!
Sensor=0
Should be 1
m
it's a setting by me, there is not mistake in it ...
the sensor setting is worthless and doesn't matter at all ... it's just a information and has nothing to do with the actual speedo program
it's mode 2 I think but it doesn't matter anyway with FW72
all modes are the same / can be programmed the same
note that the background copying process doesn't work therefore!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-30-2009, 08:54 AM   #999
So, Martin you said that NOW with NEW soft we don't need sensor wire for
spec/stock engines??? Are you sure?
Have you done some test and without sensor is better?
I'm sorry for asking, but up to update without sensor stock engines was
badly slower then with sensor setup
Regards!
m.
Michal Abramowicz
Old 09-30-2009, 09:31 AM   #1000
No read it carefully
you wrote sensor = 0, should be 1
this option is just information for the user and not an actual setting of the speedo. The speedo detects wether it's used sensored or sensorless
for additional timing you need a sensorwire
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-30-2009, 11:00 AM   #1001
When ordering a new speedo you might want to ask for an updated one.
You can get them with firmware 7.2. With that you are prepared for whatever the rules will be like in the new season.
So feel free to order your speedo now.
They are available again now.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-30-2009, 11:56 AM   #1002
Ate:
from now on all new speedos are programmed with firmware 7.2 right from the start
this means no longer necessary updates
worth waiting huh?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-30-2009, 07:11 PM   #1003
Where can I buy this nice piece and the GM racing website is?
Isaac is offline   Reply With Quote
Old 10-01-2009, 02:54 AM   #1004
Thumbs up
Eh,
Martin, there is some big mess in my knowledge ... I read this forum and now got big f*** confused.
Sometimes you wrote that sensorwire is need or not.
Need for stock/spec engines for higher power (new software from 4.9 to new one, provides change timing when reach some rpms).
Don't need for modified engines (it is correct for me, tested on 4.9 in E12).
So, if I need more power (last time copy 6 to 3, this mean I override data
in mode 3 buy 8) I should have sensor wire for spec racing, without it, there is no power. If I remember, sometimes I set data by pc and forget switch
to sensored (Sensored = 0 in ESC), has plugged sensor wire and car was
slow, no power, no rpms. When resetup data by pc, and set SENSORED,
situation changed, biger power and rpms then before.
Now, I gonna test my new upgraded esc with stock engine, and check it how it works now. With plugged sensors, unplugged or something.
Without it, I stop believe to this forum, because there is some mistake or what?
Regards!
m.
ps: no offence, Martin, I want clear my mind and know how it best work for me with spec/stock engines
Michal Abramowicz
Old 10-01-2009, 04:26 AM   #1005
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
you always need a sensor wire for anything but fast mod motor 5.5 or lower really.
13.5, 17.5, 10.5 always need sensor wire, or you will not get the extra timing.
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
