Old 09-03-2009, 08:14 AM   #916
Hi Martin!
I fired up evo 3 10.5T (got about 130C and plastics from wires fall down...),
so rotor 12.5mm got only one run if it is still usable or one temp like that and
rotor is fu....
Regards!
m.
ps: I will try rebuilt some other engine with this rotor ... ~20Euros go away ...
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 09-03-2009, 08:22 AM   #917
Kajman's Avatar
My friend, you can still practice with this rotor, but no good results during competition....
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 09-04-2009, 05:41 AM   #918
Default GM 10.5 advise
Iam moving up to 10.5 and have just bought a GM 10.5. I run an xray 09 with lipo and a speedpassion GT2 pro esc. Has any one run this motor with a GT2 ?? what settings did you run. Also does this motor come with fixing or adjustable timing as standard. Any other info you guys think I should know about this motor and 10.5 in general would be help full.
FLAT OUT is offline   Reply With Quote
Old 09-04-2009, 10:07 AM   #919
jonny123's Avatar
Thanks Martin its been ripped off now =P.
Flatout,
Havnt run the gm 10.5 motor with a GT2 esc only a GM 120. All GM motors have fixed timing as standard but the variable timing end plates are available. Generally the GM motor runs cooler due to the big cooling holes.
-Hope this helps
-Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 09-04-2009, 01:04 PM   #920
Flatout,
-Hope this helps
-Jonny
Thanks Jonny, Do you run the motor standard or with the timing ring. Also what sort of gearing should I be looking at for Cotswolds. I know we have different esc but a ball park figure would be help full.
Thanks Again
Adrian
Old 09-05-2009, 08:01 AM   #921
jonny123's Avatar
Hi adrian, Sorry for the late reply. I always run the motor as standard i know some people who have tried the variable timing plate and then having to turn the motor timing down into minus's so theres not much point. A good starting point for cotswolds is about 4.5.
Jonny
Old 09-05-2009, 08:29 AM   #922
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
it should be noted that the variable timing plate isn't legal for 10.5 and mod in the uk.....
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 09-05-2009, 10:08 AM   #923
Thats handy to know nice one
Old 09-05-2009, 02:57 PM   #924
jonny123's Avatar
Anyone know the standard rotor size that comes in the GM 6t delta?
Assuming its not a 12.3 what benifit would the 12.3 give me to the standard rotor?
-Jonny
Old 09-05-2009, 04:52 PM   #925
Send a message via ICQ to MattW
The last 6 turn I had came with a red ringed rotor which is 12.5mm - which IMHO is probably the best all round rotor for mod racing. The 12.3 (purple ring) is a lot weaker as the core of the rotor/shaft diameter is 7.3ish rather than 5mm ish (it's a long time since i bothered to measure them - hence i'm not 100% sure!) so there is quite a lot less "magnet".
The weaker rotor will obviously have more RPM and less torque, but personally i'm not convinced i'd run it in a 6 turn - BUT, I haven't tried it.
MattW is offline   Reply With Quote
Old 09-06-2009, 02:08 AM   #926
Rogier's Avatar
Has anybody tried the GM120 already indoor on carpet? The winter season is comming up and I want to race it indoor. Is the stock how to suitable for inside? Any advice ont gearratio with 13.5? Thanx in advance!!
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 09-07-2009, 08:06 AM   #927
hana166's Avatar
Hi I have GM120 and Novak 10.5. Both are new. Its hesitant from zero revs 1 time in 5 and the car has not been put on the track yet. I continuity tested sensor cable and board on motor and they seem fine. My Tekin RS and BMC are butter smooth. Is this thing a dud? Am I missing something? Any ideas?
hana166 is offline   Reply With Quote
Old 09-07-2009, 11:23 AM   #928
jonny123's Avatar
Rogier,
the GM 120 is great indoors, you dont really need to change much in 13.5 just get a good gear ratio and maybe turn your amp limit down.
hana166,
I'd recomend re-doing the transmitter and take ur time in doing this. U MUST hold throttle and brake for 3 seconds and let it go back to neutral for a second in between modes. PS: if the cogging is very minor in the pits you probably wont feel it on the track.
-Jonny
Old 09-07-2009, 12:33 PM   #929
hana166's Avatar
Thanks jonny123 I will try this. There is a connector/converter sensor cable included, and I have found a dry joint in the connector which is poorly assembled. I have fixed it and it seems better but not perfect. I have ordered cable 2894.4 so I can go direct from motor to ESC.
I had a few laps with it, the power is absolutely incredible. I suppose its just a matter of experimenting with gearing, motor timing and profile to get the temps acceptable.
It has firmware 4.9, I wonder if the later versions are more refined in the delivery?
Old 09-08-2009, 03:41 AM   #930
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
false .. the rotor is surely not damaged ...
the only way you can weaken your rotor (if it'S a gm) is by heating up the rotor not the motor! and that you can only achieve when the air/track temp is super high, you disable the current limiter and have a 180 turn at the end of a atleast 55m long straightaway ... then you might eventually demagnetize the rotor
other than that it's fine
6T has always been delivered with 12.5mm rotor (the pro ones atleast) and this won't change
we use the 12.5mm rotor (red faceplate) in every motor/winding actually ... no need for somthing else
a slight cog from 0revs on might occure from time to time with the older firmware standings
this has been fixed with fw7.2 butas said it only occures from time to time and then very minor and not while driving
note! don't let your car be pushed backwards at the start as this will cause cogging as the speedo needs to find the magnet first
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
