Old 08-19-2009, 05:52 AM   #886
Originally Posted by M.Abramowicz View Post
Hi!
I got info from Ralf and he suggest add small pack 6V, put it into bec at RX
and don't cut + wire from ESC. He said that, electronics from ESC need some voltage from RX side.
About novak booster I don't know but on 10R5 forum was some pics with
it and nosram esc, url there: http://www.rctech.net/forum/6169246-post357.html
maybe he can help
Regards!
m.
Aren't you supposed to run an opto couple if using a Rx pack?
Jason
jasonb is offline   Reply With Quote
Old 08-19-2009, 05:54 AM   #887
alan1467's Avatar
Jason
run an opto couple ??? what do you mean?
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 08-19-2009, 09:49 AM   #888
Great thread.
I'm running a hot bodies cyclone with a gm 90 and an orion 13.5 in mode 6 with the settings as per page 34 of this thread.
All I'd like to know is on a large indoor track with a main straight of about 30-35 meters whats a good drive ratio to aim for.
at the moment I'm running 24 pinion 78 spur and an internal ratio of 2.437 which gives me an fdr of 7.9, is this ok or way off the mark ?
mobile chicane1 is offline   Reply With Quote
Old 08-19-2009, 12:26 PM   #889
One of these https://shop.graupner.de/webuerp/ser...11&language=en
Instructions attached
Old 08-19-2009, 11:52 PM   #890
Hi Jasonb!
But what this thing do? Cut bec from esc ? More simple is just cut off red wire
In pdf is 6 cell pack which has more V then 1s lipo
Ralf Helbing said just connect small accu to RX and don't cut red + wire
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-20-2009, 04:13 AM   #891
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by mobile chicane1 View Post
Great thread.
well I run that gearing indoors with a 3.5 / 5cell ! so you are quite a bit off the mark
I'd say around 6.0ish should be your starting point
it all depends on motor temperature
as long as it is below 85C you are undergeared ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-20-2009, 04:35 AM   #892
as for 1s Lipo:
just use a RX battery pack and don't cut the plus wire of the ESC bec
set the undervoltage cut-off to 2.5V and don't use a novak booster
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-20-2009, 04:36 AM   #893
I have a question if anyone can help
I am currently using mode 6 copied over 3 running a 13.5T on a small technical track. I'm running firmware 4.9
When I change the switch point on the timing from a non standard value I have noticed the reserved 1 values change on there own. Items 16, 32 & 64 get ticked but none of them have a description by them
Any idea what these do?
Do I need to change them back or should i leave them?
Mad Gerbil is offline   Reply With Quote
Old 08-20-2009, 05:00 AM   #894
this is why I keep telling people not to mess around with that stuff
if you'd have ever had a closer look you will find res1 to be 254 when sending data but then 142 when receiving data again as the value 254 does not exist on the speedo ...
but there's no real reason why to mess around with special settings for standard applications ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-20-2009, 06:33 AM   #895
Martin all I have done is change the switch point as you suggested earlier in this thread.
Old 08-20-2009, 06:45 AM   #896
Well I guess I have to explain that a little more detailed then.
The software usually only sends 28 values to the speedo but receives 38.
The 10 unsent values are the special settings. By setting res1 to 254 you SEND 38 values aswell which is necessary to change the background values.
After reading out the speedo res1 reverts to 142 As that's the highest possible value the speedo can save
then just change res1 back to whatever value it was and send again (28 values this time then)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 08-20-2009, 10:02 AM   #897
as for 1s Lipo:
Martin,
When running a 90 with an Rx pack what setting should I set the the on/off function?
The 90 does not have a switch but the RX pack will have one in line.
Jason
Old 08-20-2009, 10:20 AM   #898
hmmm I need to get a temp reader
Old 08-20-2009, 10:36 AM   #899
I need help.
A club member has a GM 120.
He has no power at all. we tried to reset it and use mode 6 and it still drives very slow. slower than a Tamiya sport tunned and he is using a speedpassion 10,5T on 5 cell.
The motor is ok and the batteries also.
What can be the problem?
I have seen it by more drivers and some of them got a new speedo and some of them hath software problems.
What can he do?
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 08-20-2009, 04:58 PM   #900
speedo should be switched on
as for the power lack problem
I guess you didn't do the tx setup properly or the sensor wire is broken or there is some progam mistake
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
