Old 07-20-2009, 10:57 AM   #856
Robert_K's Avatar
Originally Posted by Martin Hofer View Post
can you tell me which firmware version you got? (when you read out the esc, the white log box opens, after 38 values have been received, the firmware version will be displayed in the top left of the white box)
37) Firmware : 47; TimeDiff : 0.1279 s
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 07-20-2009, 11:27 AM   #857
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
have you read the stock how-to?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 07-20-2009, 11:34 AM   #858
Send a message via ICQ to MattW
Robert, I have to confess myself that when i first switched to GM, the breaking did feel very strange, but i'm not sure the same as you describe. for me, I have to run a lot of initial break (40 usually, but have gone as high as 45) and initially I had to run with some autobreak - 10 I think. I don't run that any more though.
It does sound a little strange, but i do wonder if it's just "different". Has it always been this way since you had the ESC.
I'm not an expert on the firmware versions, 4.7 has now been improved, but i think it was ok. I'm sure i have seen some of the UK guys have this on their speedos with no obvious issues - but then we are generally running mod and sensorless, and that does change the breaking for sure. Martin will know more about the firmware changes.
MattW is offline   Reply With Quote
Old 07-20-2009, 12:55 PM   #859
Robert_K's Avatar
Yes, it's almoste underneed my pillow ;-).
I've tried several things, from a modified mode (1) to a Stock Mode (8), To copying 8 in 3 and 6 in 3, but the braking is the same horrible fact. It's not the feeling that is my problem, its the bigger amount of time (this is a lot more than the Nosram, like said before) that I'm worried about.
I can understand what you mean. And I'm for sure it's different, that doesn't matter for me. But I can not understand that with all the Transmitter ratings at 100 (not 150), and the software at Max Brake 100, Full Brake 100, and Initial brake 40, that I Need to brake for about 25 meter's with a GM speedo, and have blocked wheels at the end of the "brake session" and with the Nosram just 5 meters of braking and only when I slam the brakes realy hard I've got blocking wheels. Is My speedo broke, or am I doing something wrong? Are there maybe more Transmitter EPA's and settings that the Speedo listens to, or something like that?
Is there some test orso that can be done by Graupner when I send my speedo back? (and maybe give it new wires XD )
Best Regards,
Robert
Old 07-20-2009, 01:20 PM   #860
As one test with your radio, I would suggest setting your esc/car up to a brand new and un-used profile if you still have one. I have had some strange issues with just one profile on my radio (also KO) before. I only had it once, but it is worth trying.
Old 07-20-2009, 03:13 PM   #861
Best Regards,
Robert
could you send me your current esc profile of whatever mode you are using (mode 3 I guess)?
you can save it after reading out the ESC with the PC software, then click file and save .gda
[email protected] (email / msn)
I'm sure we can get rid of your issues easily, usually GM got the hardest brakes you can have ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-23-2009, 07:30 AM   #862
TheCoolCanFanMan's Avatar
Hi Martin
Could you tell me how to do a factory re-set please.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 07-23-2009, 11:43 AM   #863
Go into the mode picking process, do full throttle, then full brake, then push and hold the set button untill the esc beeps. It will beep different to the regular beeping when you pick modes as regular
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-23-2009, 02:40 PM   #864
Many thanks, and touch wood it seems to have sorted the delay to
Cheers Malc
Old 07-24-2009, 10:16 AM   #865
Martin,
nice pics at your site from wet race
How you prepare GM's esc for wet race?
Any tip?
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-25-2009, 02:53 AM   #866
mutley001's Avatar
Hi guys
I'm hoping for a little gearing advice please
I'm running a TRF 416 WE TC indoors on rubber tyres
GM 10.5 and GM 120 speedo set as per the "stock how to"
The track is quite technical but with a 100+ foot straight
could you give me a starting point please?
Cheers
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 07-25-2009, 08:27 AM   #867
marcel p's Avatar
Send a message via MSN to marcel p
good starting point is about 6.0 to 6.3
PR racing
Powerstar/futaba 4px
Absima /vr racing
marcel p is offline   Reply With Quote
Old 07-25-2009, 08:36 AM   #868
marcel p's Avatar
where can i find some setings tips for the extra timing or turbo funtion
i run now 8in3 or 6in3 but i need som extra power at the strait
had a good setting from a team driver with loads of power.
but did by accident a factory reset
PR racing
Absima /vr racing
Old 07-26-2009, 10:50 AM   #869
Originally Posted by M.Abramowicz View Post
Martin,
Any tip?
Regards!
m.
use the fingers of a latex glove and some blue-tack / serpent cleaning gum
6 in 3 is about as fast as it gets if done properly according to the stock how-to
there are no special teamdrivers settings whatsoever
if you lack topend just gear longer ....
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-28-2009, 02:21 PM   #870
Hi Martin, I am running a GM 6.5t with 12.5mm rotor and Lipo on a GM90 esc. The software version is 4.8 and there are people saying that the later software versions give more performance and a better feel. Is this true and if so what version should I upgrade to and how can I do this.
I am currently running in mode 8 over 3.
Many Thanks
Paul
blue247carz is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
