Old 07-02-2009, 05:58 AM   #811
Stein Tumert's Avatar
Originally Posted by plummers View Post
ok thanks.i am using the speedo for stock racing with a 13.5 gm motor. is the download 1-3-6 the correct one, im concerned as it comes up with 'warning this is a test version' in red at the beginning, so i no im using the correct software to change these profiles..many thanks plummers
You need to register the software, see help menu, cost 10 Euros?.
Then you get a proper licence for it and the message you get now will be gone.
If you run 13.5T you may want to try some of the hints in this GM forum.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 07-02-2009, 08:38 AM   #812
Born2Run's Avatar
Hi Martin
I would like to know what are these 12.5mm silver magnets with the small plastic fan the GM Dr.Speed uses.Are sintered or bonded?Also if i could use them (with some modifications on shiming) with my EVO III 7T delta.Thanks
Whatever
Born2Run is offline   Reply With Quote
Old 07-02-2009, 09:04 AM   #813
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
sintered
yes but it'S a lot worse than the standard black magnets
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 07-03-2009, 03:54 AM   #814
Hello all,
Im using the gm genius 120 last few weeks and its great but im feeling that i have to less brake and autobrake.
Could someone tell me what option is more break and which option is more auto break.
Thanks all!
GerwinGood is offline   Reply With Quote
Old 07-03-2009, 05:25 AM   #815
Kajman's Avatar
Well, in my opinion in software it is quite simple written Brake Min, Brake Max and autobrake ANd there you have numbers, higher number, stronger brake Everything is written when you push "?" next to option you want to change nin AS Genius Soft...
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 07-05-2009, 03:05 PM   #816
Hi Martin,
Is it possible for me to send in a motor that's blown and have the guys at GM look at it ?
I didn't get it over 85 degrees at any point, but I've opened it up and it looks like there's a burnt winding and the epoxy holding it together has melted inside the can.
Just to be clear, I'm not blaming the motor, but I'd like to know what I've done wrong with it (speedo settings, gearing, etc)
This is a 6.5 Star motor by the way.
Chris
CPD Racing
chris_dono is offline   Reply With Quote
Old 07-05-2009, 11:12 PM   #817
if the plastic has melted the motor is thru ... only thing to do is to buy a new one
it must have been hot some time, atleast on the inside ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-07-2009, 02:18 PM   #818
TheCoolCanFanMan's Avatar
Well ive tried this twice before, lets have another go
When copying 8 onto 3, what does it actually do please.
Cheers Malc
Also I am still getting a delay off the line, any idea what I can do about this please Martin
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 07-07-2009, 02:34 PM   #819
it converts mode 3 into a stock program
how much of an delay
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-07-2009, 03:15 PM   #820
well i was on pole in the A final of the STCC here in the UK, and as we all went off at the same time, the guy in 2nd place got along beside me on all 3 finals as the race started, thats how much of a delay there is, there was a metre between 1st and 2and and so on. BTW IM IN MODE 8
Cheers Malc TCCFM
Old 07-07-2009, 07:05 PM   #821
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
If you copy the "Mode 8" settings over the "Mode 3" settings I guess you will need to select Mode 3 using your transmitter AFTER you have set up the new "Mode 3" programming...
Martin says in the Stock racing HOW-TO post that Mode 8 is too hard on the motor for stock classes.
r0adrunn3r is offline   Reply With Quote
Old 07-08-2009, 12:48 AM   #822
tomracing's Avatar
actually no.
you select mode 8 by transmitter.
import into the computer program
change the mode in the computer from 8 to 3
then upload this setting from the computer back into your esc
after that your esc will allready be in mode3 so no need to reselect after that.
you can tell by counting the beeps after starting your esc.
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 07-08-2009, 01:20 AM   #823
Cheers Malc TCCFM
has your car been pushed backwards before the start?
what are your transmitter values (advanced settings!) in ms?
Originally Posted by tomracing View Post
actually no.
correct
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-08-2009, 01:45 AM   #824
vr6cj's Avatar
Trader Rating: 124 (100%+)
correct
So any US distributers? Your speedo's are expensive. :P
vr6cj is offline   Reply With Quote
Old 07-08-2009, 02:00 AM   #825
does this matter ???
if so what does it do ??
sidecarphil1 is offline   Reply With Quote
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
