Old 06-30-2009, 12:44 AM   #796
Stein Tumert's Avatar
Originally Posted by TheCoolCanFanMan View Post
I had this same prob, I went into the settings in mode 8 and played with the soft start, and this seems toi have sorrted the delay off the grid
Malc TCCFM
...and which setting did you end up with for "soft start"?
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 06-30-2009, 03:29 AM   #797
jonny123's Avatar
Default Modified Settings
Hi martin,
What are the best settings for running: Speed Passion V1 3.5, 5cell indoor tight track.
Sensorless or Sensored?
PS: Do the nosram motors work sensorless with the GM 120?
Thanks Jonny
Xray-Hudy-Ko Propo-RC DisCo Uk-Ardent Racing-Boultspeed
jonny123 is offline   Reply With Quote
Old 06-30-2009, 03:36 AM   #798
Kajman's Avatar
It depends how old speed passion motor. Old lrp without sensors had problems with GM. But frankly speaking, if a motor doesn't work with every common esc it means it is designed in a wrong way.
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 06-30-2009, 04:15 AM   #799
jonny123's Avatar
Its the first version, (competition series) 3.5R
And the nosram is the X11 Storm EVO 4.5
Old 06-30-2009, 04:32 AM   #800
tomracing's Avatar
I've got everything in the car and nearly ready to go testing just waiting for my last pinions and spurs to come in.
A few things i would still like to know before i try them.
i've got the mode setting down and also the copying etc.
but what is the difference in setting sensor=1 (in the top bar for the addData) and/or adding the value 2 (ifmar/efra hall sensor mode) to reserved ? these things are not linked by the software.
next when i try to make a second setup file to bring with me to the track to try for instance the effect of switching point rpm, as soon as i move this value the reserved1 value changes to 254 (including switching on unknown values 16, 32 and 64). should i leave it at 254 or set it back to 128.
I think this might be a software bug in 1.3.6
from the help pages i found in some case the runup would improve if rpm_limit is set to 8 (125000 rpm). is this something that is used often?
and finally why is the gm120 firmware not user updatable? it uses the same pc to controller interface as the hyperion chargers and i think also the CC mamba max. right now my controller is on 4.9 so i guess some bugs must have been fixed by the newer firmwares. i am just not looking forward to sending in my esc every so often and my computer skills are fine i'd rather do it myself.
thanks
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 06-30-2009, 06:09 AM   #801
Wink
Read this:
http://shop.graupner.de/webuerp/serv...11&language=en
1.3.6 is for NEW software in ESC, sorry you can't play if you have 4.9
You should use 1_1_5 soft for PC
thanks
Regards,
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-30-2009, 11:19 AM   #802
Send a message via ICQ to MattW
jonny123, the SP 3.5 should run fine sensorless. In theory there should be no reason why Nosram/LRP wouldn't either, so i'm not sure why there should be a problem. The motor sensors are not their for the benefit of the motor, they are for the benefit of a speedo that needs them. I haven't ever tried a LRP style motor on GM speedo though, as GM ones are better.
On a tight indoor track you probably wouldn't want a 3.5 anyway. Personally I always run a GM 4 turn star on carpet, even on bigger tracks.
MattW is offline   Reply With Quote
Old 06-30-2009, 03:04 PM   #803
mutley001's Avatar
Hi Guys
Just picked up a second hand GM 120 and want to set it up for stock 10.5 racing using lipos indoors in a TC. I have rather a few questions:
How do I set the comtroller back to factor settings?
It seems that the controller has firmware 4.9, do I need to up grade this?
I'm currenty using PC software version 1.1.5 is this correct or do I need to upgrade this too? The post above seems to suggest I shouldn't.
I've followed the stock how to and managed to set mode 8 to 3, but my transmitter full throttle, neutral and brake are not in the ranges given.
Does this matter much? If so how do I set the speedo to the transmitter full throttle, neutral and Brake correctly?
Sorry for all the probably daft questions but i'm going round in circles trying to read the manual!
Any help you all can give will be greatly appreciated!
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-30-2009, 04:45 PM   #804
TheCoolCanFanMan's Avatar
.15 but it still stalls slightly
Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 07-01-2009, 12:25 AM   #805
Originally Posted by mutley001 View Post
Hi Guys
switch everything on, put the speedo into programming mode (hold the button for a second or so) then hold the button down again for about 3 seconds until there's a long beep. That'll reset it.
I have 4.9 on my 120 and use 1.3.6 software, it seems to work fine.
You don't bind the transmitter like with other speedos. Make sure your throttle and brake EPA's are at 100%. The speedo 'learns' where full throttle/brake/neutral are by you changing modes, so make sure you go to full throttle and full brake when changing over.
CPD Racing
chris_dono is offline   Reply With Quote
Old 07-01-2009, 06:34 AM   #806
mutley001's Avatar
Wicked, thanks Chris, that's helped a lot.
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 07-01-2009, 03:05 PM   #807
plummers's Avatar
Default software and my 120
having just spent out for a gm 120 im finding there are a few different types of software available. its probably already in the posts somewhere but theres so much info i cant see it..im using the 1.3.6 is this correct (it comes up with warning test version),the speedo is new so it should be the latest type.why do you recommend the profile changes, the speedo works fine for me..thanks plummers
plummers is offline   Reply With Quote
Old 07-01-2009, 11:08 PM   #808
Kajman's Avatar
Copying modes one into another is only for people taking part in stock racing. If you don't, you don't have to do it. Latest version of software is not beeing sold with new speedos yet, it may be only changed by GM. But again, it is for stock. If you use esc for everyday use, don't think too much about it.
Old 07-02-2009, 05:29 AM   #809
plummers's Avatar
ok thanks.i am using the speedo for stock racing with a 13.5 gm motor. is the download 1-3-6 the correct one, im concerned as it comes up with 'warning this is a test version' in red at the beginning, so i no im using the correct software to change these profiles..many thanks plummers
Old 07-02-2009, 05:55 AM   #810
Kajman's Avatar
AFAIK you can, but not all functions will work (are for 7.x software).
1.1.5 has all you need, not more.
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
