Old 06-16-2009, 03:39 AM   #766
Hi,
I dont have any experience with 10.5, just 9.5T. But i would advise de EVO3 for smaller tracks (more botom end) and the Pro for bigger tracks (more top end). The Pro also has fan and runs very cool.
Itchy is offline   Reply With Quote
Old 06-16-2009, 03:42 AM   #767
Kajman's Avatar
Is pro with fan?? I have pro 9 and pro 8 and they have no fans.... Due to kV rating pro should be geared much faster than evo?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 06-16-2009, 04:14 AM   #768
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
[QUOTE=TheCoolCanFanMan;5940737]
Originally Posted by Nuno Gancho View Post
Some time i acelerate and the response comes with a delay, and afther a second the car just jumps foward/QUOTE]
Hi Martin
I had this to, not to sure why though, it even felt like it wanted to go backwards
This was the first time I used the GM120.
I was using the Nosram SPEC prior, and was geared at 4.5 using the GM 13.5 but wasn't sure where I should be with the gearing on the GM120, so started at 6.00 but was dog slow after 2.5 mins, so went to 5.3 with a 13.5 Prince motor but came off at 90 degrees, any help with gearing would be appreciated Martin.
Cheers Malc TCCFM
If the Motor is around 85 - 90C (GM) your gearing is pretty much right
Stage 1 of temperature cut, so it is motor temperature to high or speedcontrol? Should i gear up the motor or change set up in speed control (amp limit, frequency......).
About the delay soimetimes afther 1 minut race.
Thanks for your help.
stage 1 tempcut = esc too warm
switch off the tempcut in reserved settings
Originally Posted by Kajman View Post
Has anyone tried all three GM 10.5 motors? Evo3, Pro and Dr Speed? I wonder which would be the best for stock racing on lipo and mode 8--->3. It seems that Pro is strongest, but with lowest kV, dr speed and evo3 differ as far as I know in magnet material and evo3 has fan on rotor. Anyone can say something more about them?
http://shop.graupner.de/webuerp/servlet/AI?ARTN=97289
best one
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-16-2009, 04:17 AM   #769
Kajman's Avatar
Yeah, thanx Martin, but some stupid as...le in Poland decided, that when you want to use LiPo you have to run 10.5T Which one then?
Old 06-16-2009, 04:40 AM   #770
pro
is u can use a regular 12.5mm magnet (red faceplate)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-16-2009, 05:16 AM   #771
Kajman's Avatar
Ok, no problem magnets are not specified at all, I can use any
Old 06-17-2009, 06:05 AM   #772
Kajman's Avatar
Another question - about logger of current and rpm, how to store it into memory?? I have both Genius 90 and updated 95 and 85 and cannot read out this data, what should I do? Maybe power should be connected after measurement untill PC connected or...?
Old 06-17-2009, 09:18 AM   #773
tomracing's Avatar
right so i worked my way through about 52 pages of this topic to try and understand a bit more about the genius120 as i am thinking about using it for 10.5 lipo touringcar.
but i am still left with the following questions:
-I played a bit with the software for the 120 versions 1.1.5 / 1.2.1 /1.3.6
now they all hold the factory settings so i loaded 8.gda changed the value to mode 3 in the software. it comes up with the pop-up questions answered as described in the stock-howto and saved it as a new .gda file.
now with all three software i get exactly the same file as the orginal 8.gda except for the mode now beeing 4 instead of 128 as it is mode3 i am writing.
all other variables are the same as we kept the mode8 background stuff and the basic mode8 values just stored it under mode3. so didn't i just create two the same profiles on my esc?
-software version 1.3.6 has the special functions tab. does the controller need the firmware updated to use these functions?
-so if all programming of the modes is free and the changing of mode value to 3 is of use and suppose i want to quickly see the difference between 6over3 v.s 8over3. can i program both these combinations into the esc in different mode locations (say 2 and 3) so i can switch between them at track with just transmitter and not need a laptop?
hope my questions make sense as i am just going by what i read, tried and understood from the manual and software.
thanks
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 06-19-2009, 01:03 AM   #774
I know that mode 2 is not like mode 3, so if you want play with copy mode 8 or 6 to 3, you should use PC on the track.
For 10.5T/Lipo if I will have time for testing, I will try test mode 6 and mode 8 over 3 and check lap times, because mode8/3 gives big temp (last I'v got about 95C ...) and it is not good for engine
Maybe you found that mode 8 over 2 is OK, but if it will be OK, there will be wrote about it
Regards!
m.
ps: sorry for my EN
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-19-2009, 09:47 AM   #775
press the button shortly once after driving, then unplug from the batt
connect to the pc and read out the data
there's a reason why I wrote to do the mode copying like the way I wrote ...
don't use the standard settings ... they are not the same as the ones on the esc itself
stick to the stock how-to ...
don't mess around with that ... I asked for it not to be made available to public but it was made available ...
you will very sure mess up your esc settings
every mode is different ...
thanks
see above
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-19-2009, 10:57 AM   #776
Hi Martin,
I'm having some problems with the speedo gm120, at the start or when i
try to accelerate on low revs the response comes with a delay.
I'm using an 9,5 t and 5 cell. Program 6 copied to program 3.
Gerd is offline   Reply With Quote
Old 06-19-2009, 12:15 PM   #777
how much of a delay?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-19-2009, 04:21 PM   #778
chb
Hi everyone,
I am a GM fan & I got acquired my 1st product: GM100.
I've read a lot about GM in this thread & learnt a great deal. I still have a question:
1) Is it worth updating to new firmware ? Once updated, does it have all the exact feature of the new GM90 & GM120 ?
2) How much does the firmware update cost approximately ?
Thanks for this great thread & especially to Martin
Chris
chb is offline   Reply With Quote
Old 06-19-2009, 04:55 PM   #779
Kajman's Avatar
Originally Posted by chb View Post
Hi everyone,
Chris
Hi
1) Yes, as far as I know almost (sw 4.7)
2)20Eur
Old 06-19-2009, 10:12 PM   #780
correct
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
