Old 10-14-2007, 11:04 PM   #61
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
different motor/magnet combinations:
if you put a 12mm mag into a 3,5T and then put it in a 7T delta you will recognize that it spins totally different.
i have posted the list of which mag usually is best in that specific motor.
the 12mm mag basicly saves quite a bit of energie but only if you drive smooth. It rolls more but this helps you only if you let it roll.
if u use a 3,5T and want more torque gear it longer (yes right).
on 1:8 tracks we use gearings between 7,2 - 6,7 - 8
on normal size tracks maybe 7,5 - 8,2
indoors i use 8,5 - 10
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-15-2007, 02:11 AM   #62
Which version of the PC Setup Software should I use?
Are there any recommended settings for conserving energy when running 5 cell?
THancock is offline   Reply With Quote
Old 10-15-2007, 02:21 AM   #63
Use the newer one.
Regarding program. Here's what i use atm:
softgas 100
amplimit 200
turbo 1
frequency 1
switch0
abs0
autobrake 0
autorun 0
startamp 130
minbrake 20
maxbrake 92
fullbrake 92
reserved 22 (sometimes 23)
it is very precise on throttle input. super direct with LOADS of punch
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-15-2007, 04:10 AM   #64
Drewdc90's Avatar
Hi guys,
I have been having some trouble with my GM Genius 95 (I think it's the old one). It has been cogging very badly lately, I'm running a Novak 3.5 with the sensors plugged in. I've got three GM caps in parallel soldered to it.
My settings are: AUTOBRK 0%
BRAKEMAX 100%
FULLBRAKE 100%
MAXREVERSE 0%
ABS off
AUTOGAS 0
SOFGAS 0.25s
TIMING 30 degrees
RPM LIMIT 90000
AMPLIMIT 140A
START AMP 200A
TURBO 2A
POWERCURVE linear
BRAKEMIN 0%
RESERVED 6
FREQUENCY 0
The speedo has had quite a bit of use, is there any chance the caps may be a bit old and cause this cogging. If not what else would cause this (I’ve ran the same motor with another speedo and it ran fine, I also tried a different turn motor on the GM 95 and the problem persisted)
Thanks, Drew.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 10-15-2007, 07:54 AM   #65
it mayhappen, that one of the wires of the caps burn through and causes cogging. replace/resolder them caps should solve that problem. also you can make a new radio setup
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-15-2007, 04:08 PM   #66
Drewdc90's Avatar
Hi Martin,
I have checked the caps and all of the wires are fine, I will try new caps next weekend. I'm running a spektrum system with a cap on the reciever so i doubt thats where the problem would be coming from.
Thanks, Drew.
Old 10-16-2007, 03:34 PM   #67
Holmenkollen's Avatar
I have a heat sink attached to the short side of the speedo. Is it possible to remove it? Itīs attached by Mr. Helbing himself...
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-16-2007, 03:40 PM   #68
of course you can remove it.
but you have to think about a way to close the case as to attach the heatsink, part of the plastic case has to be removed. you can either order a new case or close it on any other way
to remove the heatsink first remove the 2 screws that hold the heatsink in place, then you can "brake" it off as it is additionaly glued together.
hope this helps you.
cheers.
martin
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-16-2007, 03:54 PM   #69
edseb's Avatar
So what are the pros and cons of the delta wrap?
edseb is offline   Reply With Quote
Old 10-16-2007, 04:32 PM   #70
Send a message via MSN to afonsospt
Hi,
I have Gm Genius95 and evo3 4,5T motor.
Im not sure about lipo cutoff.I think it cuts at 57/80 of the initial charge,which gives aprox 6,0v if I start with a 100% full pack.
My concern is it safe to use a 80-85% charge lipo pack and have cutoff at 6v?or safe cutoff is only for a full charge pack?
afonsospt is offline   Reply With Quote
Old 10-17-2007, 02:45 AM   #71
cheers.
martin
Great!
Why do the gap need to be closed? Isnīt it better cooling if itīs open?
Can I close it with a piece of lexan?
Old 10-17-2007, 09:47 AM   #72
Nuno Gancho's Avatar
About GM brushless motors, whatīs is the diference in run time, and final speed, and torque if you move the end bel from position B to C?
Why they say if you use other speed control you should set it at C position ?
Nuno Gancho is offline   Reply With Quote
Old 10-17-2007, 09:54 AM   #73
t4m1y4niac's Avatar
between GM and Novak BL which one is faster???
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 10-17-2007, 10:36 AM   #74
Send a message via ICQ to MattW
Nuno, that will give more run time, but i think a little less RPM. It's all down to the way that the ESC "fires" the coils. The GM is different to LRP in this way. I have heard it described as "internal timing".
I always run mid C (as instructions) when running 3.5 and LRP speedo.
MattW is offline   Reply With Quote
Old 10-17-2007, 11:06 AM   #75
If you run sensorless Iīve heard that it doesnīt matter wich position you put the endbell at?
New Novak Brushless Tekin mini rage Brushless 1/18 price to sell IOwNMkeG R/C Items: For Sale/Trade 3 05-01-2008 05:49 PM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
WTT: 1/10 scale NIB car kits for Brushless RC18T or other Brushless 1/10 car Bohh R/C Items: For Sale/Trade 3 04-06-2008 07:26 PM
NOVAK GTB BRUSHLESS RACING ESC 2.4GHZ + 13.5 BRUSHLESS MOTOR meronr R/C Items: For Sale/Trade 12 01-29-2008 02:18 PM
Brushless B4 Brushless T4 Clodzilla 4 ThunderQuake truggy Ofna Lx Pro buggy pcnutz R/C Items: For Sale/Trade 29 12-11-2005 01:12 PM
